Question about Vizio L32 32 in. LCD HDTV
Sound went out
I left the tv on when I left for awhile, when I came back I have no sound!!!
  • Vizio Master
  • 12,061 Answers
Http://www.retrevo.com/support/Vizio-L32-TVs-manual/id/512dj084/t/2/ Above is your user manual, below is your service manual. Check, your Mute, isn't on? nationalservicealliance.com/visio/VIZIO-L37HDTV.pdf
Posted on May 27, 2010
I have a 46 in lg smart tv and the picture went black ,i still have sound but no picture and every once in awhile the picture trys to light up ?
Could be the back light if flat screen which is located in the back of tv. Try shining a flashlight at the screen at an angle and if you see the picture or a portion of the picture, then your back light is out and you have to figure out why.
Oct 08, 2017 | LG Televison & Video
I had a bad storm and the TV turned off. When I went to turn back on, I couldn't turn the TV back on with my remote. So I turned on by hand it immediately would turn off by itself after 2 seconds every...
It appears that there may have been a power surge or something that damaged the electronics of your set and cause it to work the way it is now. You might want to try replacing the power supply since it is the first area that would have a surge go through it and sustain the damage.
Aug 24, 2017 | Televison & Video
Bought it used and the previous owner only used it in his salon. It worked fine for about a month and then I ended up with a line that went right to left and noticed two shaded boxes. I have been noti
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Nov 02, 2014 | Vizio 55" VF550XVT1A 1080p 120Hz HDTV LCD
I have a Samsung HLM5065W. The picture went out but there was still sound. No Lights on or flashing on the front. I unpluged the set let it sit for awhile then plugged it back in. Everything came on and...
Try searching for a possible "factory reset" for this brand. It will be a secret set of buttons on the remote to enter the default reset menu. I hope that gets you something to try. BTW you should have the original remote or a universal remote with all buttons communicating with the tv to do this. ie numbers, menu, up, down, left, right...
Feb 08, 2012 | Mitsubishi WD-52525 52" Rear Projection...
The tv went black no sound or picture. We
U have a solid green light from the LED power light indicator right?U have this DLP tv for awhile like two or three years,and use it alots right?Never change the lamp and the ballast right?Change the lamp and the ballast should solved ur problems.
Apr 01, 2010 | Samsung HLR5067WX 50" Rear Projection HDTV
I replaced the lamp bulbs and the TV worked fine for awhile but shut off after about three days of use. I unplugged it and waited awhile to plug it back in the timer light blinked for awhile and then went...
While it is suspicious happening so soon after lamp replacement, your main power supply may have failed. In earlier sets, these were problems that eventually happened.
Feb 15, 2010 | Mitsubishi WD-52725 52". Rear Projection...
Picture stopped, same pic stayed on for a while, sound went dead
Don't know how I did it. Shut tv off and left it off for awhile put it it back on and picture and sound were OK. Thank you for your concern.
Apr 05, 2009 | Hitachi 51F59 51" HDTV Projection...
No sound after a year. TV turns on by itself
I used your site to look up a problem awhile back and was helped by a guy who went by, Les Price (missiontracetv@msn.com).
I purchased a Sharp LC-26D4U LCD television and after about 16 month, the sound went on the TV. I could not get anything but popping noises out of the speakers. I hooked the TV up to a stereo and the sound worked only while using the stereo speaker from the stereo, still nothing from the TV speakers.
I searched this problem on your web site and saw a posting in which this Les Price (missiontracetv@msn.com) posted a fix. He stated this unit had a chronic problem with the insulator material used on the heat sink on the ic’s on the AV bd. He stated the unit had to be disassembled and the av bd removed. He stated the insulation on the ic 2502 breaks down and must be cleaned off and that a new insulator, part # PSPAZA663WJKZ must be ordered and used as the insulator pad. He stated there was a Sharp Technical bulletin LCDTV-194, which explained the problem and suggested this fix.
I Goggled the suggested part #, PSPAZA663WJKZ finding and ordering the part from www.electronics-storefront.com. I got a copy of the service bulletin, which had pictures and instructions on the repair.
On 25-Jan-09, I disassembled the TV, removing the back, a metal mount under the plastic back, and three circuit boards, locating the heat sink on the back of the AV board. I left the black sticky residue on the heat sink as the service bulletin suggested and installed the new insulator pad as shown on the service bulletin. I put the TV back together and found the TV volume to work again. I could not believe it worked.
Taking the TV apart made me a little nervous. I am not a repairman, however I do like to, “Tinker” with stuff. There were a lot of screws and wires to keep track of and a little tricky to put back together. If I had to do it again, I would either video tape the disassembly to make sure I replaced everything back the way it was, or at least take a few photos while disassembling.
I just wanted to say thanks for your web site and thanks to Les Price for his help. You both saved me some cash.
I have the same problem with the TV occasionally turning itself on but it only happens once in awhile. Still have not found out why this happens.
Dec 17, 2008 | Sharp LC-26D4U 26 in. LCD Television
Vizio L32 32 in. LCD HDTV Logo
208 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
