Question about Kenmore HE2 Plus Front Load Washer
The washing machine spins counterclockwise stops, makes alot of noise and sits there. It will do this several times spining slowly and then goes to fast spin cycle before cycle ends. Question is when it stops and just sits there and make noise I am not sure what it is doing. I am really starting to wonder about this washing machine. Any ideas?
  • Kenmore Master
  • 12,061 Answers
Http://www.servicematters.com/maytag_library/docs/16007803.pdf
Service and troubleshooting manual above.
http://www.washerhelp.co.uk/diy-repair-help.html
DIY self help washer repair website.
Posted on May 27, 2010
Kenmore 80 series spin cycle isn't spining water out
could be defective part or lid switch problem
Dec 10, 2013 | Kenmore Washing Machines
Wash machine won't spin all the time and makes a loud banging noise.
Check to make sure that your clothes are not piled to one side causing the load to be off-balance. If that does'nt fix it then, It may be that your machine has a balance stabilizer on it that has worked its way loose or even off.
Jun 11, 2012 | Frigidaire Affinity ATF7000E Front Load...
My lg washer shake s alot when it is spining and makes a loud noise please can you help
The washer needs to sit on a solid foundation for this to work. When the washer is spinning a load of clothes, push the corner of the washer till the noise or vibration quiets down. When it does quiet down, adjust the leg below to reduce the noise.
Good luck
May 26, 2011 | LG WM-2277HW Front Load Washer
Machine gets stuck between rinse ans spin and sits for a while then spins but wont stop, then **** from the in the machine or hose is on the clothes???? Any suggestions? Machine is a top loader smart drive...
You could try a hot load with epsom salts....this will clean out the machine....Make sure it is with hot water. It goes slow in between rinse and spin possibly because it is slow draining...clean out the pump. Also as it FILLS make sure the water runs in properly and not just trickle in making a hissing noise. Good luck. Tony the technician.
Apr 02, 2011 | Fisher and Paykel Washing Machines
WHIRPOOL WASHER LSQ9564MQ0 Started making loud
judging by the description i would say more likely the coupler
its a three peice part that sits between the mototr and transmission, kinda like a clutch,
anyway it is easily repaired
and available on appliancepartspro.com
type in your model number.....
look for motor coupler
Oct 13, 2009 | Washing Machines
I have a Kenmore model 42182 top loading washing machine which makes a roaring sound during the spin cycle. It works all actions during the wash portion so I don't think it is the transmission. I am asking...
your model should begin with a c110 or just 110. it sounds like you have a mounting stem and bearing problem. this can get alot worse as time goes on and is a somewhat costly repair. it involves taking out the entrie tub and replacing the critical center bearing and seal. you can check for fine particles of rubber at the base of the transmission as it has been ground down from the spining cycle of your machine.
Thanks.
Oct 10, 2009 | Kenmore 42182 Top Load Washer
Spining makes noise and machine vibrates a lot
its a simple solution just remove the brown colour clamp at the bottom of the machine with a screw driver
Jun 03, 2009 | Whirlpool Washing Machines
Excess water in clothes after spin cycle
Unblock the outflow pipe from the machine that goes into the sump under the sink. (have a pot ready for water overflow) This will help drain the water. If the spin cycle is making a screetching sort of noise then it is possible that the carbon brushes will need changing. This affects the spinning if the brushes are worn.
Nov 05, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Spin cycle doesn't work with loud noise
yea sounds like a bad motor coupling ( this machine equivelent to a belt).
Mar 06, 2008 | Whirlpool LSR7333 Top Load Washer
Kenmore HE2 Plus Front Load Washer Logo
109 people viewed this question
Sal DeAngelo
fordexpert
Mike Carew
