Question about RCA HD52W59 HDTV Projection Television
RCA hd52w59 out. Powerlight flashed 3x with chirp
RCA hd52w59 out. Powerlight flashed 3x with chirp for 3 reps. Replaced capacitors 110, cp150, cp114 and flyback. NOW chirp followed by 1 blink of powerlight for 3 reps. What am I missing?
  • 1 more comment
  • sandcrow95 Jun 06, 2010
    OK-
    replaced the horizontal output. Now the powerlight comes on...the chirping is gone. BUT, still no picture or sound. It's not hooked up to an antenna, but shouldn't the menu come up or something? Anything else I can check?
    Thanks
    the flyback was replaced along with the capacitors last week...that led to the recommendation for the horizontal output. Do you think that means the new flyback was defective, and we couldn't tell until the HOT was replaced?
    OK---
    Thanks so much. It's a solid light (doesn't blink) and stays on until I turn it off. I don't think we want to keep exploring and replacing everything, so I guees we don't need to spend more on this project.
    I had really hoped the flyback and HOT would be the cure. Oh well, your help is greatly appreciated!
    Thanks again
  • RCA Master
  • 8,617 Answers
Sounds like the Horizontal output transistor needs replacement.
Posted on May 27, 2010
Testimonial: "Appreciate the recommendations provided. Even though the TV didn't respond, the help was just what I needed."
  • 1 more comment
  • Sonny Berry
    Sonny Berry Jun 06, 2010
    The flyback may be defective since the New HOT solved the chirping. The flyback is the most likliest cause of the HOT needing replacement.
  • Sonny Berry
    Very unlikely the new flyback is defective. The deflection board may need replacement since the ITC222 xeries have many items that can cause the 3 blink , all the components are on the deflection board.
  • Sonny Berry
    Sonny Berry Jun 07, 2010
    Youre welcome. The ITC222 series do have a very poor reputation. Its also possible thatDL030 or DL031 may be defective along with CL031 which is the Horz. retrace capacitor. any of those three items could have also caused a blown HOT transistor.
I have a RCA d52w15byx1 when you turn it on, the power light flashes 3 times then goes out...what could be the problem?
Thats usually caused by failed power capacitors CP150, CP120 and CP114 you can get the RCA CP150 CP120 and CP114 re[pair kit from www.tvrepairworld.com which comes with instructions. That will usually solve the 3 flash issue.
Dec 10, 2011 | RCA P52926 52" Rear Projection Television
My tv model # D52w20 will not power on. The power button flashes on three times then cuts off. I have to constantly hold the button down for the tv to come on. What is the issue?
Bad CP150, CP120 and CP114 capacitors. You can get the RCA reapiar kit by that same name from www.tvrepairworld.com the kit contains the capacitors and the CD with repair instructions.
May 30, 2011 | RCA HD52W59 HDTV Projection Television
Turn on/off flashes three times then cuts off complety
sounds like the CP150, CP120 and CP114 capacitors. You can get the RCA repair kit by the same name from www.tvrepairworld.com the kit also contains repair instructions.
May 16, 2011 | RCA HD52W59 HDTV Projection Television
I have an RCA HD52W59. When I came home today, it tries to cycle 3 times and shuts off. There is no picture and no sound
Thats usually related to the CP150, CP120 and CP114 capacitors needing replacement. You can get the RCA repair kit by that same name from www.tvrepairworld.com the kit has instructions also.
Apr 19, 2011 | RCA HD52W59 HDTV Projection Television
When i power the tv on, the green power button lights up for a second, then shuts off with no picture
sounds like the cP150, CP120 and CP114 capacitors need replacement. You can get the CP150, CP120 and CP114 repair kit from www.tvrepairworld.com the kit contains the capacitors and the CD with instructions.
Mar 02, 2011 | RCA HD52W59 HDTV Projection Television
Rca hd52w59 tv. power light blinks three times in
Thats usually caused by the CP150, CP114 and CP120 capacitors which will need replacement. You can get that repair kit at www.tvrepairworld.com and the kit contains the CD with instructions for the repair.
Dec 14, 2009 | Televison & Video
Takes longer and longer to heat up and turn on
replace CP150, CP114 and CP120 capacitors. You can get replacement capacitors under the RCA parts category at the following link.
http://servicemanuals.vstore.ca/
Aug 01, 2009 | RCA HD52W59 HDTV Projection Television
Come on and goes off
3 bad capacitors located in front of deflection board cp150 cp111 cp114 they are green with gold writing on them if cp150 is bubbled up on top it is bad. 2200uf 16v. so replace all 3 capacitors.
Nov 22, 2008 | RCA HD52W59 HDTV Projection Television
RCA HD52W59 HDTV Projection Television Logo
337 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
