Question about Frigidaire FEQ332E Electric Dryer
Gas dryer Unit only get hot for a few minuets then cools down for the rest of the cycle. Gave the unit a good cleaning. The proublem continues.
  • Frigidaire Master
  • 43,501 Answers
Hi, If you have a gas dryerGas dryer Unit only get hot for a few minuets then - 2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
Gas dryer Unit only get hot for a few minuets then - 2_bing.gifour dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bingGas dryer Unit only get hot for a few minuets then - 2_bing.gifs= Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Posted on May 27, 2010
Hi, i have a whirlpool duet sport wfw8400tw03. When i run to normal cycle, it stop no error code no light. The washing machine just shut down. I can run it on delicate or sanitary.Is a balance trouble
if u can run it on delicate or fluff cycle with cool air more than likely its ur cycling thermostat or the hi limit thermostat going defective test it with a meter for ohms..
1. On gas and electric dryers that have an "Auto Dry" cycle, the cycling thermostat is often used to advance the timer as well regulate the drum temperature. Essentially, thermostat will alternately turn on the heat source or the timer motor when the temperature has been satisfied. To check this thermostat, you will have to check for power to the timer motor with a multi-meter, during a cycle. This is a live voltage test and caution should be used.
2. Some dryers will use a cool down thermostat to tumble the clothes without heat, at the end of the dry cycle. Power is routed through this thermostat to the drive motor to keep it running until the drum temperature has dropped to a specific temperature. If this thermostat fails it can cause the drum to turn indefinitely or until the door is opened. You can check the thermostat for continuity with a multi-meter. This test should only be made with the power removed from the dryer.
Lastly check the moister sensor for OHMS according to ur schematic as it must show a certain amount of ohms as per ur unit. When unit has been on short while
DRYER OVERHEATING:
Heating Element
A defective heating element can make a dryer too hot or not heat at all. . If the element partially shorts out, it can produce heat all the time, regardless of whether the dryer is calling for heat. Remove the heating element to inspect it. The coils should not be touching each other or anything else.
Other Causes and Conditions
Air Flow Problem
Dryers need good ventilation to work properly. If the vent is clogged it can make the dryer too hot. Clean all of the vent tubing thoroughly.
Cycling Thermostat
Although not common, a defective cycling thermostat can make the dryer too hot. The cycling thermostat is supposed to turn on and off the heat to maintain the proper temperature. If the thermostat is defective it may keep the heat on too long. The thermostat is not adjustable or repairable, it must be replaced.
HI LIMIT THERMOSTAT DEFECTIVE? SHOULD SHOW OHMS AT ROOM TEMPERATURE
Felt Seal
Most dryers have a felt seal at the front and rear of the drum to keep the heat inside the drum. If the felt seal is worn away or missing, the dryer may keep heating and make the dryer too hot. This is not common.
Blower Wheel
A defective blower wheel will not spin properly and will not vent the hot air, making the dryer too hot. Check to see if there is adequate airflow out of the dryer.
https://www.youtube.com/watch?v=3m5NZvY9V5Q
GOD IS still GOOD !!!! SO MY ADIVE IS FREE
Whirlpool Kenmore Dryer Won Heat Test Replace Heating Element 279838
Apr 17, 2017 | Whirlpool Washing Machines
Lg dryer dle5001w keeps running
Hay Donald , sounds like the relay on your control board is stuck closed .replace control board, good luck APPLIANCES R EN
Feb 28, 2013 | LG DLE5001W Dryer
I have Maytag dryer with Model No. LDG8424AAE. It
how long have you had dryer....have you ever had dryer cleaned out inside...it could be plugged up...chek airflow,disconnect vent line...feel if you have lot of air...or little....then it might be internal tstats problems.....check all this first.....good luck...
Apr 03, 2010 | Dryers
Hotpoint nvl333gyoww gas dryer heats for a few minutes, then no heat. Seals appear fine, door latch appears fine, not sure what it could be - suggestions? Thanks.
here are a few reasons that you will get heat for a few min and then no heat.
1. if the vent is cloged, anywhere in the flexable hose to the wall or from the wall to outside. If the vent is cloged the flame in the unit will widen and the thermostat hi limit will shut she burner off untill it cools.
2. The coils for the burner could be bad and will allow the burner to light a couple of cycles and then will get hot and internaly disconect the coil untill it cools down and then will repeat and will get worse over time.
The good news :) The ignitor is good if it lights a flame, If the flame burns for more that 10 sec then the flame switch is mostlikley good. The main valve in most cases will also be good.
Im using Model # NVL333GY0WW
Jan 13, 2010 | Hotpoint NVL333GY Gas Dryer
My electric dryer is becoming extremely hot during the drying cycle. I replaced a blown thermal fuse several weeks ago and the dryer was extremely hot at that time. The dryer runs but becomes so hot you...
Clothes will get very hot in the dry cycle, especially when the dryer is set to the warmest or hottest setting.
There are controls built into the unit to prevent it from overheating to the point of causing a fire. The thermal fuse you replaced is one of them (and I assume you replaced a perfectly good fuse with a new one as you said it was very hot.).
You might want to check the following if you feel the unit is getting too hot -
1) Make sure the lint screen is clean.
2) Make sure the hose between the back of the dryer and the exhaust duct at the wall wall is not kinked or full of lint.
3) Make sure the exhaust duct leading to outside of the house is clear and not full of lint.
Let me know what you find.
Dec 14, 2009 | Kenmore 62602 Electric Dryer
Heat shuts off after few minuets of running
Normal 0 Hi, You need to change the coils on the top of the gas valve. This is a very common problem with the newer gas dryers. We have them for $29.95 on out web site www.whilpoolpartssurplus.com
If I can assist you further on how to replace them, please let me know.
Thanks
Vic
May 24, 2009 | Dryers
Kenmore gas dryer starts to heat but does not maintain the heat. It cools down after a few minutes.
Something simple for you to try is: remove the duct from the dryer,run a cycle,IF the unit works fine, you will need to have your vent system cleaned to the outside. If you still have troubles, you will need to place a service call to have the unit diagnosed
Feb 19, 2009 | Kenmore 63942 Dryer
Dryer will sometimes start to heat, then stops heating altogether.
There are always more parts to replace. From the sounds of it though, it sounds like one of your gas coils are going out. Normal gas dryer opperation is your unit will heat up, cool down, heat up, cool down, etc thorugh the course of the cycle. Usually when one of your coils are going out, it sticks after the 1st, 2nd, or 3rd cycle and the gas will no longer come out. So the cycle will continue just without heat. Another less likely possibility is that you have a restriction in your ventalation causing one of your heat safeties to open and not let the machine heat for most of the cycle. This can generally be checked just by placing your hand under the vent hood outside where your dryer vents to. You should feel air pressure on your hand while the unit is running. If there is not pressure or you are hearinf some whisling noise, it might be restricted in which case you'll need to have your vents cleaned/ repaired. Now since you are going through an extended warranty company, here's a couple other thoughts. They contract companies to provide service to thier customers. Do they have another authorized company in your area that can look at it? Do they have any kind of lemon or excessive repair policy? Many companies will replace a unit after so many repairs in a given time frame.
Jun 25, 2008 | Maytag MDG7757AW Gas Dryer
LG Gas Stacking Dryer
The check filter light comes on every load to remind you to clean the lint filter. Cooling only happens when that light is flashing not when it's on solid. If this is a gas dryer check the exhaust hose and vent on the outside of the house. If it is blocked it will not let the unit get to the correct temp due to cycling.
Dec 16, 2007 | LG DLE2514 Electric Dryer
After a few heating cycles the burner does not ignite
The problem you are describing is usually associated with a bad gas valve coil. The dryer runs normally until it gets hot, then starts making a strange clicking noise. After it cools down, the dryer runs normally again. The gas valve coils (there are two of them) usually run about $20 a piece. I recommend replacing both of them at the same time just to be sure. I hope this helps.
Apr 15, 2007 | Maytag MDG3600BW Gas Dryer
Frigidaire FEQ332E Electric Dryer Logo
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
