Question about Samsung SF-565P All-In-One Laser Printer
No power. Unit seems dead. - Samsung SF-565P All-In-One Laser Printer
  • 315 Answers
Have you checked the fuse in the plug?
If you have then the internal power supply is faulty, this should only be repaired by an experienced technician.
Regards
Mike
Posted on May 27, 2010
All 3 handsets seem to be dead at same time. It seems odd that they would all go out at same time. Is it simply a battery issue? The answering machine part works fine.
Check the line using an old conventional plug in phone. You should always keep one for power cuts. Also, get someone to phone your number.
One a three handset system, the signal to all three are driven by the main unit, the bit with the answering system. Check that is plugged in to the mains wall socket and if it is, check for power at the socket. If that checks out, you need to check that little plug in power supply unit. Best way is with a test meter. If the lights are on on the unit and the answer machine works, then you know you have power at that unit, so you need to check the power supplies in the slave units.
My guess is that your line is dead to the house.
Dec 23, 2015 | Lands Phones
Why will it not turn on? the buttons seem dead
The unit is probably a few years old and the power supply has gone south..
Apr 30, 2014 | Audio Players & Recorders
Inconsistent power
If it's totally dead, the main fuse may have blown. However, since it was inconsistent before it went dead, it might lead me to think that you have a loose connection. Sometimes they heat, lose continuity, and then work again when they cool. A defective thermal protector might also cause this.
Dec 20, 2013 | Whirlpool WMH1163XVS Microwave Oven
Ainol Novo 10 Hero 10 won't turn on :( it appears dead :'(
Sounds like it is not charging.
The unit will power on momentarily if low batter but power off straight away
Get an electrical competent person to check the output of the power unit or use know good unit.
Dec 06, 2013 | Ainol Novo 10 Hero 10 Inch Tablet Pc IPS...
Seems to be dead .wont turn on when plugged into the cigarette lighter Garmin street pilot c 510
Before writing the unit off as dead I would try obtaining a new 12v power cable and maybe try your cable in someone else vehicle, often the 12v power in your car can short not providing power to the GPS.
Hope this helps!
Apr 13, 2011 | Garmin StreetPilot c510 Deluxe GPS...
Dimension 4400 Power Supply ** FREE ** (DE4400300WB) Power Supply: My Dell Dimension 4400 is dead with none of the 4 ...
It seems like it that you have a faulty power supply. Also the motherboard may be damged aswell, But most probably you can fix your PC by changing the power supply.
May 16, 2010 | Dell Dimension 4400 Power Supply ** FREE...
Hello I seem to have a dead console. It wont power up
The first thing you should try is another power supply/power outlet. If this does not fix the problem, then there may be a loose cable inside the unit. Contact Nintendo and see if the unit is still under warranty.
Feb 12, 2010 | Nintendo Wii Console
Seems to have no power.
check where wiring connects to machine,make sure correct voltage is present at connection block.also check for blown fuse at connection block area.
Oct 16, 2009 | Whirlpool GU3600XTS Dishwasher
Power light works when plugged in but will not power up
Your Charger Sounds like its dead,but dont worry it's a common fault with laptops etc..
they overheat,check the fuse in the plug before you buy a new one just in case.
GOOD LUCK...
Aug 09, 2009 | Acer Aspire One PC Notebook
Samsung SF-565P All-In-One Laser Printer Logo
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
CheckitRight
CheckitRight
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
