Question about Brother MFC-7420 Printer
Manual feed paper
The printer is asking for manual paper feed, how do i change this to feed from the tray?
  • 23 Answers
That's easy thing, you should right click on printer icon and in property, check that option, you will find that optop paper feed, change it from manualy to automatic.
Posted on Jul 11, 2010
MY PRINTER SAYS ...MP TRAY PAPER IS EMPTY DURING PRINTING
Put more paper in the Manual Feed tray to allow it to continue or change the settings to bypass Manual Feed Options.
Sep 12, 2014 | Dell 2355dn AllInOne Laser Printer
Our infoprint 1125 is on a ibm mid range computer system & is accessible to 9 users. when we print an envelope, the printer asks for a manual load of the envelope, how do i change this to automatic...
It's been my experience with these machines that envelopes are always fed through the manual feed tray.
The Tray 2 cassette's pick up assembly is different than the manual feed,
it has 2 rollers that have a wide area they can pick up while the manual feed has just 1 single roller.
If you remove the tray cassette and look under the printer you can see the two rollers, these would probably have a hard time picking up a standard size envelope.
Also the tray would have to path the paper up and would have to bend it through the paper path which can cause problems with the flaps on the envelopes.
Best method is to use the manual feed tray and to also have the back cover open so that the envelopes path straight through the printer without being curled.
(I've seen these in a ton of places ranging from small business to banks and they always have the envelopes in the manual feed)
Jun 08, 2011 | IBM Infoprint 1125 Laser Printer
Every time when printing there is a message MANUAL FEED, load paper and click continue
Please check your printer driver to see if the default tray is tray 2 or other than the manual feed tray and take the paper out of the manual tray.
May 03, 2011 | HP LaserJet 3200 All-In-One Printer
Does not print says manual paper feed
Try putting a piece of paper in the manual feed tray which is right above the paper tray, its a slot you have to flip open, sometimes on certain documents the margins are too big and asks to go into the manual feed slot.
Jun 15, 2010 | Brother MFC-7340 All-In-One Laser Printer
Brother 2040 printer blinking paper light - I open all of the drawers, took out and put the cartridge back in, played with the paper wheels and it won't stop blinking!
Hello ,
This is due to your computer software selecting the manual feed instead of tray one usually because the software program decides that the paper size is not the standard letter size, such as envelopes, and has to go through the manual feed.
If you are having trouble finding the manual feed, it is found just above the paper tray, usually on the front panel of the printer.
If you are trying to print a letter sized document yet the printer still asks for the paper to be inserted into the manual feed, then one of the settings in the software you are using needs to be changed.
For most windows based applications, you can find a “page setup” menu; in this menu, there is a section that specifies the tray being used to print from.
Make sure the setting in page setup is set to “tray 1” and not “manual”
Thank you,
Mar 29, 2010 | Brother HL-2040 Laser Printer
The printer ask for paper and then OK, but then
a friend helped out. A little piece of paper got stuck somewhere. Thanks for your assistance
Dec 16, 2009 | Canon PIXMA MP530 All-In-One InkJet...
Dell 3000cn keep getting load mpf when i try to print but there is paper in the tray. how do I get it to recognize the paper. I've changed nothing on the computer but this just started to happen! please...
I have a Dell 3010n myself, and a few times I did run into that "Load MPF" issue.
1.) Before printing a document, please check and see the properties. i.e. Kind/type of paper, which tray, or if printing envelopes or any other document than a regular 8 x11 paper. Putting all the tray and paper type selection on "Auto" can be very helpful.
2.) On the printer itself, there is a menu button where you can configure the type of paper, i.e. regular 20 llb. copy/print paper, glossy photopaper, thicker paper - after you place a fresh load on the paper tray and slide it in, usually it will ask you which type of paper you just loaded. Make sure it is the same settings as the document that you are trying to print: i.e. if document settings on computer was set to print on photopaper and you have regular paper on the tray, the printer will do a "Load MPF".
The paper sensor on it is amazingly (for a Dell, that is) sensitive and it can differentiate across a lot of paper types/thickness. If you have several computers and user across a network, and there are several paper-type settings done on the printer itself, this "Load MPF" issue will present itself more often.
In my case, it's simply because the person who recently changed the paper-type to glossy cover paper from some user who previously printed to a transparency forgot to revert MPF/Tray 1 to regular copy/print paper. Most cases, the printer setting on the PC has been left to print on to a transparency by default, so even if I stack the tray with copy paper to the hilt, it still will do "Load MPF".
Jul 25, 2009 | Dell 3010cn Laser Printer
Dell laser printer asks to change tray 1 everytime I print. I have updated the driver too and made no changes. It just started happening???
reconfigure the Printer's set up paper feed instead of auto change it to tray 1, also clean the paper feed sensor.(not the computer printer setup)
Mar 20, 2009 | Office Equipment & Supplies
Paper does not feed from Tray 1.
Check your printer settings.
Sometimes if your printer or the program you are printing from has the paper source set to "Letter" it waits for you to press the continue key on the printer which allows you to insert headed note paper before printing.
If it is set to letter, change it to A4 and this should solve your problem
You may need to change this in both the printer settings and/or each program from which you are printing
Jan 12, 2009 | Lexmark C532dn Laser Printer
Open Questions:
See all Brother MFC-7420 Printer Questions
Brother MFC-7420 Printer Logo
565 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
