Question about Emerson Black Microwave Oven
Will not run when you push start
The numbers beep when you push them they also show up on the window so you can see them. When you push start it acts like it is going to start but it does not.
  • Emerson Master
  • 9,085 Answers
This is usually caused by either a bad door switch, a loose door switch mount (which are pretty simple problems to fix) or occasionally a problem on the control panel.
Even though a door switch clicks, it may still be bad inside.
Door switch or mount trouble is usually caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
Sometimes it's a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under the bottom edge of the switch.
If the switch mount is broken, it's usually more economical and safer to add a dab or two of hot glue to the mount to secure the switch. Let it cool for about 30 minutes before using.
One test that sometimes helps is to gently lift up (and/or push down) on the door or handle as you try to start it. If it works or tries to work, then it's a door switch mount or door alignment issue.
If you only need a switch, you can order a universal type here for $5 postpaid.
If you think the problem is on the control panel, we repair these nationwide by mail for $39.95 postpaid in most cases with a one-year guarantee.
Posted on May 30, 2010
Reset emerson microwave
There is no reset button. You will need a control board.
Dec 13, 2014 | Emerson MW8102SS 1100 Watts Microwave Oven
Locked keyboard on a 1540tw
I guess your model number is GMV1540TW?
I think I answered this or a duplicate post already, but here goes:
The owner's manual covers that, but if for some reason you don't have yours, you can get it here.
To set child lock:
1. Press STOP/CLEAR.
2. Touch and hold START more than 4 seconds.
"LOCKED" will appear in the display window with two beeps.
To cancel child lock:
1. Touch and hold START more than 4 seconds.
"LOCKED" will disappear in the display window with two beeps.
Oct 06, 2011 | Goldstar MV-1502 Microwave Oven
Microwave beeps
HI. the touch pad is defective at this point. you will need to replace this damaged touch pad board asap. this will fix your issue.
Aug 24, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Galanz (french for ''****'') microwave is sporadically beeping
maybe, just maybe, there is an error code showing....and, most microwaves beep when a button is pushed too...LIVE WITH IT!
Jul 06, 2009 | Microwave Ovens
Giving -F3- display and beeping 3 times, does not respond
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
If that doesn't work, you have a shorted / failed membrane keypad.
Until it is repaired, please leave it unplugged or leave the door open.
If you (or someone you know) might want to replace it yourself, I have uploaded a handy guide with pictures showing you what's typically involved.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
If you would like to have us do this repair for you, we do that for $39.95 plus part costs.
Feel free to contact me directly (and please remind me of your model number) for more information & help.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Jan 11, 2009 | GE JVM1850 1000 Watts Microwave Oven
Emerson Black Microwave Oven Logo
87 people viewed this question
Top Emerson Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Jerry Greenberg
Jerry Greenberg
Are you an Emerson Microwave Oven Expert? Answer questions, earn points and help others
