Question about JVC KS-FX772
How can I set the clock on the MMCS in the 2003 Mitsubishi Grandis? Mine is stuck back in 2000. The panel in the centre console is all in Japanese (Japanese Import vehicle). It would also be helpful to get an explanation of the menus on the console in English.
WHY IS MY MITSUBISHI GRANDIS 2005 2.4L 4G69 ENGINE IS USING WAY TOO MUCH FUEL?
Check the ECT coolant sensor for sticking too low and causing way too rich of a mixture .
Aug 12, 2017 | Mitsubishi Cars & Trucks
How do I set the clock on a 2005 Mitsubishi Grandis?
Visit the on-line store, know as reliable-store, they have the repair manuals. I'm sure you will get the solution of your problem.
Best Manuals
Sep 06, 2016 | 2005 Mitsubishi Grandis
My key is dropping to bits.
If it is a remote like these, I got mine from these people. For the type with a key as part of the remote, they sell a blank key and an empty skeleton. You transfer the workings to the skeletal fob and get the key cut at a locksmith.
http://www.carandtruckremotes.com/mitsubishi-remotes.html
Mitsubishi remotes s
Mar 09, 2016 | 2006 Mitsubishi Grandis 2.0
Mitsubishi multi communication system screen is black, still playing music tho?
How to enter hidden service menu in Mitsubishi MMCS ...
? 2:59
https://www.youtube.com/watch?v=gnsmrfLmHK0
Jan 15, 2014 - Uploaded by mr-fix
If you have MMCS (Mitsubishi Multi Communication System) in your ... GPS antenna, touch sensor precision ...
Mmcs Mitsubishi Multi Communication System - Car Forums and ...
www.automotiveforums.com > ... > Mitsubishi > RVR
Sep 29, 2005 - I have a rvr and my screen on the mcs system is now blank. It first asked for the cd and then it went blank. I can see the cd turning but still ...
Dec 30, 2015 | Audio Players & Recorders
The multi display of my grandis do not memorize even the time that I have adjusted
There is a fuse for the clock memory. It gets constant system voltage even when key is off. Check your fuses, I'm surectou'll find the bad one.
Apr 15, 2014 | Mitsubishi Grandis Cars & Trucks
How do i change the navigation screen language from japanese to english in Toyota Avensis 2006
The irony of this is that the handbook is in English
For Toyota Avensis from 2003:
My console has a screen with a row of buttons below it and a centre mounted knob (the enter knob)
press Menu (1st left of knob)
select SETTING from navigation menu (on screen)
oddly you need to read the foreign language to do this one)
turns out mine was in german so not too hard, third down IIRC
select LANGUAGE from SETTING end press ENTER (knob)
again, I guessed which was 'language' by trial and error
select Km or miles press knob
leave well alone lol
Let's face it, if it was in English we'd not need the instructions, just time.
Good luck (you'll need it)
Aug 10, 2012 | 2006 Toyota Avensis 2.0
Cant find computer on my 2000 galant 2.4l motor
On earlier models, the ECM (also known as PCM & ECU) was located above the passenger side 'kick panel', hidden behind the glovebox.
However, on later models, Mitsubishi mounted the computer in behind the Centre Console (below and behind the ashtray area). You'll need to remove both centre console side panels.
The one you want, has a part number starting with: MR *****
Note: NEVER replace the PCM, unless your diagnostic codes codes confirm the PCM is faulty. Have your diagnostic codes read before disconnecting.
Cheers,
"Please take a moment to rate this solution with a 'testimonial' and/or 'thumbs up', as this will keep my status active and allow me to continue offering technical support. Thank you."
Jul 15, 2011 | 2000 Mitsubishi Galant
98 mitsubishi grandis chariot fault code 78 APS(main)
mitsubishi grandis 1999 low fuel, it starts but cut out
Jun 02, 2010 | 1984 Mitsubishi Starion
JVC KS-FX772 Logo
184 people viewed this question
Top JVC Car Audio & Video Experts
Radames Pagan
Radames Pagan
xxxxxx xxx
Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
