Is it Samsung HL-R5667W or any other model?
How old is this tv and did you replaced its lamp in last 2-3 years?
Let me know to diagnose possible cause of problem.
Thanks.
It is a model HLR5667W it was working fine and then all the sudden it just turns on and off all by itself the timer keeps flashing. No the light bulb has not been changed but the picture is ok the thing just wont stay on.
The Tv was purchased in 2005 the bulb was never replaced. If I time it just right and I hold down the power button where it is blinking timer the tv stays on and I can watch my show. When I let the button go it keeps turning on and off on and off on and off and it wont stop. I need some help please!
OK, please unplug tv from wall socket for minute or so to get it reset, replug back in and turn it On,
Do you hear fans run when you turn tv On?
So since 2005 bulb has not been changed, it seems bulb is reaching to end of its working life.
Please replace bulb in tv to get it back in business.
Yes I hear the fan working and I did unplug it for several minuits it did not fix the problem
OK, nothing is wrong in tv, just put new lamp in tv to fix the issue.
Current lamp is not dead/ broken yet but got weak in result because working hours life is limited of dlp lamp so it causing that symptoms.
Thanks.
The On/Off timer lets you program your television to turn itself on or off. You can use it as an alarm
to wake up, to help you remember important programs, or as a decoy when you're not home.
Press the MENU button
Press UP or DOWN button on the remote control hanset to ON/OFF TIMER
Make it OFF.
Switch off the TV by its front panel power button, and switch it ON again after 10 seconds.
OK.
