Question about Amana Heating & Cooling
My unit model # ap 148ds stop cooling, how do i fix
Can I purchase a plastic gear for a Apex AP a88 motor?
Apex Reclining Motor Model AP A88 ' eBay
m.ebay.com/itm/201272942152?cmd=VI_SPR
Apex reclining motor- model- AP-A88 in Home & Garden, Furniture, Sofas, Loveseats & Chaises ' eBay.
Jan 04, 2015 | Furniture
Manual for Arctic Cool Air Conditioner Model #AP-08CR1FACS
hi there...I am MiLi,
I've a question about this, because I've a similar problem.
My airco is displaying this code E2, and I'm wondering what it means.
I don't have the manual anymore to look it up. And the Airco stopped cooling, it is blowing warm or house temperature air.
It is set to cool, but blows warm air.
Is there someone who can help me out with this?
I just want to know what this code E2 means and what to do about it.
MiLi
May 26, 2012 | Danby Heating & Cooling
I have a carrier air conditioner model 38CKC024340 it cool the house sometimes, then a block of ice will form on the unit outside and it stops cooling, what could be the problem
Have you changed the air filter?
The 2 main reasons for frozen units in cooling mode 1. Not enough air flow. 2. Low on refrigerant.
You can fix #1.
#2 will require a service call.
Jun 02, 2011 | Carrier 38CKC024 Air Conditioner
My unit is avaya ap3 and the problem is all read lights appear and i dont know how to fix it. pls help me to fix the machine
Try rebooting the AP first. If there is a reset button press that, but that will erase the config.
Call in a pro to troubleshoot.
Aug 12, 2010 | Avaya Wireless AP-3 (700236946)
Mita 1860 copier, AP code. Motor won't stop cycling.
AP means ADD POWDER, the auger in the developer unit is probabaly clogged or you are simply just out of toner.
Dec 16, 2009 | Kyocera Mita Office Equipment & Supplies
My Avanti wine cooler, model WC3201D, stopped cooling
same problem, can not fix. Had a authorized service tech who said that you can not add freon to this unit, the only option is to plant flowers in it.
Nov 20, 2009 | Avanti WC3201D Wine Cooler
Hi, I got a AP-5131 with 4 antenna outputs in the
Greetings, It is entirely possible that it has a RAM error but again this may be part of the power spike problem. Its not unusual for RAM to be affected. I don't suppose it is connected into a power spike connector? It would be wise to invest in a good one with throwouts on all plugs and use it specifically for all your PC set up. I had two router/modems affected last year ( in summer) whenj lightning is not around one would think! But there is more lightning in summer than winter according to the Gurus's of weather.
I now have all sensitive items plugged into an expensive power board with double protection fuse/cutouts and so far all has been well.
If the unit is under any warranty I would be taking it back and just complaining that is stopped working suddenly, without explanation or intervention on your part. Let them replace it. Dont ask about spike arrestors in the same shop HAHA as they may suddenly refuse to exchange it.
Ram chips are not cheap anyway, and both chips could be damaged as well as internal componenents. I don't suppose you can smell any burn in the unit? (not always evident)
Cheers
Oct 12, 2009 | Symbol AP-5131
Reset to default a symbol spectrum24 ap-3021
On the Symbol Spectrum24 AP-3021 and what looks like all of the Spectrum24 AP models. There is not a reset button. We only have the RS-232 serial port to work with.
Start with the power off.
Short pin 2 and pin 3 together.
Plug in the power.
Wait 15 secs.
After the two network lights become solid.
Remove whatever you used to short pins 2 and 3.
(make sure to only jumper pins 2 and 3 - if you ground against the outer shield it will not work)
Cycle the power on the unit.
The password is Symbol and it is case sensitive.
Apr 09, 2008 | Symbol Spectrum24 4131 Access Point...
Copy Star 1505 error code
Toner empty.If You have new toner in Machine,and have AP error, call service because machine needs to be cleaned inside imaging Unit.
Nov 14, 2007 | Office Equipment & Supplies
Heating & Cooling Logo
46 people viewed this question
Top Amana Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you an Amana Heating and Cooling Expert? Answer questions, earn points and help others
