Question about Intermatic & Malibu& 300 Watt Power/Pack Timer
I have a Malibu 900W transformer for low voltage landscape lighting. There are three sets of terminals (300 watts each), but each set has three connections labeled A, B, and C. Why three connections when there are only two wires to connect?
Im looking for that same answer too ...
Posted on Aug 12, 2010
We have a Malibu 300 low wattage transformer for 13- 20 watt landscape lights.
Try connecting a lamp (correct voltage, etc) directly to the transformer. Most likely, the wire from the transformer to your lights is broken... The reset button can't reset anything, if there's nothing wrong there.
Jun 16, 2016 | Intermatic Malibu 300W Power Pack...
How do you program a da-150-12w-1?
150 Watt Transformer TDC Power DA-150-12W-1 - eBay
www.ebay.com > ... > Outdoor Lighting > Walkway & Path Lights
eBay150 Watt Transformer TDC Power DA-150-12W-1 in Home & Garden, Yard, Garden & Outdoor Living, Outdoor Lighting, Walkway & Path Lights ' eBay.
New Free SHIP TDC Power Da 150 12W 1 Low ... - eBay
www.ebay.com > ... > Outdoor Lighting > Other Outdoor Lighting
eBayNew, Free Ship, TDC Power DA-150-12W-1 Low Voltage Transformer, 12v 150watt Max in Home & Garden, Yard, Garden & Outdoor Living, Outdoor Lighting ...
[PDF]SECTION H - Etlin
www.etlin.com/pdfs/Outdoor_Transformers.pdf
1-800-661-9610 (Canada) 1-888-762-5384 (USA). OUTDOOR LOW ... DA-XX-12WSeries - 60 to 150VA Small Case Low Voltage Outdoor Transformers.
Da-150-12w-1 Manual ' downloadthingsfast.com
Dec 09, 2015 | Malibu Hardware & Accessories
I have a ML500TW timer transformer I don't believe they make it any mor can I replace it with a 600
Yes, use ML 600 with 5 year warranty.
Save receipt.
Copy following link for useful information about getting new power pack to last longer.
http://waterheatertimer.org/Malibu-power-pack-stopped-working.html
ML 600 will have 2 sets of ABC terminals.
Each terminal supports 300 watts.
Split lights between both sets of terminals.
Use 12 gauge wire. Maximum 75' length each wire.
Apr 15, 2013 | Malibu ML600TW - Low Voltage Power Pack -...
How to install Intermatic ML600TW
Copy following link for ML600 installation manual, installation tips, problem-avoidance, troubleshooting, replacement trippers, warranty information:
With the ML600, there are usually two sets ABC terminals.
Connect wires to AB terminals unless using photo eye.
Connect 300 watts to each set of AB terminals.
Nov 22, 2012 | Malibu ML600TW - Low Voltage Power Pack -...
Loud huming from my 300v low voltage lighting transformer
Transformers make humming sound.
ML300 series transformers make sound.
Used styrafoam to separate transformer from contact with building so sound is not carried.
These transformers have 10 year limited warranty.
Copy following link for general troubleshoot and tips, and warranty information, and trippers.
Oct 23, 2012 | Malibu ML300RTW - Low Voltage Power Pack...
I purchase a Malibu ML600TW. My quest is. In this unit are there 2 separate 300 watt transformer. or when you contact the line in you are wiring to 600 watts.
With the 600 watt ML series, there are two sets of a-b-c terminals. C terminals are used with photo eye.
Connect 300 watts of bulbs to one set a-b terminals, connect 300 watts to other set of a-b terminals.
I'm not sure what is inside the power pack. However if you run less than or more than 600 watts or let your bulbs burn out for any length of time, the power pack can burn out. Save your receipt for limited 5-year warranty.
For your benefit, open following link for more information on ML power packs, plus troubleshoot, plus tips to keep power pack from burning out, and links to trippers:
Upvote the help.
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
May 24, 2011 | Malibu ML600TW - Low Voltage Power Pack -...
My 600 watt 12 volt transformer timer for out door lighting does not keep time properly. HOw do I get and install a new timer?
1) Amazon sells 600Watt power pack:
http://www.amazon.com/Malibu-8100-9600-01-Voltage-Power-Transformer/sim/B002ZRPM4A/2
2) I bought new 300Watt Malibu power pack at Home Depot about 2 months ago.
Near the lighting section.
My new power pack has electronic time clock, so no more 'slow clock.'
I think Home Depot had 600Watt.
Lowes carries different brand.
3) Manuals for power packs at Malibu lights.com
http://www.malibulights.com/customer_service/owners_manuals.aspx
4) Tips for buying and taking care of power pack:
-Match up wattage of bulbs with wattage of power pack
-15 each X 20 watt bulbs = 300 watts, so install 300Watt power pack
-Installing a 500W power pack on 300W of bulbs will burn out bulbs and power pack.
-Replace bulbs as soon as they burn out or other bulbs will burn out and power pack will burn out.
-When working on bulbs, unplug power pack or it may burn out.
http://www.malibulights.com/guides_support/low_voltage_planning_guide/select_your_power_pack
5) How to install power pack.
Before unplugging old power pack, check which bulbs are not working.
Replace bulbs using phillips screwdriver.
Unplug power pack.
Notice how wires are connected to power pack, write down terminal connections.
Some power packs have three terminals ... extra terminal is for additional photoelectric eye.
Use pliers or screwdriver to disconnect wires.
New power pack has has same terminals.
Plug in power pack.
Read instruction manual before connecting wires.
Save instruction manual because a few years that manual won't be around as products change.
Dec 03, 2010 | Malibu Intermatic Inc. ML121RT Low...
Intermatic & Malibu& 300 Watt Power/Pack Timer  Logo
289 people viewed this question
Top Intermatic Hardware & Accessories Experts
Gene Haynes
Jay Finke
Jay Finke
Steve
Are you an Intermatic Hardware and Accessory Expert? Answer questions, earn points and help others
