Question about Jwin JCAM300 Webcam
How To adjust the color? My webcam is showing black
  • 2,841 Answers
If you have a dashboard ( toolbar ) with your webcam launch it and access the 'Settings' menu.
Failing that open the chat program you use and navigate to the 'Camera Settings' program (as if you were setting up the webcam again)
click the tabs and the sliders for colour - contrast - brightness should be revealed.
Posted on May 29, 2010
My webcam iball c8.0 is showing blurr images and is fully blurrr
Webcams are useful in both personal and business functions, from video chatting to video conference calls. When your webcam displays strange colors, it is usually due to a problem that is easily fixed even without advanced technical abilities. By trying at-home solutions before sending the computer or camera in for service, you can save time and money.
Lighting
Lighting is a common cause of strange webcam colors. When your webcam does not have enough light, it compensates by adjusting settings internally. The adjustments can result in color shifts that are not true to life. Bright, diffuse lighting reduces the workload on your webcam and allows it to display colors as they are. The light source should be behind the computer and pointed at your face to reduce shadowing and provide an even light. Avoid light sources behind you, as they can cause extreme contrast between your face and the light. b> Webcam Settings b> Most webcams come equipped with customization settings that allow you to adjust the display. Changing the settings while watching a preview webcam image can help you fix odd colors on the display. The location of the video settings varies, but is often located in the Preferences, Settings, Configure or Video menus. Adjust the tint, contrast and brightness settings until the image shifts to a normal color scheme. Webcam Drivers b> Webcam drivers allow the camera to function properly. When your drivers are corrupt or out of date, they can affect even the most basic display abilities. Webcam manufacturers publish the most recent driver downloads on their websites, usually on the individual product page, along with instructions for installation. To allow your computer to communicate with the webcam and use the drivers, run a software update to install any recent versions. b> Special Effects b> Some webcams come with built-in special effects that allow you to customize the appearance of the video stream. If an effect was enabled during the last session, it may stay on when the camera is turned on again. Turning the effects off will usually resolve the problem. The location of video effect settings varies by webcam model and manufacturer. Logitech Video Effects are located using the mask button in the QuickCam menu. On a Mac, effects for the built-in iSight webcam can be changed in the Effects 1 and 2 menus in the Photo Booth application. Hope this helps.
Jan 16, 2013 | Computers & Internet
Tip
Webcam only shows black & white in Windows 8
Note: I have Logitech webcams but since this is a Windows fix it will probably work with any brand that is having similar problems:
I recently upgraded my PC to Windows 8.1 and discovered that my two Logitech webcams would only display black & white (although snapshots were in color). I tried all of Logitech's advice but nothing worked. The Solution: Use Windows Explorer to navigate to the .exe file in the Logitech folder (in my case the path is (C) / Program Files (x86) / Logitech / LWS / Webcam Software / LWS.exe). Right-click the file and choose "Properties". Click on "Compatibility" and choose "Run this program in compatibility mode for Windows 8". Restart your webcam software and it should now have color. (PS: The system may sometimes default to the original settings, so you may need to repeat the above to get your color back.)
on Jul 17, 2014 | Computers & Internet
I have colour problems with my webcam! it doesn't show the colours properly, for instance, my blue shirt appears purple.
you might try to adjust your color profile through windows control panel,display. or when you open the control panel search for color profile
Dec 01, 2012 | A4tech A4-PK333MB WEBCAM 1.3M
My a4tech camera is PK-635K model, but the image is black and green color. How can i adjust the brightness?
In the open window box, select 'device' from menu then your model in the drop down menu.
Oct 03, 2010 | A4tech Xmaster PK-835 Webcam
Mic not working with msn
Start > Control Panel > Classic view > Speech recognition options - run through set up.
BODY,.aolmailheader {font-size:10pt; color:black; font-family:Arial;} a.aolmailheader:link {color:blue; text-decoration:underline; font-weight:normal;} a.aolmailheader:visited {color:magenta; text-decoration:underline; font-weight:normal;} a.aolmailheader:active {color:blue; text-decoration:underline; font-weight:normal;} a.aolmailheader:hover {color:blue; text-decoration:underline; font-weight:normal;} TEST SPEAKERS Right click on speaker icon in System Tray Select "Playback Devices" The speaker icon ( checked as working) and volume level graph should be visible Right click on the volume graph and click "Test" Left hand speakers followed by right hand should be heard
SET DEFAULT & TEST MIC Click "Recording" tab. Set required mic as default - click on mic font to highlight and click "Properties" In lower dropbox display "Use this device enable" click OK Click "Levels" tab and set slider to 80% ( adjust to suit later) Return to "Recording". Test mic by speaking and make sure volume graph displays Not working ?
Expand 'Imaging' folder in Device Manager and right click on your webcam text - Update driver software from internet
Failing this, uninstall current webcam software and download from here
http://www.logitech.com/index.cfm/405/&cl=us,en?prodcrid=405
WLM (MSN)
Open WLM > Show menu > audio and video setup > set mic as default and test > Next - set webcam as default > Finish
Sep 13, 2009 | Logitech QuickCam Pro 5000 Webcam
MSI starcam 370i only shows black and white
You can change your lighting to fluorescent lighting the brighter the fluorescent lights are the better your cam will show up the colours, it worked for me.
Aug 02, 2008 | MSI Starcam 370i Webcam
Black display
I dont know what it is. I have the same problem
Dec 19, 2007 | Philips J44414
Video Downloads and Webcam do not show in color...Only Black and white
There is an option in the Webcam properties for black and white.
1. Open the Webcam program.
2. Top right corner of the window click the "down arrow" button next to the minimize and maximize button.
3. Select "Properties"
4. On the right side of the window, under the heading "Extra Control", make sure there is no check in the box.
Hope this helps.
Dec 11, 2007 | Microsoft LifeCam VX-3000 Web Camera
Only black and white!
I have the same problem. I instaled the driver with lot of problems but I made it work. Only in (black and red).
Who can help us
Dec 09, 2007 | Logitech QuickCam Pro 5000 Webcam
Jwin JCAM300 Webcam Logo
170 people viewed this question
Top Jwin Computers & Internet Experts
Shawn DuRee
Avishek Samaddar
Avishek Samaddar
Pramod Kumar
Pramod Kumar
Are you a Jwin Computer and Internet Expert? Answer questions, earn points and help others
