Question about RCA P46924 46" Rear Projection Television
Blurry picture I just got this tv from a friend. it was built in 2000. he replaced the front control panel board on it a while ago, but the picture is blurry. Words are really bad to try and read. is there some kind of adjustment for this?
  • peralta_rifa Aug 02, 2008
    my tv seens blurry. It seens to curve in.Ive tryed to adjust the projecter with the manu bu i seens it does not ddo much. What is wrong with it?
    Sergeant:
    Champion:
  • 301 Answers
You can try to clean the mirror and lenses. or try to adjust the focus for each CRT(picture tube). also could be a convergence alignment issue. check the main menu for convergence alignment feature.
Posted on Apr 10, 2008
Vizio picture
you may have a dry joint on the screen controller board or a lose connection on to the screen. clean the board on the back of the screen. but take it out first and clean the copper parts on the screen cable.
Sep 15, 2013 | Televison & Video
Westinghouse Flat Screen Goes Blurry/has Scrambled Picture
tried first with re seating the lvds cable in the t-con board, the t-con board is mounted covered with metal shield. if can get with fixing the cable, then your t-con board has defective component parts.
Aug 13, 2012 | Westinghouse Televison & Video
#1 tv has black horizontal line middle of screen, fades away about 80% of the way from right to left. #2 picture is blurry and the colors stretch down in horizontal lines, then picture goes back to...
The tv board that called a T-CON board it is dying to causes these problems.All the tv pictures dots pixel codes go through this board before it show up onto the tv LCD sreen panel.This tv T-CON decodering board sit in the midle at the bottom of the tv LCD screen panel.Tries websites like Shopjimmy.com,Ebay.com to buy a whole new refurbish T-CON board for the replacement.
Sep 04, 2011 | Sony BRAVIA KDL-46W4100 46 in. LCD HDTV
42" sony projection with blurry picture
Remove front bottm panel and behind it should be the Focus/Screen control block replace it.
Mats 1-800-628-1118
May 09, 2010 | Sony KP-51HW40 51" Rear Projection...
Static electricity fried the button panel
static electricity can damage the chips on the boards. it all depends were the static voltage went to, if it was just to the buttons controller board or to the main av board. you could need new button board or you could need to replace the main board and the button board its hard to say with static shock.
Jul 11, 2017 | Emerson EWL3706 37 in. LCD Television
The screen looks out of focus and the top and botton bend inward.
Remove front bottom panel behind it is a small black control box top controls are focus controls for R/G/B and Bottom 3 controls are your screen drives adjust one at a time turn off G/B adjust red first,then Do Green and Blue fter adjusting focu to each tube leave them set then adjust screen drive turn color off adjust RGB for a Black and white picture get as close as you can then turn color back If after doing this you still have blurry looking picture look down into Tubes you should be able to see picture clearly in each one if you cannot see picture then projection Fluid need to be changed out. Call Mats 1-800-628-1118.
Sep 26, 2009 | Sony KP-53S65 53" Rear Projection...
Blurry tv
there is a focus control in the front of the set behind the front grill there is a door in the middle attached by screws take this off and it should be right behind it. There are six controls on a little box one row says focus and the other says screen don't adjust the screen controls. In some cases these are in the back of the set.
Aug 07, 2009 | Sony KP-65WS500 65" Rear Projection...
Blurry picture
It really depends on your level of expertise. Usually this is technically a very involved repair
Mar 13, 2009 | Televison & Video
Picture flickers in and out rapidly,gets blurry for about 5sec then looks like new for about 5sec then back again
Did you replaced 2 IC convergence as well or just 2 resitors 3.9 ohms ? if you did replaced 2 IC then you might have probelm in convergence drive it is1 of the PCB mount vertical on the left side from the rear view under part BP95-00415C you need to readjust the convergence by using your remote control just follow in the servive manual
Nov 22, 2008 | Samsung HC-P4752W 47" Rear Projection...
RCA P46924 46" Rear Projection Television Logo
121 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
