Question about Sony FD Trinitron WEGA KV-36FS120 36" TV
Stand-by light blinking 7 times, wont turn on
This has been happening for a couple of years now, and has typically been temporarily resolved by turning off the TV and unplugging it for an extended period. Is there a quicker fix?
  • 1 more comment
  • jmc7285 May 27, 2010
    Probably should add, its a Sony Trinitron HD TV
    Yes, that is the model number. I have seen several times that it is a high voltage failure and something to do with the horizontal circuits...I don't have a lot of technical knowledge about televisions. If I leave it off for weeks, it will probably work again, but I don't want to wait that long.
    Any idea how much something like this might cost? A range, even?
    Thanks so much for the assistance!
  • 4,234 Answers
The 7 blinks is a diagnostic code. Please confirm that the model number is KV-36fs120. The diagnostic code is unique to each model. The fact that a power down would "fix" this if long enough, indicates that this is likely a heat sensitive part. I would geuss that the problem is on one of the power supply circuits. Please confirm the model number and I'll provide additional details.
Dan
Posted on May 27, 2010
  • ABRsvcs May 27, 2010
    If you can solder, try looking for poor solder connections around the flyback transofrmer and/or the horizontal output transistor. If the set still "recovers" by letting it sit for a while, the poor connections may be the only problem. If the solder connections are good, then the next likely suspect would be capacitors or hte regulator IC. The labor rate for a repair like this is location dependent. If the picture is good, I'd spend $150 or so for a repair. Much more than that amount and you can get a replacement 42" LCD for a little more.
    Dan
  • 315 Answers
Just a guess but could the be classed as a power save mode?
You could try pressing the stand-by button on the tv for about 10 to 15 seconds and see if it makes any difference.
I'm not sure if it will but I've been having to do the same thing on some NEC monitors I've recently been installing.
Sorry if it doesn't help.
Regards
Mike
I have a Hisense led tv model F39V77C.
Yeah, replace the set since it appears to be trashed. But if you have a few bucks lying around you might want to try replacing the unit's power supply to see if that resolves the many issues you have.
Jan 03, 2017 | Hisense Televison & Video
Tv not coming on has a blinking power button
Toshiba CX36F85 36" TV Blink - Questions - Fixya
www.fixya.com > ... > Toshiba > Toshiba CX36F85 36" TV
Toshiba CX36F85 36" TV, blink related issues. ... Every brand TV will have its ownblinking ... stand by light blinks 6 times, wont power on tv is only 4 years old. ...From the number of blinks occur at one time switch ON, you can get an idea ...
Toshiba CX36F85 36" TV Blinks - Questions - Fixya
Toshiba CX36F85 36" TV, blinks related issues. Get free help ... Every brand TV willhave its own blinking codes. From the ... Push power button and it ... and then ... stand by light blinks 6 times, wont power on tv is only 4 years old. Junk! it wont ...
Toshiba power light blinking not turn Standard (CRT ... - Fixya
www.fixya.com > ... > Standard (CRT) Televisions
Jan 10, 2016 | Toshiba CX36F85 36" TV
Sony kv36hs500 tv, suddenly no power, no standby lights, no sound
U check the power source?Take the tv aparts,check or replaced the power fuse,might get lucky.Not,than sorry,this tv can't be repair,without replacing electronic's componnents parts.Hire the same shop to do the repair.Ur tv power ICS inverter are dead.
Jun 15, 2010 | Sony FD Trinitron WEGA KV-36HS500 36" TV
KV32XBR450 no picture and blinking stand By light
Typically, 4 blinks mean "Vertical Deflection Stopped." Chances are that you have a problem on the D board.
Nov 19, 2009 | Sony Televison & Video
Tv wont come on and a red light is blinking. I have a Sony Wide screen projection TV model kp-46wt520
Can you unplug the TV for about 15 seconds, and then plug back in and watch the stand-by light. Tell me how many time the stand-by light blinks in regular intervals. If it doesn't blink at all, you need to change a fuse on the g-board. Once this is done run back through the stand-by blink light process, and more troubleshooting can be done if problem isn't already solved. If the stand-by light just keeps blinking with a count over ten just tell me, and I'll look for other possibilities.
Oct 25, 2009 | Sony KP-46WT520 46" Rear Projection...
Sony KV-34HS420 shuts of and stand-by light blinks
  1. Turn off the television. IMPORTANT: For a projection television that uses an internal lamp, wait 5 minutes after turning off the television to allow the lamp to cool before continuing with the following steps.
  2. Unplug the television power cord from the electrical outlet.
  3. Let the television remain without power for 60 seconds.
  4. Plug the power cord back into the electrical outlet. NOTE: If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.
  5. Turn on the television.
If the issue is still unresolved after following all of the troubleshooting steps, service may be required. Please note the number of times the STANDBY light flashes and relay that information to the service center.
Source
Sep 01, 2009 | Sony FD Trinitron WEGA KV-34HS420 34" TV
My sony wega keeps cutting off then coming back .
a couple of years old can be a long time:
has the TV been on 24\7
It's the amount of hours that matters..
electrolytic capacitors typically last 3000 to 5000 hours....
Special "long life" caps last close to 7000
but the caps in most consumer electronics, even broadcast equipment 3-5K hours.
Jun 16, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony trinitron
The standby light should be blinking in a pattern. Count,pause,count... Please post the count and that will indicate the circuit in which a problem was detected. That will allow me to give you details and possible solutions.
Thanks,
Dan
Oct 02, 2008 | Sony FD Trinitron WEGA KV-24FS120 24" TV
Sony Trinitron XBR, Stand By Mode?
The 6 or 7 blinks usually indicate a problem in the horizontal circuit. Since the TV recovered once, the problem is most likely to be a bad solder connection in that area. If you can solder, resolder any connections on the board that appear grainy or have rings. That may resolve the problem. If not, update this and we'll look elsewhere for defective parts.
Dan
Sep 16, 2008 | Sony FD Trinitron WEGA KV-36HS500 36" TV
Stand by light blinks 6 times, wont power on
Here you find sony blinking codes
SIX Blinks---No Horizontal (H STOP), no raster, goes to the blinking selfdiagnosis
function immediately. Check C515 & 516 and the jungle IC, IC206.
SEVEN Blinks---High voltage shutdown. The high voltage has exceeded 33k
and the unit goes immediately into safety shutdown. Check power supply
regulation and horizontal circuits.
Aug 10, 2008 | Sony FD Trinitron WEGA KV-36HS510 36" TV
Sony FD Trinitron WEGA KV-36FS120 36" TV Logo
130 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
