Question about Yard Machines 158cc Push Lawn Mower #11a 034f200
My mower starts up and dies.
I just replaced the spark plug so that's not the problem.
  • Yard Machines Master
  • 7,482 Answers
Sounds like you will need to clean your carburetor.
Sometimes you can get by with priming it a few times, and letting it
run a few times like that and it will flush the gunk out of the jets,
but most of the time you will need to rebuild the carburetor.
If the mower is over a couple years old, then I also recommend that you
buy and install a new carburetor repair kit, because the diaphragm will
get hard and that will cause it to be hard to crank.
When you clean your carburetor and remove the jet screws, count the
number of turns it takes to seat the jets from their original position.
That way when you go to put the jets back in, you know how many turns
they were in/out.
Please do not forget to rate me, Thanks
Good Luck, I hope this helped
Posted on May 27, 2010
Mower will start, but when I release starter, mower dies
Check your Spark Plug. I had this issue and after replacing it, started fine! Check your OIL level too.
Jul 24, 2015 | Garden
Why does my briggs and straten model 313-707 hard start then dies after a few seconds when it is running it acts like it's starving for fuel replaced fuel filter fuel cap and cleaned carb
Try replacing the plug.could also be a spark problem from the coil .you can purchase a spark tester which you can fit between the plug and lead .pull start mower and watch if spark is good.if ok then get a can of carby clean start mower and spray carby clean spareingly while running and if it keeps going the fuel is the problem
Aug 14, 2014 | Garden
Mower will not start
Hi, check that you are getting a spark at the spark plug 1st. Also check that you my have an air lock in your fuel pipe.
Apr 21, 2014 | Craftsman Garden
Weak spark
pull flywheel and replace sheer key on flywheel to get spark on time
Feb 23, 2014 | Garden
Snapper mower 331416kue won't start
You can try buy a new spark plug and replace it with the old one.
I had the same problem!
You just have to keep pulling until it catches!
Or maybe it's the carburetor that needs to be replaced!
I had the same problem wih my scooter.
I just changed the carburetor and it worked fine :)
Sep 08, 2012 | Garden
Lawn mower will not start. I changed spark plug, gas is in the mower and oil, mower still does not run
If your mower will start when you prime it, and then it dies right away, you have a carberator pluged. If after primeing the mower and it will not even start for a few seconds, you have lost spark. If you have no spark, this can be cause by two things. First, the magnito could have gone back, but this dosen't happen to often, but it can happen. First, check to see that the cable from the brake handle has not stretched. This controls engine brake and its also the kill switch, which kills the spark. Get acess to your engine brake, and you will find a wire connected to a tab. Remove this wire and try to start the mower. If it starts, replace the control cable. If it dosen't start, hook the wire back up and replace the magnito. I hope this is of some help
May 05, 2010 | Garden
Mower was working fine then engine coughed and died. Plenty of fuel but can't get it started again. Any suggestions?
Ckeck the spark plug cable and make sure it is tight on the plug. You did not say what kind of mower but some have low oil shutdowns. Make sure the oil is up to the full mark. If neither of these items solve the problem check the spark. If there is good spark remove the air cleaner and squirt some gas into the carbburator and try to start. If it runs then dies you know it is a fuel problem.
Dec 03, 2009 | Garden
My mower starts and runs great when cold but dies when hot. It will restart but won't stay running until it cools off again.
How old is your mower ? Sounds like points and condensor if older model ,or ignition module if its newer , points tend to stick together when they get old causing no spark at plug when they cool they come appart allowing it to spark again , module is sort of the same except you have no way of replacing points you have to replace module .
May 11, 2009 | Garden
Yard Machines 158cc Push Lawn Mower #11a 034f200 Logo
473 people viewed this question
Top Yard Machines Garden Experts
Phil Walker
Phil Walker
Dean Gruber
Tim Whalen
Are you a Yard Machines Garden Expert? Answer questions, earn points and help others
