Question about Kenmore Single Room Air Conditioner
Temp setting way off kenmore 580
Temp set at 60 degrees. Unit discharges 40 deg air. Unit cycles off after 3 to 4 mins and maintains approx 68-70 deg in a small room. Thermostat must be faulty. Where is it located and is it easy to replace. Unit is relatively brand new, used 2 seasons
Thanks for any help Bob V
  • 6,927 Answers
Remove the window unit and dissasemble,and clean it out,careful not to bend the fins on the condense and evaporator,but clean them out,and the inside of the unit also,then see what happens,if the problem persist,then find the probe on the evaporator and move it away from the evaporator until the compressor stays on longer.
Posted on May 27, 2010
When set to heat it blows out cool air.
Chances are your portable unit is a reverse cycle unit...If so, the leaving air temp in heating mode is not usually much warmer than room temp with 85 degrees F just about the maximum under PERFECT design conditions. A small portable in a large cold room may only be discharging 75 degree air, which is going to feel cold.
If your unit is NOT a reverse cycle unit, the heating source (probably electric resistance) is either not coming on at all or a portion of it is not coming on due to a defective element, burnt wire or a control issue.
Jan 08, 2015 | Amcor AL10000EH Portable Air Conditioner
I have recently installed 1Te Voltas 2 star A.C. I need clarification on the following 1) In cool mode, what is system of auto cut. Suppose I put on remove temp 27deg C. Temp of the room goes up to 26 deg...
Dear Mahesh
In Cool Mode
Temp Diff - + - 1 deg C in Room Temp & Set Temp
This is auto cut
In Dry Mode
Comp Runs for 10 mins then get off for 5 mins then again get on for 10 mins this cycle continuues.
Oct 15, 2013 | Whirlpool ACQ158XP Wall/Window Air...
My E123CS55GS Electrolux Side by Side Refridge is not working on the refridge side. The "High Temp" light came on, so I 1) checked the door to ensure it was closed tight, 2)Checked Fridge setting- Set at...
when temperture is droping its a good indication it fuctioning properlt but when the refrigerator doesent go down to the desired temt of 37 you may have to clean the coils in back of the refrigerator this can be done easily as it worked for me you can use a aircompresor to blow any heavy dust the unit has acummilated or you can use a soft brisle brush even a tooth brush is good in hard to reach areas.
Sep 09, 2013 | Electrolux EI26SS55GS Stainless Steel ...
Freezer is at 0 degrees and my fridge is at 60 degrees
Keep 3 to 5 degree temp setting. And check defrost cycling is properly done. Due to frosting formed behind the freezer could restrict the function freezer fan which throw freeze air to refrigerant compartment. Unplug fridge till defrosting all frosting, and then plug it again. Thanks.
Feb 05, 2011 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
I have a 18000btu LG mini split heat pump installed about 1 year ago in vacation home. In heat mode the unit cycles on and off when room temp is within 2-3 degrees of set point. Cycle on time varies...
Hello.I think they are on to something with shortcycling on temp sensor.I think it should be sampling the return air instead of (inside coils ?).A 2*f dead band use to be built in (factory installed) to thermostats to prevent on/off, but not sure in this case.Try a new sensor location(return air) and see if anything changes.
Oct 26, 2010 | LG LS-L1210CL Mini Split Air Conditioner
Need to adjust oven temperature on a Croley gas range
you shouldnt need to adjust the burners for a temp problem.
the control has a built in calibration setting and it should be described in your owners manual.
if you dont have the manual, then try to set the oven temp to max, 550, and then hold the bake button in for 10 to 30 seconds. after that it should beep and show you a 2 digit number like 00. that is the calibration mode, then you can adjust it up or down +/- 35 degrees. try to make a small adjustment first like 10 degrees and see how it bakes.
if it takes too long to bake, then use + degrees, if it is burning things then lower -10 degrees.
hope that helps you.
Jan 03, 2010 | Crosley CE35100AA Electric Kitchen Range
Odd operation
This unit is a sanitizer, not a full fledged dishwasher. It is designed for restaurants and bars where the primary use is washing glassware. The behavior you describe is normal for this model. The manual can be found at the following link:
https://feg.hobartcorp.com/resourcecenter/ProductDocumentation/F34779%20Rev%20B.PDF
Jun 15, 2008 | Hobart 24 in. LXIH-3 Built-in Dishwasher
Freezer works ok.refrigerator temp varies from 39 deg.to 60 deg.
check to see if there is frost in the back of the freezer if so you have a defrost prob..
Jun 20, 2007 | Kenmore 44109 / 44102 Side by Side...
Kenmore Single Room Air Conditioner Logo
173 people viewed this question
Top Kenmore Heating & Cooling Experts
Dan Webster
Dan Webster
Ronny Bennett Sr.
Ronny Bennett Sr.
1STHVACMAN
Are you a Kenmore Heating and Cooling Expert? Answer questions, earn points and help others
