Question about Maytag MSD2756G Side by Side Refrigerator
Refg warm frezzer ok
Evap frozzen, fan runs, defrost heaters replaced about 18 mounths ago, manual defrost works for about 4weeks I think its the defrost timer
  • Maytag Master
  • 1,606 Answers
To check the defrost circuit , unplug the refrig and inside the refrig section at the top
about 2" in from each side in the back , there are "D" slots to put a finger in , and pull
downward and foreward , to remove the control panel cover . Once removed , there is a 1/4"
screw on each side holding the adjustment indicator panel on , 1 phillips screw behind both
light bulbs , and 1 screw holding the complete panel to the rear wall . After removing these
5 screws , at the top right corner , with about 6-8 wires going to it , is the adaptive
defrost board . Sometimes you can see the electronic board and on newer refrig's , a white
box will be seen. Inside this box , is the adaptive defrost control . Disconnect the plug
going to the board and on the right side of the PLUG , the far right wire is yellow , then
another color , then white . Useing a small insulated wire with both ends stripped , insert
one end into the yellow wire hole and the other into the white wire hole . This will bypass
the adaptive board and send power directly thru the defrost bimetal ( thermostat ) AND
heater to check if they are good .Plug the refrig back in . Now , wait about 3-5 min and
look for a red glow at the bottom of the inside freezer panel , which will be the defrost
heater or listen for sizzling which will be the frost melting and dripping onto the heater
.If NO red glow , watch for a spark while removing the jumper wire you installed , from the
plug . If a spark IS seen , then the heater was on and the heater AND bimetal are good . If
you see the red glow , hear the sizzling , or see the spark , then the adaptive defrost
board should be replaced . If no glow , sizzling or spark , then unplug the refrig and
reinstall the refrig control section .
Remove the food in the freezer section enough so that the 2 screws holding the lower freezer
panel on and the freezer panel , can be removed . Remove the panel . If the heater (black
element at the bottom of the coils ) wires are visible , trace then to the top of the coils
and disconnect . Use an ohm meter to determine if the element is good . If the element IS
good , at the top of the coils , is a 1" cylinder with 2 wires , clipped onto the coils .
This is the defrost thermostat ( bimetal ) . Replace this part if the element shows good .
If the element shows bad , replace the element . NOTE 1 : sometimes the element and the
bimetal come wired togather and the replacement part comes with a new heater and bimetal
already wired togather . This would be the adviseable replacement part . However , each part
can still be replaced individually . NOTE 2 : If looking at the bimetal and the top plastic
" cap " looks cockeyed , replace the bimetal as moisture has gotten inside and disturbed its
designed function .
Posted on May 27, 2010
Refrigerator running but not cooling
Is the fan running in the back compressor area?If not check voltage at the fan if there replace fan motor.[Condenser motor] Is the fan running in the frezer compartment if not check for voltage at that motor if voltage there replace motor[Evap motor]
Is their frost on the frezer back wall,in side the frezer compartment? if yes its a defrost problem.Use volt meter to check continuty on heater and term.thermostat [It must becold below 20 degrees to check term thermo.if those 2 ok its defrost timer
Nov 26, 2012 | Refrigerators
GE Profile Side-by-Side running warm
If it's cutting off at too high a temperature it is a good possibility the probe is faulty. However if the compressor is not cutting off at all, suspect short of gas.
Apr 24, 2012 | Refrigerators
My freezer is working but the refrigerator is warm
Check to make sure that the evaporator fan is running. If it is you will be able to hear it. If it isn't replace the evap fan located behind the freezer wall. If it is running see if there is a lot of frost build up on the back of the freezer wall. If there is you have either a bad defrost timer, defrost t-sts=at (attached to the evap coils), or a bad defrost heater. Use a hair dryer to melt all of the ice and the cooling will return for few days till you can repair it. Hope this helps.
Mar 29, 2010 | GE Refrigerators
My frezzer side is working ok but the fridge side is warming up now at 15 cant lower the temperature
I would check the defrost timer. Most of the time when you are having a problem such as this, it is due to frost/ice accumulation on the evap coil, due to a faulty defrost component. Start with the defrost timer and work from there. Hope this helps
Sep 22, 2009 | Samsung RS2630SH Side by Side Refrigerator
FREZZER IS COLD FRIDGE IS NOT
OK, Sounds like we have a problem with the defrost. Need to unplug and lets remove the rear panel and examine the defrost heater, It has a glass tub around it so it will be easy to see if its burned out. WR51X10101 Defrost Heater if you need to change the defrost heater it would be a good idea to replace the defrost thermostat also. Part number WR50X10054 Defrost thermostat. Let me know if I can be of more help. And please rate my solution, Sea Breeze
email appliancepartsse@yahoo.com
http://servicepartstec.blogspot.com/
http://appliancepartsse.blogspot.com/
http://appliancepartseast.blogspot.com/
Aug 12, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
My fridge is warm, the frezzer is cold but not freezing. what could be wrong?
Hi, Look inside the freezer and see if there is frost building up on the rear panel inside. If there is frost, Remove the rear panle and check the defrost heater and bi-metal switch (must be tested while cold) for continuity, If either of these switches show an open circuit, replace it.
If these parts test ok, replace the defrost timer.
Other things to look for, make sure fans and compressor are running.
Please let me know if this helps or if I can assist you further.
Vic
Jul 01, 2009 | Kenmore 64802 Top Freezer Refrigerator
We have side by side kitchenaid refrigerator. The problem is the freezer side is working, but the vents in the other side (refrigerator) does not blow air. I think the diffuser is not working. Is that...
most likely defrost problem, check for evidence of frost on back of freezer panel, remove evap cover if nec. Make sure evap fan is working, if not, test for power to evap fan, if none, replace. if defrost problem, ohm out heater and defrost thermo, if either open, replace, if not, check defrost timer. If in defrost no power to heater or thermo, replace timer.
Jun 25, 2009 | Refrigerators
Compressor not working warm fan inside frezer run
Heat exchanger was iced over, took a hair dryer and melted ice. I think defrost heater element is bad will check it this week end. I put a new computer in the frige about 3 mounths ago and will check if it has gone bad. The compressor is working fine.
Jun 03, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Fridgidaire 18 cu new defrost timer and evap fan stil freezes
Did you replace the timer with the correct one for your refrigerator? If so you may need to check the defrost thermostat out.
Mar 26, 2009 | Frigidaire FRS3R5EMB Side by Side...
GE Model PDS22MBRABB bottom mount
These fridges were made by LG they are very problematic, the defrost cysle does not work properly due to board defects and the fridge freezes up, I have replaced my board twice and the fridge has worked properly for 6 months max them the board shorts again, I talked with the LG rep he said scrap the fridge they are ****.
Nov 06, 2007 | GE Energy Star PDS22SIS Stainless Steel...
Maytag MSD2756G Side by Side Refrigerator Logo
178 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
isaac johny
isaac johny
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
