Question about Health & Beauty
Mocom exacta what is message "ALARM 3 and 8" and how do I fix these problems?
  • 776 Answers
Please provide model no. of the Blood pressure monitor to provide a resolution.
Posted on May 27, 2010
  • helen479 May 27, 2010
    hi the medical device is a sterilizer/autoclave
Which fuse disarms the theft alarm system on a 2003 Saab 9-3 convertable?
Taking out the alarm fuse will cause the engine to never start. Try locking and unlocking the driver's door with the key to see if it resets. If not then service the alarm system.
Dec 22, 2016 | 2003 Saab 9-3
IRC4080i printer. How do I correct error code E000007-0001?
Error Codes Relevant to Fixing/Pressure Belt Displacement Control
E007 Fixing belt displacement error
0001: Upper belt displacement fault. (Either the upper belt full displacement or the belt displacement sensor
fault.)
0002: Lower belt displacement fault. (Either the lower belt full displacement or the belt displacement sensor
fault.)
0101: Upper belt HP detection error.
0102: Lower belt HP detection error.
Note:
Adjust the fixing/pressure unit HP with the following service mode at the installation or when replacing the
fixing (pressure) belt.
COPIER > FUNCTION > FIXNG > FX-UHP-S
> FX-LHP-S
Points to Note When Replacing Fixing Unit
By executing the service mode, the alarm code is closed and the total rotation time is cleared. Thus, this mode
must be executed when replacing the fixing unit.
If the mode is not executed, the following symptoms will occur.
-The alarm code is not closed.
06-0002: Fixing unit life alarm (Caused by the belt displacement)
06-0004: Fixing unit life alarm (Caused by the torque up)
-Although the total rotation time of the replaced fixing assemble does not reach to the message threshold, the
machine wrongly recognize that it reaches to the threshold and displays the message.
Be sure not to execute the mode except at the installation and the fixing unit replacement. If not, an error
message may not be displayed when the fixing unit reaches to its life.
Sep 10, 2015 | Canon Office Equipment & Supplies
Manual
You may download a copy of the manual here.
Mar 02, 2013 | Royal DS3 Exacta Electronic Postal Scale...
Htc hero alarm not working.... no sound when alarm goes off
I had this problem with my Orange Hero too - there is a fix but it's quite obscure.
When you're inside the "choose an alarm sound" menu and scrolling through the list,
if you press the volume buttons on the side of the phone then you can manually adjust
the alarm sound (mine was set to 0). Not sure what causes it to set to zero,
presumably when you take the phone off silent mode it sometimes fails to update the
alarm as well? This still needs looking at because it means the alarm volume resets
to zero of its own accord, but it can at least be managed by manual readjustment.
Hope this helps!
P.S. It might also be worth noting that when I was having this problem, no
third-party alarm apps would play the stock alarm sounds either.
Oct 28, 2009 | HTC Hero Smartphone
Menu Reconfiguration Problem
The menu items on my 2600 have changed to email (1) messaging (2) recent calls (3) media net (4) media mall (5), etc....I cannot find the alarm features, not even in the games & applications menu item. What probably happened? How do I get my 2600 to give me the standard menu item
Oct 29, 2008 | Nokia 2600
Service message for alarm system
The message is trying telling you that the system has a fault and most likely the control module has disabled the system. After the problem is fixed the message will clear. You can have the system tested by Volvo to see what part of the system has a fault, most likely they will charge about 1 hour labor time.
Aug 24, 2008 | 2000 Volvo V70
Phone communication failure
I have been following your case for a while now and start to think that you should switch to another alarm company, I mean if they can't fix such a simple problem with a tech (!?!?) to me, as an alarm installer, it is unacceptable!, in Canada we had the same problem and did the change and life went on..sorry for my typo mistakes it is because i have a french accident (i am from Quebec, Canada).
Thanks,
Lucus123
Jul 10, 2008 | GE Security Simon 3 Wireless Home Security...
Alarm displayed on phone
This indicates there was a problem with your T1 line. Pressing 606 will clear the message on the phone. If the message returns, you may want to have your T1 line checked.
Nov 05, 2007 | Vodavi 30-Button XTS Telephone
Motorola E815 alarm quit working
I've had a similar problem with alarms not going off.  In my case, it was caused by receiving a text message that was unanswered between the time that I set the alarm, and the time that it was supposed to go off.  Try reading all your text messages, deleting all messages, and then take the battery out and put it back in after a few minutes.  The last part is to reset any caching, but the first two steps followed by a turn off/turn on should also do the trick.
Oct 08, 2007 | Motorola Mobility E815
Health & Beauty Logo
271 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
