Question about Mitsubishi VS-50605 50" Rear Projection Television
Blank screen on VS-60705
Tried the hard restart....Power unplugged for two hours...still nothing...TV is 11 years old,,so it might be time..How do I fix
  • aggieace May 27, 2010
    Although the first response will suffice...Just thought I would get another opinion.....After the hard restart...The TV no longer stays on...Soon as I press the power button, it turns back off???
  • 10,515 Answers
This model is equipped with a self-diagnosis feature to help with diagnosis of shutdown problems, to activate this turn the unit on let it shutdown then press the input/or device and menu buttons on the front panel simultaneously and hold them in for 5 seconds after 5 seconds the power LED on the front panel will blink a two digit sequence. This will be one set of blinks a short pause then another set of blinks, this will repeat 5 times.
Let me know,so that we could Proceed.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on May 27, 2010
  • 2 more comments
    Thanks...the sequence is 1-2, 1-2, and then 1...That is two blinks, two blinks, and then one.
    leo
  • taran_2005
    taran_2005 May 27, 2010
    Thanks for your response!!
    This clearly indicates - No Error Detected.
    Most of the Times, this indicates a problem with Power Supply.
    Let me know,if needed further assistance.
    Hope i helped you.
    Thanks
    Thanks again for your help....I will try to purchase a power supply if you think it is something easy for someone to change out....or should I go with a technician????
    regards,
    leo
  • taran_2005
    I would strongly recommend you to call a Technician if you want to get it Fixed. He would be the best person to tell you the Fact. There is no point of Purchasing Power Supply without Inspection and Testing.
    Hope i helped you.
    Thanks
  • Mitsubishi Master
  • 12,061 Answers
Http://www.eserviceinfo.com/downloadsm/19914/mitsubishi_vs-50605.html Above is your service manual. http://www.eserviceinfo.com/index.php?what=search2&searchstring=mitsubishi+projection+tv Above is another service manual, as well as below, use the troubleshooting procedures to isolate your issue. http://elektrotanya.com/mitsubishi_cs-20301_chassis_xm1_sch.pdf/download.html
With this symptom, it is impossible to tell what the exact "Cause" of this symptom is. The LED's do not tell us what is wrong, sometimes it may indicate the "Area" in your case it is the X board. BUT thats NOT where the "Fault is" thats just the part that is affected. These days unlike the "Old" analogue days it just isn't realistically possible to fix anything but the most basic of problems with todays sophisticated units. This is quite apart from the Safety aspect, any unit that can cause a firs or have an explosion, or both, is NOT to be treated lightly, and and the repairer, of the unit is legally responsible, another thing to think about. Also, one must have tools, a Multimeter, a soldering iron, a deslodering iron, an oscilloscope, a signal tracer, tools, and most important of all, a Service Manual, without which, there is no way to even begin to understand and fix it, and more importantly Program it, AFTER it has been fixed. As these days a TV, is a PC, a Tuner, and an HDTV Monitor, and more, all in one. in the "old" days TV"s were more, rudimentary, and built to last for 20 years, and a "Parts" supply was set aside. They usually used to fail for only a few reasons, and they while still difficult, were less difficult to repair. Electrical knowledge was transferable, and they could be and would respond to, This-is-the-symptom-This-us-the-Fix, But that no longer applies, as now, it can be a Fault on I squared Bus, or "Sensor" failure, or it simple may have "Crashed" just like a PC, It could be a Diode go bad, and that will stop the whole thing. You see, in the day, the sets were Very "Fault Tolerant" because they were Analouge, and a faulty, component, or more sometimes, the set would always diplay something usually, and when they didn't it was one of anly a few things, sure there are always the horrid ones, and there are pleanty of those, but all in all it was quite easy. But with Digital Electronics, it either goes, or it doesnt, there are usualy few half measures. I mean thats the definition of logic either going or not. So it can take very little to completely paralyse a set, and generally give the only sysmptom, it can, by not working, usually No picture, or the like. So you, see the list is endless almost for any given SYMPTOM, as that is what is being seen, not the cause, as I keep going on about. Also any fault, usually involves the Power Supply, it is either the cause, the cause of the damage, or it is damaged. or ALL of them. Then after you have done the electronic repairs, you then must program the set to work, and align, and set up in general, any one of those settings missed or done wrong, back to square one. So, it is nearly always my professional opinion that one should always get a "Quote" form the manufacturers recommended service center, I cannot stress how important that last point is. It is even worth the cost of shipping. you see an authorised service agent, will have trained staff, trained on their brand, also they have first hand access to parts, original parts. This will actually save you money and ensure you can actually get it back fixed. Of course asking for a "Quote" also gives on the option of repair or replace. Often my clients,do not go through with repair, unless it is moderate, but in some of the more costly jobs they see it, as do i, that a replacement, with a warranty, is a better option. As an aside here, one could then tear the TV down, and sell the Known Good bits. You'd be surprised who needs parts, i myself often must by from third party sources to effect a repair. So money could be recouped, somewhat,and help out someone else
So, it is nearly always my professional opinion that one should always get a "Quote" from the manufacturers recommended service center, Mitsubishi, in your case, please contact a local or head office and ask for a referral to an Authorised service center. I cannot stress how important that last point is. It is even worth the cost of shipping. You see an authorised service agent, will have trained staff, trained on their brand, also they have first hand access to parts, original parts. This will actually save you money and ensure you can actually get it back fixed. Of course asking for a "Quote" also gives on the option of repair or replace. Often my clients,do not go through with repair, unless it is moderate, but in some of the more costly jobs they see it, as do i, that a replacement, with a warranty, is a better option. As an aside here, one could then tear the TV down, and sell the Known Good bits. You'd be surprised who needs parts, i myself often must by from third party sources to effect a repair. So money could be recouped, somewhat,and help out someone else.
Television turns itself off after being on for about 10 minutes
Run the diaginostic that you find in the pdf user manuel...1st
Nov 11, 2009 | Mitsubishi VS-60705 60" Rear Projection...
Horizontal lines in the picture.
Give it time to warm up like another 10 to 15 mins i find put a tv guide channel on the screen stays pretty much the same picture, then leave the TV on" i use a 4 hour rule if i dont view in 4 hours or more i will close tv power
Oct 07, 2009 | Mitsubishi VS-60705 60" Rear Projection...
Vs-60705
My Mitsubishi Model VS-60705 did the same thing a couple of years ago...A TV repair facility replaced the Video card. Any repair facility that works on rear-projection TV's should be able to repair your set. I bought the set on Jan 1, 2000. Coming up on 9 years and the set works like new.
Jul 30, 2008 | Mitsubishi VS-60705 60" Rear Projection...
Tv problemsMitsubishi VS-60705 60 in....
My Mitsubishi Model VS-60705 did the same thing a couple of years ago...A TV repair facility replaced the Video card. Any repair facility facility that works on rear-projection TV's should be able to repair your set.
Jul 10, 2008 | Mitsubishi VS-60705 60" Rear Projection...
No picture
Try a "hard restart"', which simply means unplugging the power cord of your TV, and replugging it after 4 hours have passed. This technique helps to reprogram the electronics of your TV.
Hope this suggestion works for you.
Jun 05, 2008 | Mitsubishi VS-60607 TV
Mitsubishi VS-60705
I have a Mitsubishi VS-60705 and the picture flutters vertically and horizontally i need to be fixed
Dec 04, 2007 | Mitsubishi VS-60705 60" Rear Projection...
RCA HD50LPW62AYX2 WILL NOT STAY ON
My HD50LPW62AYX2 RCA TV sometimes reverses the blue and reds. The peoples faces are blue, especially the lips.
Sometimes turning the TV off and then back on again fixes the problem. At other times this correction is good for only a second or two.
Do you have an English owner's manual available on line or otherwise available?
Nov 21, 2007 | Televison & Video
Mitsubishi VS-60705 - picture flutters vertically and horizontally
This sounds like one of the 9 volt regulators on the small signal board is going bad, supplying less than 8 volts. I have seen this is several of those sets. The IC needs to be replaced and if you do not have experience in servicing projection TV's then I suggest letting a qualified tech handle it for you.
Jul 09, 2007 | Mitsubishi VS-60705 60" Rear Projection...
Mitsubishi VS-50605 50" Rear Projection Television Logo
87 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
