Question about Dewalt DW735R Reconditioned Heavy Duty 13" Three Knife, Two Speed Thickness Planer
Dewalt 735 cannot raise height adjustment above 1-5/8"
  • dcauthorn Jun 01, 2010
    Thanks but not a lower problem........a raise head problem. I think one of the lead screws may be out of adjustment and I don't have the procedure for adjusting them but can figure it out if i disassemble the whole thing and start from scratch. I was just hoping someone had encountered this problem before. Thanks for your input.
  • 17 Answers
There is a wheel on the left hand side. Typically, it won't let you LOWER it below what that wheel is set to, but that may have something to do with it.
Posted on May 27, 2010
I have a John Deere LX178 lawn tractor and the mower deck will not raise/lower. It is all the way down and pushing in the button is how i've ALWAYS adjusted the height. It will not budge
1) NEVER adjust to where the deck wheels touch the ground. The wheels are to ride 1/4" off the ground. 2) The long lever to your left which raises & lowers the deck has 3 settings. 1- Fully back toward you which has the deck raised (called transport mode). 2- Halfway down which is the normal mowing mode (called float mode) 3- Fully away from you which sets the deck fully on the ground. This mode is ONLY used for VERY rough terrain where the deck risks getting pushed into "transport" or "full up" mode & getting stuck there. 3) On front-to-back tilt, the front should be 1/2inch lower than the back for least damage to the grass. Ok-now to adjust "cutting" height. 1) Park on a level, flat surface. 2) Pull the deck lever fully back toward you to put the deck into "transport" mode. 3) twist the "cutting" height knob (just below your seat) to the height you want the grass cut. Has choices by 1/2" increments from 1" to 3.5". The deck in "transport" mode is 4". 4) Lower the deck lever to the midway/"floating" mode point. 5) Adjust each deck wheel with its own peg & pin to have at least 1/4" clearance from ground. Thats it for "cutting height" adjustments
call your deere dealer,
Troubleshooting
Service Mower
cant find info for you,call dealer
Jun 03, 2015 | Garden
1997 Honda CBR 400 RR how to raise the height
Hi, Jayk936 the answer to this question is way above my pay grade for this situation, I would call or visit my local dealer or reputable shop's service/parts department and inquire about any possible quick fix, answers, or parts inquiry.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
http://www.fireblades.org/forums/honda-cbr-600/60096-raising-height.html
4 1 how to adjust your motorcycle the rear suspension
MC Black Bears free service manual
https://www.partsfish.com/page/oem-parts-for-honda
Honda CB400 Owner Manual
Aug 24, 2011 | 1997 Honda CBR 400 RR
How to raise and lower saw blade
You raise and lower the table plate, NOT the blade. There is a knob to lossen and tighen the tension on the table plate and you can adjust the blade height by lowering the plate and vice versa.
Jun 20, 2011 | Dewalt DW364 7 - 1/4'' Heavy Duty circular...
The drive belt on a dewalt 735 planer dosnot track
The pully which quides the belt must be perfectly level in both the horizontal and vertical positions. Use a metal square to check alignement and adjust using adjustment screws.
Apr 25, 2011 | Dewalt 13 in Planer
How to adjust water flow coming out of bubbler
Check stream height from bubbler. Stream height is factory set at 35 PSI . If supply pressure varies greatly from this, remove the (bottom cover plate) and adjust the screw on the regulator Clockwise adjustment will raise stream height and counter-clockwise will lower stream height. For best adjustment stream height should hit basin approximately 6-1/2" (165mm) from the bubbler.
Mar 02, 2011 | Elkay Water Cooler ADA Wall Hung 8 Gallons...
I am unable to raise or lower the cutting surface of my DW734 thickness planer. The turn handle is very hard to turn. Is there some kind of a locking mechanism ? If I had a manual I might be able to figure...
Follow this link: http://servicenet.dewalt.com/Products/Detail?productNumber=DW734
This will allow you to download the manual and exploded art for base, cutterhead and motor. You may also want to check the position of the turret stop. First of all, make sure the cutterhead lockdown lever is disengaged. Here is from the manual:
Your planer is equipped with a turret stop (M), shown in
Figure 11, for repetitive planing of pre-set depths. Stops are
set at 0", 1/4", 1/2" and 3/4". Use the 0" setting when planing
between 1/8" and 1/4".
TO SET A PLANING DEPTH
1. Be sure the carriage is set above 1-1/4" before trying to
set the turret stop.
2. Turn the turret stop until the desired measurement
shows (Fig. 11).
3. Unlock the head lock lever (Fig. 8). Turn the depth
adjustment crank, lowering the carriage by the desired
increments, until it contacts the turret stop.
NOTE: DO NOT USE FORCE TO CRANK THE CARRIAGE
BELOW THE LEVEL THAT THE TURRET STOP INDICATES.
PERMANENT DAMAGE TO THE HEIGHT
ADJUSTMENT SYSTEM ON YOUR PLANER WILL
RESULT.
NOTE: The 3/4" turret stop can be adjusted for other planing
thicknesses. Adjusting the 3/4" turret stop does not affect the
other turret stop settings.
TO ADJUST THE 3/4" STOP FOR OTHER
THICKNESSES
1. Unlock the head lock lever (Fig. 8) and turn the adjustment
handle counterclockwise to raise the cutter head.
2. From the back of the tool, locate the turret adjustment
bolt (N) shown in Figure 11. This bolt is set for a 3/4"
depth of cut at the factory. Use the crescent wrench provided
to loosen the jam nut. Adjust the bolt up or down to
reach the desired planing depth.
3. Turn the depth adjustment crank, lowering the carriage by
the desired increments, until it contacts the turret stop.
Hope this helps.
Dec 27, 2010 | Dewalt DW734 Heavy Duty 12 12" thickness...
Dewalt 735 planer. dust is accumulating in the
Had the same problem. Drove me nuts trying to figure out where it is coming from. It most likely is a worn in hole in the squirrel cage where the two halves go together. You won't see it unless you remove the fan and both halves of the blower housing. Take them out and put the two together and have a look from the inside. The wear is along the seam. I used hot glue in that area to fill the gap. Squirt it on one half and put the two halves together while hot. Also, you can buy replacements for these. Hope this helps.
Jan 12, 2010 | Masonry Tools
Vacuum height won't go on low carpet setting. Dial will go on medium and high, but not low.
Make sure you're not trying to adjust w/ handle in upright locked position because thewre is a cam which raises the vacuum head a little bit when handle is locked in upright position. If this is not the problem, turn vacuum upside down with handle in unlocked position and power cord not plugged in(for safety reasons obviously), unscrew and remove 3 screws that hold belt/beater brush assembly cover in place(2 are in corner near ends of beater brush and 1 is towards motor housing) tilt end of cover with 1 screw up and remove cover(there are 2 tabs at beater brush end of cover). Right above this is the height adjustment assembly with 2 rollers, raise up the assembly gently and using your finger or a bristle bottle brush,etc. make sure there is no debris caught between the height assembly and the hose(you will understand when you see it), if there is no debris you can now see the pattern on the bottom of the height adjustment knob and the lobe that rides on it, just check to make sure nothing is broken and/or missing, hope this helps!!
Dec 29, 2009 | Hoover Vacuums
How do you replace or repair the chain drive on a Dewalt DW735 planer? I went to use my planer and the height adjustment was very tight. I tried to raise it and lower it and even lubricated the 4...
hi i have a coleman powermate 18 volt cordless drill
i put the batt in the charger for a long period of time
and still not up to par
i wonder is it the batt or the charger??
thanks
dan
Nov 28, 2009 | Dewalt Tools & Hardware - Others
Dewalt 621 fine height adjuster
I would go to Dewltservicenet.com and in the middle of the page at the bottom type in your model number and you can go to either a breakdown or the instruction manual. On page 6 and 7 it talks about th fine height adjuster. Hope this helps
Mar 28, 2009 | Dewalt Tools & Hardware - Others
Dewalt DW735R Reconditioned Heavy Duty 13" Three Knife, Two Speed Thickness Planer Logo
339 people viewed this question
Top Dewalt Cutter Tools Experts
Are you a Dewalt Cutter Tool Expert? Answer questions, earn points and help others
