Question about Dell 1700n Laser Printer
I've cleared to paper jam. Paper was not torn so
I've cleared to paper jam. Paper was not torn so I know there is nothing left in the printer but I still the error light is on
    Problem Solver:
  • 14 Answers
You have take the ink cantainer out and disconect the printer for one min then reconnect
Posted on May 27, 2010
Hpc6280 paper caught internally
This information comes from the User Manual on pages 111-112:
http://h10032.www1.hp.com/ctg/Manual/c01150745.pdf
Internal paper jams on this machine tend to be in the two-sided printing accessory.
To clear a paper jam from the two-sided printing accessory:
1. Turn off the printer
2. Press in the tabs on the left and right side of the two-sided printing accessory, and remove it by pulling out from the center of the printer.
3. Gently pull the paper out of the rollers. If the paper has torn, check the rollers and wheels for small, torn pieces of paper
4. If it's still not clear, open the two-sided printing accessory by pulling up on the tabs, and remove any paper stuck inside it, then close the accessory by pressing down on the tabs until they lock into place
5. Replace the two-sided printing accessory by pushing it forward until it snaps back into place
6. Turn on the printer, and verify that it works by pushing OK to continue the job it jammed on.
Feb 27, 2014 | HP Office Equipment & Supplies
Torn paper- how can I disassemble epson workforce 610?
Before you do a complete teardown, use a flashlight to examine every possible point in the paper feed path where the paper is jammed. There may be an easier way to clear it. In some cases I have had to clear a paper jam bit by bit using tweezers.
Oct 15, 2012 | Epson Workforce 610 All-In-One InkJet...
Paper jam in exit area
Hi
Disconnect it completely from power and re-connect again.
Sep 16, 2012 | Samsung SCX-4300 Monochrome Laser...
I've got a 4 by 6 photo paper jam in my Lexmark S405 all-in-one printer.
Please follow the steps below to fix the problem:
1. Remove the sheets of paper from the feeder.
2. Try to reach for the paper jam.
3. If paper jam can't be reached, open the printer cover to access the cartridge area. You may be able to get a better hold of the paper jam in the cartridge area.
4. Remove the paper jam and make sure not to tear or leave any torn piece of paper in the printer.
When paper jam is clear, try to print a document again to verify that the problem is fixed.
If problem continues, please contact Lexmark Technical Support Center for additional assistance.
Sep 01, 2011 | Lexmark All-in-One Printer with PictBridge
How to fix paper jam! problem
Clear the paper jam Followthese steps in the order presented to clear the paper jam. Step one: Remove any loose paper: Remove any loose sheets of paper from the input tray and theoutput tray. Take note: Do not remove jammed paper at this stage. Trying to clear jammed paper from the front of the product can damage the print mechanism. Step two: Clear the jam from therear of the product Take note : Never pull jammed paper from the front of the product. If you can pull it from the rear of the product or the tray, always try the rear first. Pulling paper from inside the front cover can cause mechanical damage to the product. 1. Pressthe Power button ( clip_image001.gif ) to turn off the product. 2. Disconnectthe USB cable from the rear of the product. 3. Disconnectthe power cord from the rear of the product. 4. Pressin the tab on the left side of the rear door to release the door. Remove thedoor by pulling it away from the HP All-in-One. Figure 1: Press the left side tab torelease the rear access door Gently remove any jammed paper orbits of torn paper from the rollers inside the product. Use both hands to pullout any whole sheets of paper to avoid tearing them. Take Note: Use a flashlight to thoroughly check the rollers and wheels for torn pieces of paper that might remain inside the product. If any torn pieces of paper remain inside the product, more jams are likely to occur. Figure2: Remove scraps of paper Replacethe rear access door. Gently push the door forward until it snaps into place. Step three: Clear the jam from theautomatic document feeder (ADF) 1. Openthe cover of the ADF. Figure 3: Open the cover of the ADF 1. Gentlypull the paper out of the rollers. CAUTION: If the paper tears when you are removing it from the rollers, check the rollers and wheels for torn pieces of paper that might remain inside the product. If you do not remove all the pieces of paper from the product, more paper jams are likely to occur. 2. Closethe cover of the ADF. Step four: Clear the jam from thefront of the product 1. Lookinside the product through the paper output tray to check if any loose or tornpaper is stuck in the rollers. 2. Gentlypull the paper out of the rollers. You must Remove paper from the front of the product as carefully as possible. If any torn pieces of paper remain inside the product, more paper jams are likely to occur, and this could damage the print mechanism. Use a flashlight to make sure that you find all traces of paper. 3. Reconnectthe power cord to the rear of the product. 4. Pressthe Power button (clip_image001.gif ) to turn on the product. Step five: Print a self-test report Printa self-test report. Please inform me if this help you with the paper jamproblem.
Nov 22, 2010 | HP J3680 Officejet All In One Printer
Have paper jam in lower part of unit. Do not know how to remove sheet of paper.
Hi. I can give a tip on how to remove the paper. First, unplug printer from power outlet. Then, you can try removing the jammed
paper by opening the cover of the
printer where the cartridges are. Try to get a firm hold on the paper and slowly remove it. Make sure it won't get torn and nothing's left in the printer so it won't cause another paper jam in the future. Good luck!
Mar 12, 2010 | Lexmark X5650 ALL-IN-ONE PRINTER
It says there's a paper jam or a scanner misfeed..but there's nothing there
Paper stuck inside the HP All-in-One can cause jams or also sometimes there are some instruction that get stuck in the printer internal mechanism .
Power off the printer , unplug the power cable. Wait for 30 sec. , Replug the power cable. Power on the printer.
Check for a stuck paper or torn bits of paper.
Clear jam from the back of all-in-one
Press in the tab on the left side of the rear door to release the door. Remove the door by pulling it away from the HP All-in-One.Trying to clear a paper jam from the front of the HP All-in-One can damage the print mechanism. Always access and clear paper jams through the rear door.
Gently pull the paper out of the rollers.If the paper tears when you are removing it from the rollers, check the rollers and wheels for torn pieces of paper that might be remaining inside the device. If you do not remove all the pieces of paper from the HP All-in-One, more paper jams are likely to occur.
Replace the rear door. Gently push the door forward until it snaps into place.
Press OK to continue the current job.
Clear the jam from the automatic document feeder (ADF)
Paper can also jam in the automatic document feeder. Follow the steps below to clear a paper jam in the automatic document feeder(ADF)
Lift the cover of the automatic document feeder.
Reload and test the all-in-one
Once you have removed the jammed paper, verify that the all-in-one is still functioning properly.
Reload the all-in-one with either plain or photo paper.
Print a page from a memory card or the computer.
If you have completed all the steps listed above and are still experiencing a problem contact HP to service the product.
Jan 24, 2010 | HP J3680 Officejet All In One Printer
When powering up printer receive message "press power then clear paper jam" I cannot find any paper jammed in the printer
Power your printer off and unplug it. Try manually feeding a sheet of heavy weight paper (cardstock) through the paper path to help push out any torn scraps of paper left from a previous jam, or any staples or paper clips etc that may have fallen into the paper path.You may need to do this multiple times. You can also try blowing in canned air to remove and paper dust that might be laying on the sensors causing a false jam message. Good luck!
Aug 08, 2009 | Dell A940 All-In-One InkJet Printer
Paper will not feed from drawer
Pull the paper tray out of the machine. On the right side underneath you should see a rubber paper feed roller. Clean this off with a slightly damp cloth until it is "squeaky clean". Also, look about to be sure there is nothing blocking the paper path. Sometimes paper gets torn off and left in the machine when clearing a jam.
Apr 21, 2009 | Canon PC-941 Copier
HP 3419A
Hi Mose,
I never faced this problem any time , but could find a solution for you which i think will be helpful.
The paper jam error state occurs if the printer detects a paper at the platen after attempting to eject paper to the out tray. Clear the paper path.
<Power and Resume>
1. Turn the printer OFF and back ON to allow the printer to clear the jam.
(If the paper remains jammed, turn it back OFF and follow the remaining steps.)
2. Open the top cover and remove the OUT tray.
3. Pull the jammed paper out of the printer by grasping the middle section of the paper.
4. Remove all torn pieces from the paper path.
5. Remove any wrinkled or torn paper from the IN tray.
6. Reload the paper stack.
7. Replace the OUT tray and close the top cover.
8. Turn the printer ON.
Hope this answers your problem, Please let me know by providing your valuable feed back
Thanks,
Robosoft.
Dec 24, 2007 | HP Photosmart 375 InkJet Printer
Dell 1700n Laser Printer Logo
161 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
