Question about HP Officejet Pro L7680 All-In-One Printer
I HAVE A HP OFFICEJET PRO L7680 ALL-IN-ONE
PROBLEM IS:
IF YOU GO TO COPY ,SCAN ,OR FAX OUT THE PAPER IS BLACK!
WHEN TRYING TO DO ANY OF THESE CHORES THE SCANNER BAR TURNS OFF AS IT IS PASSING UNDER THE PIECE BEING WORKED ON.
OTHER THEN THAT THE PRINTER PRINTS FINE IN COLOR AND IN BLACK/WHITE AND CAN RECEIVE FFAXES FINE.
THE QUESTION IS ...IS THERE A COLD RESET THAT I CAN PERFORM ON THE PRINTER OR JUST WHAT THE HECK IS GOING ON??
  • 21 Answers
Sounds to me like the scanner is faulty, return it under warranty and demand a replacement.
Posted on May 12, 2008
SOURCE:
Black line 1 inch wide right side ,when copies are made and faxing
When the paper is fed through Automatic Document Feeder (ADF) is is scanned before copy or fax. The scanner is fixed type and is located just below the ADF.
The lines are due to dirty scanner mirror. The printer/ scanner design is based Sheet-Fed Scanner. Open/Lift the Control Panel (scanner top )(by pulling it up from front - the area from where the paper to scan comes out). Look out for the horizontal mirror and use a soft, damp, lint-free cloth to gently clean the scanner mirror, rollers etc. and enjoy clear scanning and copying!
Inspect for any tron pieces of paper dirt etc.DONT USE PAPER, CHEMICALS OR ANY ABRASIVE CLOTH as it may damage the parts.
Also note that your machine can scan an image only 8.15 inches wide, regardless of how wide the paper is.
Hope it helps! Good Luck! Thanks for using Fixya!
CreativeTECH
May 31, 2011 | Brother 5750E Fax
When I send a fax, the recipient gets all dark or black sheet. Thinking this was the recipients problem, I faxed again to a different fax number, same thing happened.
To fix the problem you have to check the scanner of your fax machine. It might not be functioning properly. Try to observe the fax machine while sending a document, look at the scanner section and see if the light of the scanner is turned on or lighted. If it's no longer lighted you have to replace it.
Nov 07, 2010 | Sharp UX 355L Plain Paper Thermal transfer...
My paper comes out black after i scan it
try to calibrate the scanner, go control panel, scanner and fax, properties.. and calibrate with the calibration paper.. you can clean also with the cleaning paper..
May 11, 2010 | Visioneer Strobe XP 300 Pass-Through...
Black copies being received
Your image scanner is bad. Try making a copy....if it comes out black but your incoming faxes are fine then your image scanner is bad. You can also print a report from the machine and it should come out fine.
The image scanner is the part that scans your originals before faxing them out or making a copy. There is a light bar that lights up when scanning. Either that light bar(l.e.d. array) has gone bad or the scanner itself is bad. If this is the case it is probably going to cost more to fix than the machine is worth. You could buy a new machine for what it would cost to fix.
Good Luck and Thank You for using Fixya.
Apr 22, 2010 | Brother IntelliFAX 4750 Plain Paper Laser...
Fax sent and copy has a 2 inches black belt on left
This is scanner defect. You could have a scrap of paper or something in the slot where your documents are fed in but I suspect that the scanner led array has a few bad led's and that is what is causing the black line. When your original is fed in there is a "light bar" that lights up to scan the original. This light bar is made up of a row of small led lights. I have seen these led's loose connection so that a few do not light up and this causes the problem you describe. They are usually repairable but the problem is you can replace this fax with a new one for under $100 and the repair most likely will cost more.
Dec 25, 2009 | Brother FAX-1020 PLUS Plain Paper
Black vertical lines on the sent copies when faxed on Sharp UX 510
Lift the document feeder cover, and clean the scanner glass.
Please rate solution
Mar 31, 2009 | Sharp UX 510 Plain Paper Thermal transfer...
The Black line on the paper when I scan and fax
try cleaning the grid on the drum unit and you might replace the drum
Dec 22, 2008 | Brother MFC-8220 Fax
Black Bars on the copy page
It sounds like you have a bad scanner unit.
Oct 27, 2008 | OKIFAX 5400 Plain Paper LED Fax
Stripe on receiving fax Brother MFC 7820N
I had the same problem, and I just fixed it.  It was a tiny little black dot which was stuck to the glass where the document feeder passes the paper to.  First you need to figure out where the line is on paper with respect to the paper, and just carefully run your finger on the glass to see if there is something on the glass.  I removed it, cleaned the glass, and anything which I run through the document feeder is now fine.  Hope this helps.
Aug 15, 2008 | Brother MFC-7820N Printer
Receive a black copy
scanner problem. if you receive faxes that are good. the scanner is used when you copy or send. Lawrence
Feb 26, 2008 | Panasonic Panafax UF-490 Plain Paper Laser...
HP Officejet Pro L7680 All-In-One Printer Logo
218 people viewed this question
Clive
Clive
Ekse
Thomas F. Schneider
