Question about Raypak Free Hydraulic Lift Gate Delivery - No L...
My raypak keeps clicking to ignite, but doesn't ignite.
My natural gas raypak pool heater keep clicking to ignite (SPK appears) but won't ignite. The only reading that comes out are CLK and CFH. Read somewhere about cleaning filters and have never done this. this is the 4th season that I've had the heater. thanks
    Top Expert:
  • Raypak Master
  • 6,514 Answers
See if gas line to ignitor is clogged or spider web
Posted on May 25, 2016
  • 44 Answers
SOURCE: "CLK" is being displayed on
CLK stands for Clock. Your heater thinks it is connected to a timeclock and the circuit is open. The connection is on the back of the circuit board, and a communication wire will continue on to your timeclock or controller. Close that circuit and it should fire.
Posted on Sep 28, 2010
  • 139 Answers
SOURCE: Raypak pool heater RP2100 error message CLK
you are in fireman switch mode,which means pool timer is ready to shut down pump. clk shuts down heater approx 15 minutes before pump shuts down. this lets heater cool down before pump shuts off.
Posted on Jul 23, 2009
  • 990 Answers
SOURCE: Raypak 2100 digital display on start up goes through
There may be a buildup of carbon on your pilot or your gas pressure may be low. It is hard to say without more info on the heater, gas line size and meter size. Depending on where you live it could also be something like spider webs in your gas orfaces. These will cause all to fire normally but not be consistant enough to read fire back to the ignition control. A small piece of bent wire into the orfaces will help to clear this up. As it is not a heater related problem it will not show a ready made answer on the display. Hope this helps, let me know.
Posted on Nov 07, 2009
SOURCE: Rheem model p-m266a-en-c digital gas pool heater runs, shuts down
So now we know what it stands for. Now how do we call for heat? Can we do this ourselves?
Posted on May 25, 2010
john224
  • 1378 Answers
SOURCE: raypak heater. fault cde says (ROL)
Thank you for posting your question here on Fixya.com.
Replacing the roll out switch is an easy do-it-yourself repair. Fixing the problem causing the roll out of the burner flames in the first place is a bit more of a pro job. Something is causing to much heat to roll out the the combustion chamber into the control area causing the switch to fail. You will continue to burn the link until the underlying problem is fixed.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. Positive feedback is appreciated once your problem is solved!
John
Posted on Jun 01, 2010
SPK displays on Raypak 2100
check gas supply if ok check to see if gas line to ignitor free of debris
May 24, 2012 | Raypak 2100 Pool Heater Gas 266000 BTU'...
Raypak 406A won't light
check wiring if 120 volt see wiring on inside of front panel if wiring ok switch black and white to see if it stays running
May 15, 2012 | Raypak 406A Digital ASME Natural Gas IID...
What is causing my P-R405AL to not ignite? It shows SPK, CFH and the 'flame' flashes, but no ignition or heat.
check gas pressure see if gas valve on if voltage to gas valve bad valve see if cobwebs in lines or flame sensor if only runs a few seconds if new check wiring
Jan 17, 2012 | Raypak Rp2100 Pool & Spa Heater Lonox 407k...
Raypak 2100 just get SPK then LO codes. won't ignite
if wired 120 volt check wiring and check gas pressure see if lines have cobwebs
Jan 02, 2012 | Raypak Rp2100 Pool & Spa Heater Lonox 407k...
Pilot lights but burner won't light. Display continues to read SPK
On these units, the pilot ignitor and the pilot rectefier are the same part. The pilot can be lit, but not be sensed by the rectefier/ignitor. This will keep your burner tray from igniting. You need to replace the ignitor assembley. If it is the same as the raypak digital 406a I charge about $75 for that part, and it takes about 20 minutes to install. Need the part or more help e-mail me. adamh@newconceptchem.com
Oct 22, 2010 | Raypak Rp2100 Pool & Spa Heater Lonox 407k...
I have a five year old Raypak 207A on my 500 gal spa. When I turn the unit on, the display shows: PV 1, then CFH, then SPK, then the burner ignites, then CFH again, then it displays the flame icon and...
CFH means "Call For Heat", and SPK is "Spark". It sounds like you are running out of gas.Propane tanks need to have 30% in the tank for a heater to run correctly,and after they are filled you must bleed the air out of the line.If you have Natural gas,the gas line may be too small to supply enough gas to keep it running. NOTE...gas pressure MUST be checked with the heater running.
Sep 28, 2010 | Raypak Free Hydraulic Lift Gate Delivery -...
Raypak Free Hydraulic Lift Gate Delivery - No L... Logo
345 people viewed this question
Top Raypak Pool & Spa Experts
Bill Jordan
Paul Carew
Jim Goldsmith
Jim Goldsmith
Are you a Raypak Pool and Spa Expert? Answer questions, earn points and help others
