Question about Craftsman 20 Hp 42" Deck Lawn Tractor
Cuts lower on side
Have a mastercraft lt1000 20 hp with a 42 in cut
everything seems ok but it cuts abt 1in lower on one side
  • 420 Answers
First and foremost! make sure the tire pressure is correct in ALL TIRES and then level the deck.
Posted on May 27, 2010
Yard works 4.5hp 42" cut lawn tractor cuts fine when mower deck is up on 4, but when it is lowered it cuts out and won't cut the grass.
4.5 hp will not power a 42 inch deck any way you cut it quite likely the blades need sharpened real bad .motor needs to run fast when tryng to cut also as that throws the grass out of the deck
May 27, 2015 | Garden
I have a mastercraft ride on lawn mower .... model # 13A0678G515....the drive belt broke and there are no numbers left on it.......i got the mowerwhen i purchased the property and have no manual .....it...
For parts, 18006681238 is a toll free number (at least in Canada) to MTD (who made this model for Mastercraft). The part number is 754-0371A for V-belt 'B' x 74.04. I got this from the original manual. The phone number came from under the seat of my ride on mower.....yeah, it's the same model. I bought mine in 1999.
Hope this helps.....
May 25, 2011 | Garden
LA110, 42" mower deck, 1
Check that the cutting tip of the blade that is cutting lower is not bent down. Also park the mower on a level surface and lower the deck and check the gap under the front of the deck is even. If not, there are levelling adjustments on the top of one side of the deck. Regards Phil
Apr 15, 2011 | John Deere 195HP Hydrostatic 42" Cut...
My tractor cuts uneven when i am cutting my yard
Check your blades common problem with uneven cut is a bent blade. Next find a level spot like a padio and take a torpedo level place it on the front center side to side not front to rear. On one side or the other you should see a J(jay) bolt with a nut tighten to raise losen to lower.
Terry
Aug 18, 2010 | Craftsman 20 Hp 42" Deck Lawn Tractor
The mower is not cutting even. we changed the blades and leveled the deck but can not seem to fix the problem
Everything sounds and looks good but the cut is uneven. I would think the only possibilities are a freewheeling blade, or an upside down blade. Neither situation is rare. If neither of those is possible I think I would set the whole thing up on jack stands and make sure nothing is going akilter in the mechanism which raises and lowers the deck, one side could be hung up.
Aug 04, 2010 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
My riding mower has a 42" deck with 2 blades. Left side cust much lower than right side. It looks like two different cuts. How can I fix this?
adjust the cutter bed so that it cuts the same hight
look at the mower bed and feel how high it is on both sides if diferent adjust it so its the same hight,
Jun 26, 2010 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
Left side blade cuts about an inch lower than right side , the left 21" when cutting is about an inch lower than the right 21", looks terrible, checked tire pressure and that was not the problem
measure the height of cut from the ground to the bottom of the deck all the way around, if it is the same the blade or bearing housing is at fault, if it is lower on the left look for a bent or broken mount from the deck to the tractor on that side.
Jun 14, 2010 | Craftsman 21 Hp 42" Deck, Ys 4500 Lawn...
I need the battery size for a 2005 21hp 42" cut craftsman rider
Most Lawn and Garden batteries are the came size, if you are referring to amp rating I like to go on the larger side I believe you can get between 175 to 425 cca (cold cranking amp) batteries. On a 21 hp I like to stay no lower than 275. I have tried lower amp batteries and sometimes on start I get a hesitation.
Mar 17, 2010 | Craftsman 21 Hp 42" Deck, Ys 4500 Lawn...
Poulan 42-Inch Steel Deck 17.5 HP Briggs & Stratton I/C Engine With 6 Speed My mower is a 42 cut and leave a row in the middle of the cut
SOUNDS LIKE YOU HAVE A BENT BLADE TRY PUTING A 2X4 UNDER THE DECK THEN LOWER IT TO HOW IT LOOKS IF ITS THE SAME ON BOTH SIDES THAN YOR BLADE IT BENT
Sep 30, 2009 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
Craftsman 20 Hp 42" Deck Lawn Tractor Logo
282 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
