Question about Frigidaire Electric Dryer
Dryer simply buzzes when start button is pushed.
This is a model FD952AW1 and is at least 15 years old. I want to suspect the belt has broken and closed some sort of "dead mans" switch but wouldn't that cut power completely and render it impossible to "buzz"?
  • Frigidaire Master
  • 43,501 Answers
There can be many reasons why your dryerDryer simply buzzes when start button is pushed. - 2_bing.gif will not turn...
This tip that I wrote will help you to figure out what is happening...
Dryer2_bing.gif Repair - The Dryer2_bing.gif is not Turning
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_tDryer simply buzzes when start button is pushed. - 2_bing.gif
Dryer Repair ? The dryer2_bing.gif will not start
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
Posted on May 27, 2010
Admiral Heavy Duty Super Capacity Plus dryer does not start when button is pushed. The dryer buzzes when the start button is pushed, but the dryer will not start tumbling. The model number is ADE7005AYW...
Motor runs, but drum does not turn
1. Broken or slipping belt---replace
2. Loose pulley---tighten pulley on shaft
3. Drum jammed or bearing frozen---check for foreign object & clear it
Clean or replace bearing
Sep 21, 2011 | Dryers
Push the start button. The dryer will run. Release start button and the dryer stops. The end of cycle chime sounds. The timer ticks. Placed all controles in every position and the results are the same.If...
probably has a broken belt,there is what is called a "Broken Belt" switch by the motor inside on the idler pulley tensioner for the belt,if the belt breaks this switch opens so the dryer wont run without the drum turning so as not to overheat and burn your clothes,replace the drum belt and you should be good to go
Jan 21, 2011 | Whirlpool GEW9878LW Electric Dryer
I have a Kenmore Elite electric dryer. It is only two years old. The dryer is a HE 3. Model 1108787 or 1108789. It was working fine two days ago then after finishing the dryer load it was on....I went to...
This could be one of several things.
1.thermal fuse is blown(with power off(unplugged)check for continuity)
2.Belt is broken (check belt).
3.loose wire somewhere
4.Door switch malfuntion push in on it and and test for continuity.
5.The control board is malfunctioning.Try removing it and observe the back of it for burnt or cracked places.
6.Motor is bad test for power to motor see wiring diagram and tech sheet inside cabinet.
Input full model # here for parts and diagrams. Model # should be located just inside of door.
searspartsdirect.com
Nov 03, 2010 | Dryers
Whirlpool dryer makes a buzz noise when push
pull motor switch out(the one with wires go in motor) best use compressed air.... lint is stopping lever... this all happens after you turn breakers off...hi hi
Aug 27, 2009 | Whirlpool ET8CHEXSQ Dryer
Dryer drum will not turn.
Hello.
If the buzz continues to go for awhile(2-3 minutes before you stop it you will need to replace the belt on your dryer.
If the buzz quits pretty quickly after you let go of the start button and you smell something hot or electrical, you will need to replace the motor.
Please let me know if you have any other questions.
Jul 22, 2009 | Kenmore 94052 Dryer
Kenmore dryer not running
Ticking sound is the timer running--so it is not the problem unless a contact has failed or a wire has come loose.  Broken door switch, thermostat failed in open position, or clogged lint filter/exhaust vent/outlet would keep unit from running.  If you can hear the motor running but the drum is not turning then the drum belt is broken.
Jun 04, 2009 | Dryers
My dryer makes a buzzing noise when I push the start button
My Hotpoint dryer is seven years old and did the exact same thing. When I got over the anger and the thought of spending 4 or 5 hundred dollars to replace it I started messing with it. I finally decided that since it buzzed when I tried to start it there was current there. The only other thing it could be was the drying cycle knob.
I held the start knob and let it buzz while I slowly turned the dryer cycle knob to the right. As I turned through each cycle it would hit "off" and the buzzing would stop and then resume as I moved past the "off " setting. On the third trip around the dryer "started" and has been working since. Maybe something got out of kilter. Apparently the problem was in the knob that controls the drying cycles.
Mar 24, 2009 | Hotpoint NVL333EY Electric Dryer
Repairing Frigidaire FER641FS0 Electric Dryer
I would suspect the drum belt has broken.
Reply back what you find and I will help you further.
Jan 29, 2009 | Frigidaire GLEQ2152ES Electric Dryer
Dryer motor
if the motor buzzes when you push start then it is a bad motor.as long as the drum turns freely by hand.
Oct 29, 2008 | Whirlpool LER4634J Electric Dryer
Try pushing start button while turing drum clock wise and see if drum will start spinning, sounds like bad start winding or relay
Sep 17, 2007 | Estate EED4300SQ Dryer
Frigidaire  Electric Dryer Logo
126 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
