I replace the lamp but i still dont hav pic wht do i need to do
  • 4 more comments
  • raiderfan906 May 27, 2010
    its a 62inch Lg projection tv. the model number is 62sx4D. i bought a new lamp. before i put it in do i need to rest anythin.
    its a 62inch projection tv. the model is 62sx4d.
    ok im goin to do that right knw
    ok put the lamp bak in still no pic. its like if the lamp dont turn on. and in the front of the tv thers a red light on. first it was green and was blinkin stop blinkin turns a solid red
    no i do dont. will it be hard to do
    ok thanks for the help. but for sure that wilbe the problem
  • 10,594 Answers
I need model number and brand info of your tv to diagnose possible cause of problem.
Model and brand would be written on label pasted at back of tv.
Thanks.
Posted on May 27, 2010
  • 2 more comments
  • Shahid Electronics
    Shahid Electronics May 27, 2010
    Ok, its LG 62SX4D
    Did you put back Lamp Cover in its position properly?
    Its first thing that need to be removed to replace lamp, make sure lamp cover is back in its place securely.
    After lamp cover is in place and tight, turn tv on.
    Right, solid red light shows problem with ballast supply board that provide high voltage to lamp to generate light.
    Did you worked before in tv circuit boards and have any experience/ knowledge about that?
    Yes, for novice its hard to replace ballast supply board and any attempt could cause any other damage to circuit boards nearby because few things will take apart to replace it.
    Please ask local tech to come out and replace it.
    Thanks.
Color code wiring for 2007 dodge 3500 4x4 tail lights and reverse light
Left
TAIL/STOP/TURN lamp: WHT/DK GRN
TAIL/TURN lamp: WHT/YEL
BACK-UP lamp: WHT/LT GRN
Right
TAIL/STOP/TURN lamp: WHT/YEL
TAIL/TURN lamp: WHT/GRY
Sep 16, 2016 | Dodge Ram 3500 Cars & Trucks
Replaced lamp on my Mitsubishi 82 in dlp. after 15 minutes pic started to flicker losing color. was advised to also change lamp ballast, did that but still flickers with new lamp. put old lamp back in tv...
When you put the old lamp back in did the picture look OK? If so why did you replace to begin with? Yes, there are some poorly manufactured lamps out there, where did you obtain the replacement? Was it true OEM?
Dec 04, 2014 | Mitsubishi Wd-82837 82" Inch 3d Full Hd...
What should i do create my own email on my phone?
You didnt tell me wht handset u r using. If its nokia (Symbian S60 v-3 or above)then u have to go to MESSAGE-EMAIL-CREATE. If u r using android then u will get get a precise email app with gmail app. U hav to just tap the app and put your id-password. Dont forget to mention incoming & outgoing server as IMAP & SMTP. Pls revert if any confussion.
Dec 01, 2014 | Cell Phones
Where can i find a wiring diagram for neutral safety switch for 2003 neon
The DK BLU/WHT wire from 15A fuse 10 in the fuse block connects to terminal 2 of the brake transmission shift interlock solenoid. The WHT/PINK wire from the brake lamp switch connects to terminal 1.
Apr 09, 2013 | 2003 Dodge Neon
I hav a cannon lazer printer 4350 its giving me error 225 pls help
You need to replace the scanner lamp (cis lamp),you must unzip the scanner,is simple you undo 4 screws under the panel above the scanner and then another 4 and so reach the lamp.E225 error means you need to replace the scanner lamp.If i have been useful plese give me a vote :).Thanks
Apr 06, 2011 | Canon Office Equipment & Supplies
Unlock code for htc s710
Try Hard Resetting it. It brings your phone to Manufacturers setting. Though You'll be loosing all your data (Try syncing with your comp if you can) but you'll be able to use your handset. Just go through your user manual for the hard reset.
Feb 26, 2009 | HTC Touch Cell Phone (Unlocked) - Soft...
Reset lamp counter for zenith z52dc2d
Go to stand-by mode press "?" key on remote. then press 9 8 7 6 and the ok button. the 3 led lights will flash to verify the lamp timer was reset
Oct 30, 2008 | Televison & Video
Mitsubishi WD-62525 Red Status Light After Cap Replacement
maybe this help you, let me know. good luck
ok here new tips on v26 chaiss cust install new oem lamp with led lamp just blink only many time install new balister still shut down no audio no hv at all come with code 34 for test turn out to be that in power supply ther caps that wher blow up 3300 mf at 16v two them c9a38 ad c9a36 both same also note c9a62 1000mf at 16v thru c9a52 ad c9a82 ad c9a61 all 1000mf at 16v install 63v at 1000mf all same with both 3300mf at 25v fix the set now turn on with great pix cust old lamp too dark for pic install new lamp pic better ad reset lamp timer all good cust happy that cust got from mist the power supply board from looking from back of the set on left hand side all way in front u hav pull whole dmb bd to get to it want lets yu guys know[john leyva american video service center ] the right model number is this WD52525 HIT BAD KEY THIS RIGHT MODEL NO WD52525
Sep 09, 2008 | Televison & Video
Sound troubleshoot
first thing you can do is uninstall 11 and then reinstall it. but before you install media player 11 again uninstall the previous version 11 doesn't upgrade ..what sound device do you have???
Aug 18, 2008 | Creative Labs Sound Blaster Live! 5.1...
Desktop screen is stretched abnormally
please trie and double check the resolution on the screen that its correct.
Also check so you dont use too much Hrz on the monitor/settings.
Jul 14, 2008 | SAMTRON 55V 15" CRT Monitor
Televison & Video Logo
26 people viewed this question
Top Televison & Video Experts
