Question about Danby DDR401 Dehumidifier
Slow flushing toilet.....won't pull all the material down the drain....used to work fine.....tried plunging....tried drain snake.....used a coat hanger to **** the holes under the rim, nothing worked.....I am trying CLR down the pipe in the tank......another brilliant ideas
  • 6,927 Answers
There is either something lodged in the bottom ,in the toilet,or the drain is restricted with something on down in the sewer drain.
Posted on May 26, 2010
  • waynebaenen Oct 11, 2010
    how do you get a lodged object out of the toilet when it wont move either wayu
  • Ronny Bennett Sr.
    Ronny Bennett Sr. Oct 11, 2010
    remove the toilet and reach inside from the bottom
Bucket removal is extremely difficult. What should I do?
There's usually a piece or tubing that hangs down into the tank and you need to pull your tank past this when removing it to drain your dehumidifier. Are you lifting from the top or bottom? Try the opposite of what you are doing. Sorry I don't know your model specifically, but often there's an outlet or cap at the bottom of the tank that can have a plastic piece of aquarium type tubing hooked to it. This way if you can elevate the whole dehumidifier, say on a counter, the water can just drain into a sink or if you're a real conserver into a storage tank to use to flush your toilet or water your grass.
Jan 21, 2015 | Comfort-Aire BHD-501 Dehumidifier
How do I connect my dehumidifier with a hose directly to a drain
Are you much of a handyman? Most folks set their dehumidifier on a counter or elevated and run the exhaust tubing right into a sink or toilet. You could collect the water to flush a toilet or water the grass if you are handy. I've never seen anyone connect directly to a drain though.
Jun 04, 2014 | Comfort-Aire BHD-501 Dehumidifier
Just bought this unit and it wont drain out the hose just keeps filling up the bucket.
When this happens with a brand new unit, there are a couple of things that can be causing it:
The drain hose/garden hose you're using is to long. It should not exceed 48" in length and must slope down and straight to the floor drain.
A piece of packing material or debris is in the hose concector and inner tubing. To remove this clog, turn the unit OFF & unplug it. Then Using an appropriately sized, 18" long, plastic Zip Tie, carefully insert the tip of Zip Tie into the hole or tubing. Continue to push it in until you reach a bend in the tubing. You will need to gingerly work the Zip Tie past this bend, until it either bottoms out or you run out of usable Zip Tie. Then slowly pull the Zip Tie back out while rotating (twisting) it. This will breakup any clogs. As you reach the inserted end of the Zip Tie, be prepared, as some water may follow. Reconnect the hose, plug the unit in and turn the Master ON/OFF Switch to ON. Set the humidity extraction level to 35% . Allow the unit to run, while you monitor the hose end for water flow. Be patient, as it may take 5 to 10 minutes to start flowing.
NOTE: If you don't have a Zip Tie, you may use something similar ( i.e.a long pipe cleaner), but NO wire coat hangers.
I hope this helps you to troubleshot & solve the problem. Thanks for choosing FixYa.
Sep 23, 2011 | Frigidaire FAD504TDD Dehumidifier
I got a new Whirlpool dehumidifyer (AD50GEUSX) I put the hose in and the green light on "continuous" and the water will not go through the hose. The machine stops when the bucket is full. Your...
Christianeta, first let me clarify one thing. The FixYa website you posted the problem on, is not the Whirlpool website, nor the Canadian Tire website.. And we don't sell appliances of any type. But, I can help you with your problem.
Despite it being a new unit, there may be some packing material clogging the inner tubing of the the hose connection. Or the hose you're using is to long (over 48") or is kinked or is not sloping down and straight to the floor drain. It relies on gravity to drain, so it will not drain up. When any of the aforementioned happens, water is diverted into the water collection bucket.
To clear any potential packing material or a clog from the inner hose connection tubing, please do the following:
Turn the unit OFF and Unplug it and disconnect the hose.
Using an appropriately sized, 18" long, plastic Zip Tie, carefully insert the tip of Zip Tie into the hole or tubing. Continue to push it in until you reach a bend in the tubing. You will need to gingerly work the Zip Tie past this bend, until it either bottoms out or you run out of usable Zip Tie. Then slowly pull the Zip Tie back out while rotating (twisting) it. This will breakup any clogs. As you reach the inserted end of the Zip Tie, be prepared, as some water may follow. Reconnect the hose, plug the unit in and turn the Master ON/OFF Switch to ON. Set the humidity extraction level to 35% or Maximum if you have a manually controlled unit. Allow the unit to run, while you monitor the hose end for water flow. It may take 10 to 15 minutes for water to start flowing. So, be patient.
I hope this helped you. Thanks for choosing FixYa.
Aug 24, 2011 | Whirlpool AD50USS Dehumidifier
It runs but leaks water, water won't stay in bucket
Denise, there are several things that can cause the problem.
1. The water collection bucket is not installed properly. Turn the unit OFF and remove the bucket. While you have it out, look at the top of the bucket, is there a float valve near the top. If so, it may be stuck in the DOWN position, which tells the dehumidifier the bucket is not full yet. Jiggle the arm of the float valve to see if it moves freely. Reinstall the bucket bucket "squarely" from top to bottom into it's holder. The bottom should not tilt down at all, if installed properly.
2. The drain tube to the bucket may be clogged. To solve this problem do the following:
Remove the water collection bucket and look up inside the bucket holder cavity. You will see either a drain hole or small tubing that drains the water into the bucket. Using an appropriately sized, 18" long, plastic Zip Tie, carefully insert the tip of Zip Tie into the hole or tubing. Continue to push it in until you reach a bend in the tubing. You will need to gingerly work the Zip Tie past this bend, until it either bottoms out or you run out of usable Zip Tie. Then slowly pull the Zip Tie back out while rotating (twisting) it. This will breakup any clogs. As you reach the inserted end of the Zip Tie, be prepared, as some water may follow. Reinstall the bucket, plug the unit in and turn the Master ON/OFF Switch to ON. Set the humidity extraction level to 35% or Maximum if you have a manually controlled unit. Allow the unit to run, while you monitor it for any leakage.
3. The water you're seeing may not be from the bucket overflowing or leaking. It's condensation that is has built up on the cooling coils and is dripping down under the unit. If this is the case, it's an indication that the coils are dirty and need to be cleaned. Warm water and dish washing liquid works well to clean the coils. Be sure to rinse them with a damp rag, dry thoroughly and spray a light coating of WD40 on them.
I hope that all the information I have provided will help you troubleshoot and solve the problem. Thanks for choosing FixYa.
Aug 19, 2011 | Goldstar DH504EL Dehumidifier
DEHUMIDFIER STILL WORKS JUST WONT DRAIN WITH HOSE.
If it won't drain thru the hose, but is draining into the bucket instead, the problem lies either in the hose or the hose connection on the unit. Either one of the other is clogged. Remove the hose first and check for a clog, If none there, it's in the hose connection on the unit.
Use an 18" long, plastic Zip Tie appropriately sized to fit in the hole. Or something similar (NO wire coat hangers, though) and carefully insert it into the hose connection opening. Continue to insert it, until you reach a bend in the tubing. Work it gingerly pass this bend, until the Zip Tie bottoms out or you run out of usable Zip Tie. Then, while rotating (twisting) it, slowly pull it back out. As you reach the end, be prepared for some water to follow.
Also, keep in mind the hose should be no longer than 5 feet and slope downward from the humidifier. It has no pump and relies entirely on gravity to drain the water.
Hope this helped you to troubleshoot and solve the problem. Please be kind enough to let me know. Thanks.
Jun 10, 2011 | Maytag M3DH30B2A Dehumidifier
I have an LHD6594EBL dehumidifier that won't run and it keeps saying the bucket is full but the bucket is empty, we have a hose attached and don't use the bucket,
Sue, if you haven't noticed any water draining from the hose recently, it may be that the hose connection and tubing of the unit are clogged and the drained water pressure is causing the unit to show "Bucket Full." Also, if the bucket is not properly in place, whether you use the drain hose or not, it will cause the unit to stop functioning. You know how to correct that, so I won't go into detail on that issue.
To unclog the drain, you will need an 18" long, plastic Zip Tie or something similar (NO wire coat hangers though) that will fit into the hose connection. TURN THE UNIT OFF AND UNPLUG IT. Then carefully insert the Zip Tie and continue to push it in until you reach the bend in the tubing. You will have to carefully work it past this bend, until it either bottoms out or you run out of usable Zip Tie. Now, while rotating it, slowly pull it out and be prepared for some water to follow.
Hope this helped you troubleshoot and solve the problem.
Jun 01, 2011 | LG LHD659EBL Dehumidifier
I bought the eva dry e-333 on 4/30/11. I placed it near my toilet tank in the bathroom. Everything was working fine until two or three days ago. I noticed that the tank had water condensation and the eva...
You are trying to fix the symptoms rather than the problem. The problem is the water going into the tank is colder than the air in the bathroom, which cause condinsation on the tank. If you can, take the chill out of the water. By exposing the pipes, which may cause the pipes to sweat. Or cool the room air. Is the bathroom vented so that the warm moist air is carried outside? There are liners that go in the tank that work well. If you use a liner make sure you will still have enough water to flush with, as they will take up some of the water volume.
May 27, 2011 | Eva-Dry E333 Dehumidifier
Both drain hole are blocked & the water is
Remove the cabinet: take out bucket and remove all visible screws; sometimes the plastic cabinet parts also snap together or the top actually has plastic hooks that engage so it has to be slid front or back 1/2" - just be very careful after you remove all screws to determine what is still holding it together BEFORE applying any force.
Once the cabinet is off, the coils are exposed in the front, and the drain pan is under then. Be careful to not damage the coils or bend them. Flush/blow into drain tube or snake with flexible wire to open then, clean out all sludge and lint, and check to make sure drains still open, then reassemble.
Jan 07, 2010 | Danby DDR586R Dehumidifier
Water will not go down drain tube
Sounds like you have a clog. Either try plunging the drain in the stationary tub or replace the line from the humidifer.. Just a thought
Jun 10, 2009 | Danby DDR586R Dehumidifier - 58 Pints...
Danby DDR401 Dehumidifier Logo
76 people viewed this question
Top Danby Dehumidifiers Experts
Bill Long
Colin Stickland
Colin Stickland
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Danby Dehumidifier Expert? Answer questions, earn points and help others
