Question about GE GSH25JFR Side by Side Refrigerator
Refrigerator problem th efrezzer and refrigerator are not working but the inside and the outside fan are working what could be the problem
    Scholar:
  • 59 Answers
There are 2 wires going into the compressor. They go to an overload and a relay. If the fans are operating and you have no power to those 2 wires you are going to need to replace the main board.
Posted on May 27, 2010
My lg gm-313sc keep on work and stop in lest than 3 minits
The refrigeration is short cycling. The cause may be due to airflow problem. There is an outside fan thalt blows across a radiator and another in the inside the fridge enclosed behind panels.
These two fans must run and blow across the refrigeration radiators. The outside one can clog with lint and dirt, the inside one can clog with ice buid up, or the fans simply quit working. Check that the fans run and that the radiator coils are clean and clear to airflow. For the outside one, paneling will need to be removed, as well for the inside one if the outside one does not do the trick.
The refrigerator compressor short cycles because it overheats. The cool refrigeration gas entering the compressor cools it and when the gas is not kept cool, the compressor may short cycle.
There may be a different problem but checking for airflow is a start.
Jan 06, 2015 | LG Refrigerators
Both my refrigerator fans (circ fan freezer / icemaker fan) are very loud. They both started doing this at the same time.... quite odd I know. I fix about everything but need to knownhownto get to th
They are inside. First I would completely thaw both sections out, add an external fan blowing in. This will remove any moister that is frozen around the fans. While this is happening clean the condenser and when you start it up check the condenser fan.
Dec 11, 2014 | General Refrigerators
Kenmore coldspot 106.53769202 will not cool fridge, have deg=frosted,vacuumed underneath and emptied drip pan, no air blowing into fridge. Had gnats inside while power was off for over a month.
Does the compressor run? Does the small tube get warm? is the inside fan working? does it have an outside condensor fan? Is power getting through the thermostat due to gnats between the contacts? Does the inside light work? need more info.
Oct 16, 2013 | Kenmore 50522 / 50524 Side by Side...
GE PTS25LHR refrigerator temp at 50 degrees
You need to replace the mother board located on the outside rear wall
Jul 25, 2012 | GE Refrigerators
Freezer works great but the refrigerator don't work. any ideal
Remove any things that will hindrance or block to the flow of cold air inside the refrigerator. Often the fan is block with food stuff or bottles, cans of drinks. Rearrange it correctly and also clean the fins of fans. Pullout unnecessary things and clean the inside. Put some allowances to the things inside. Overloading of food stuff really make it hard for the refrigerator to cold it. It takes longer for a overload food stuff to eliminate heat outside and cool then cold it.
It's a pleasure to help you.
Jul 03, 2011 | Dometic RM2852 Refrigerator
Nordyne AC unit works at first but later provided cool air. Thermostat set to 65. Power running to unit outside. Noticed ice around line outside and can send a picture. Chipped ice away. Want to know what...
If the inside fan motor is running OK you are low on refrigerant. If the inside fan motor is not running, repair the inside fan motor. Could also possibly be dirty inside coils.
Jul 20, 2009 | Heating & Cooling
Amana Top Freezer Refrigerator is hot to the touch on the outside on the sides by the freezer. Still working fine inside. Is something getting ready to break inside?
The problem was the fan. It was hitting the metal enclosure and had stopped working. We made an adjustment and cleaned it and now it works fine and the hot spots are gone.
May 04, 2009 | Refrigerators
GE GSS20IEPAWW Freezer Not cold outside of freezer very HOT
check to make sure that the fan in the back is working and then clean the condenser coil underneith the frig
Apr 26, 2009 | GE GSS20IEPWW / GSS20IEPCC Side by Side...
Amana refrigerator will not chill
That model number does not come up for me.
Click on and enter model number
http://www.searspartsdirect.com/partsdirect/index.action
Jan 10, 2009 | Amana BC21V1W Bottom Freezer Refrigerator
GE GSH25JFR Side by Side Refrigerator Logo
143 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
