Question about Indesit 24 in. DE73 Evolution Free-standing Dishwasher
Indesit evolution de73 dishwasher
Dial flashing saying ao1
  • teritadpole Jul 15, 2008
    my dishwasher is giving me the error code ao1.
    its driving me nuts now and has flooded my kitchen floor.
    is it repairable or should i just go and buy a new dishwasher?
    can anyone advise?
  • ritareserved Dec 10, 2008
    There is A02 error message flashing. What can I do?
01 = Acquastop operated due to leak / overfill - machine drains until empty + lmin.
A02 = Heater Relay open circuit/short circuit or Thermistor or Safety T/Stat o/c or s/c or Element machine fills to Level Switch & Wash Pump runs.
A03 = Thermistor open circuit /short circuit - machine drains until Level Switch resets +1minute
A04 = Unable to sense/reach temperature in 70mins. - machine drains until Level Switch resets + lminute
A05 = Level Switch not resetting in within 3' 20" of drain commencing - machine drains until Level Switch resets +1 minute
A06 = Not used see also H20 at end
A07 = Wash pump Triac closed/open circuit - check that Drain Pump is not disconnected or Aquastop operated
A08 = Auxiliary Wash Pump Triac closedlopen circuit - check Wash Motor operation- machine drains until Level switch resets+30"
A09 = Main Wash Pump Triac closed/open circuit - cheek Wash Motor operation- machine drains until Level Switch resets+30"
A10 = Fill Solenoid valve Triac closedlopen circuit - check valve/operation - machine drains until Level Switch resets+30"
A11 = 1/2 load Solenoid Valve Triac or alternating Wash Motor action - check Solenoid Valve operation & alternating Motor action, replace Module if required - machine drains until Level Switch resets +30"
A12 = Relay with open circuit - check Heater, replace Module if required - machine drains until Level Switch resets+30"
A 13 = Dispenser Triac incorrect operation closed/open circuit - Wash Cycle completes but with Dispenser Lid notfunctioning correctly
H20 = Static 'Fill Time exceeding 6 minutes - cheek for blockages/low pressure
Posted on Jul 16, 2008
Code A13 FLASHING WASHER REFUSES TO START AT ALL
Posted on Sep 06, 2008
Indesit dish washer is showing error code A08 why
from what i can find out, it means (auxillary wash pump triac cloesd/open circuit)
Sep 25, 2011 | Indesit 24 in. DE73 Evolution...
Error code a14 on indesit evolution de73
A fault with the water heating has occurred. Book a service engineer
Sep 07, 2009 | Indesit 24 in. DE73 Evolution...
My dishwasher has a box with a fashing s in it with dots beside it what is it
i looked on the indesit web site and got the manail for it. it means it has low salt
Mar 02, 2009 | Indesit 24 in. DE73 Evolution...
A05 code
ao5 is showing on the display of my indiset de73 dishwasher
Aug 19, 2008 | Indesit 24 in. DE73 Evolution...
De73 evo
A01 keeps coming up. Can you help
Nov 07, 2007 | Indesit 24 in. DE73 Evolution...
Flashing star sign
Try turning off the breaker to it for a few min… and then turn it back on that might reset it.
Indesit evolution DE73 frozen program
I have the same problem. You need to switch it off at the mains for at least 20 mins.
Aug 14, 2007 | Indesit 24 in. DE73 Evolution...
Indesit DE73 showing A08 fault code
Sounds like it has overflowed at some stage. Ensure the filter is cleared and then rock the dishwasher backwards. Any trapped water will drain out and the safety valve will reset. i had similar and this was what the indesit technician did.
May 21, 2007 | Indesit 24 in. DE73 Evolution...
Indesit evolution de 73 dishwasher with an AO5 error code
a05 is pressure switch not reset. check for blockages in the drain pump, filters and sump
May 06, 2007 | Indesit 24 in. DE73 Evolution...
Error code AO1
Error message A01 means -Acqua stop operated due to a leak or overfill. Check if there is still water in the machine after it stop pumping. In case you still have water - your problem is with the pump or with a blockage drain line. If there is no water in the machin, it might be a water level sensor issue - stuck physically in the high level position or become defective. Try to reduced the water presure and leveled it up by the water entrance tap to the machine, it might solve your problem. Goog luck !!
Jun 27, 2006 | Indesit 24 in. DE73 Evolution...
Indesit 24 in. DE73 Evolution Free-standing Dishwasher Logo
1,549 people viewed this question
Top Indesit Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Eric Taylor
Are you an Indesit Dishwasher Expert? Answer questions, earn points and help others
