Question about Infinity Reference 1252W Subwoofer - 12" Dual 4 Ohms Polypropylene Cone Butyl Rubber Surround Car Speaker
I have a four channel rockfor fosgate amp and I need to know hows the best way to connect Infinity Reference 1252w Car Subwoofers
    President:
  • 676 Answers
Rockford fosgate usually work best with 2 ohm speakers. Depending on the resistance of your speakers, will then give you best connection. Check the resistance for the subwoofers. If the subwoofers are two ohm then connect them directly right and left. But if they are 4 ohm connect them parrallel (positive to postive, negative to negative and bridge the amp.) Good Luck, please rate.
Posted on May 27, 2010
What are some best cheapest bass amp under 500$?
'Best' and 'Cheapest' are seldom in the same category, but have a read of these links.
12 Best Subwoofer Amplifiers for Your Car or Truck - BestProducts.com
www.bestproducts.com/cars/parts/g662/subwoofer-amplifiers-for-your-car/
  1. Cached
  2. Similar
Jul 19, 2016 - If you want big bass, choosing the right subwoofer is only half the battle. Be the loudest car on the block with the help of these new mono amplifiers for your car or truck. ... 14 Best Rubber Floor Mats for Your Car or Truck.
Best Car Amplifier 2016 ' Top Rated Auto Amplifiers - CarAudioNow
https://www.caraudionow.com/best-car-amplifiers/
  1. Cached
Looking for the Best Car Amplifier of 2016? ... And if you are going to add a subwoofer, a monoblock amp is an absolute necessity. ..... Two-channel A/B ZRX516.2, 500 watts; Four-channel A/B ZRX616.4, 600 watts; Four-channel ... (PCBs) that can perform under the most rigid and extreme conditions attesting to the brand's ...
Bass Packages Under $500 at Crutchfield.com
www.crutchfield.com > ... > Car Audio, Video & GPS > Car Subwoofers & Boxes
  1. Cached
Under $500 - Shop for Bass Packages with the help of real A/V experts. ... package includes Magna Bass MB212P mono amplifier (250 watts x 1 at 4 ohms) and ...
Can you guys recommend me a combo amp under $500? ' TalkBass.com
https://www.talkbass.com > ... > General Forums [BG] > Amps and Cabs [BG]
  1. Cached
Jan 19, 2012 - Hey guys, I'm currently in middleschool and I need a new amp thats preferably 400-500 watts, but under $500. We currently have a bassist, ...
Need good advice on a sub+amp combo, $500ish budget - Car Audio ...
www.caraudio.com > Forum > Car Audio Discussion > Subwoofers
  1. Cached
  2. Similar
Oct 13, 2012 - 12 posts - ‎1 author I'm new to both the forum and somewhat new to car audio in general so please excuse any ... So i need a great sub and amp to complement them for around $500. ..... other subs for under 200 bucks id rther have over type r
World Record Budget Build w/ Drew Wesley's $500 Car Audio System ...
z? 2:32 https://www.youtube.com/watch?v=NOatL_DzZL0
  1. Similar
Oct 3, 2013 - Uploaded by EXOabigdeal World Record Budget Build w/ Drew Wesley's $500 Car Audio System ' 4 12" VVME Subs & Bass Amps ...
Top 10 Best Car Amplifiers To Buy for 2016 - MyCarNeedsThis
mycarneedsthis.com/todays-best-car-amplifiers/
  1. Cached
Whether you're looking for an amplifier to power your entire cars component speaker ... power outputs come in 3 settings (of 800 watts, 500 wats, and 300 watts ). ... Rockford Fosgate R750-10 Class D 4-Channel Subwoofer Amplifier ... Talk about power when it comes to getting some serious knocking under the trunk.
Oct 30, 2016 | Car Audio & Video
I need to wire up a rockford fosgate punch hx2 12" subwoofer to a 500 watt single channel amp and i need to know how to wire the dual voice coil properly ??
Wire it in a series. One wire from amp positive to one positive speaker terminal. One wire from amp negative to negative speaker terminal. This should leave one positive and one negative termianl on the sub. Use one additonal wire to connect these two, this wire should not be connected to anything else other than the two remaining terminals. This will allow you to have the music up louder with higher amp settings without having to worry about blowing the speaker as easily.
Jun 24, 2010 | Rockford Fosgate Punch HX2 RFD1212 Car...
How to wire 12 in sub 1252 infinity
http://www.rockfordfosgate.com/rftech/woofer_wizard.asp
go here put in your specs and you have your answer :]
Oct 04, 2009 | Infinity Reference 1252W Subwoofer - 12"...
Car amplifier
HI PAL BUY MONOBLOCK AMP TO DRIVE UR SUB TRY GET ROCKFORD FOSGATE, KICKER,BMBOSCHMANN,OR INFINITY
Jun 03, 2009 | ElectroVoice EVM10DLX Car Subwoofer
2 sets of pos. and negs. on 10" infinity reference 1052w
This means you have a dual voice coil sub. It is probably a dual 4 ohm voice coil. If you hook up the left channel to one input and the right to the other you can safely push the sub but the amp will be running at a lower efficency. In other words it isn't the best amp for the job because it can't push max power to a dual voice coil speaker but it will work.
Jan 30, 2009 | Infinity 1250w Car Subwoofer
Inifinity 1252w subwoofer
this is probably due to the box they are in. it seams that your box is tuned to a lower freq then the bass hits that are popping. message me with the box dimensions and the speaker parameters
May 28, 2008 | Infinity 1250w Car Subwoofer
Subs
First of all you need to check if your amp can support this type of speaker setup? If you are simply going to wire 2 subs up to the amp (assuming a 2 channel amp) it's pretty simple. Just connect the + & - cables to one channel of the amp & the other ends of the cable to the sub, making sure that they are the correct polarity on both sides (ie speaker & on the amp).
If on the other hand you want to 'daisy chain' the subs onto one channel of the amp (this effectively drops the load down to half that of the speakers (usually 2 Ohm)), then you do as the name suggests. Simple connect one speaker cable to the amps channel 1 + ve output to subs_1 +ve input. Then from sub_1 -ve connector to subs_2 +ve. This leaves you with only 1 more to connect sub_2 -ve back to amp channel 1 -ve.
NOTE: make sure that your amp can support this first! If it can't then it's will auto switch off in most cases but can also damage the amp if there is no fail safe circuit built in.
Dec 24, 2007 | Rockford Fosgate FNQ1404 Car Speaker
Trying to wire my amp to my subs
no thats not it you are lucky you havent burned it up like that. wire each speaker to its own source positive and negative, you loose power when you bridge an amp and use two speakers, its best to hook up without bridging you will get more volume that way.
Dec 18, 2007 | Infinity Reference 1211a Car Audio...
Car Audio & Video Logo
198 people viewed this question
Top Infinity Car Audio & Video Experts
xxxxxx xxx
Tygh Duval
Tygh Duval
Colin Stickland
Colin Stickland
Are you an Infinity Car Audio and Video Expert? Answer questions, earn points and help others
