Question about Bissell 1950-3 Quicksteamer Plus Vacuum
Where can i order a quicksteamer plus 1950 clean water tank?
  • 276 Answers
I had a look at the Australian variant of this model and located parts number 407-0931 Clean Water Tank.
My best suggestion is that take this part number and contact your local Bissell Service Center, go to the Bissell International website to locate information for your country.
Posted on May 27, 2010
Instruction to put it together
Bissell has the assembly instructions in the manual for the unit. Most Bissell manuals are available here: http://www.bissell.com/user-guides/ . The direct link to the manual for 1950 series Quick Steamer is http://www.bissell.com/user-guides/DownloadAsset.aspx?id=567 .
I hope this helps. Out of the box, the assembly is very simple. Put the handle on the lower body and secure with a Philips screw. The water tanks lift off and then get placed back on the body of the unit. (Use care when the tanks are filled with water.) See the manual for adding the bare floor tool.
Oct 15, 2015 | Bissell 1950-3 Quicksteamer Plus Vacuum
How can I clean or open the bissell quicksteamer dirty tank
Hi Deni! The collection tank can not be opened for cleaning. You may want to fill the tank with some hot tap water and let it sit for about 30 miutes.
Here's a link to our website if you decide to order a new tank.
http://www.bissell.com/parts/?id=9143&sc=part&partid=4482&cid=ccsocial
Jan 16, 2013 | Bissell 1770 Quicksteamer II Upright...
I have a Bissell Quicksteamer plus model # 1950 and when I plug it in it begins to heat the water then trips the circuit. Can this issue be corrected?
Have you cleaned the tanks recently? If not do it.
Remove water from the solution tank and collection tank.
Keep the tanks open and allow to dry in sunlight.
If you can, remove the solution tank and see whether there are any leakage signs where the tube connects to the solution tank. If there are, use an adhesive that can withstand heat and stops the leak.
You can also contact Bissell consumer service on 1-800-237-7691.
Aug 07, 2011 | Bissell 1960-3 QuickSteamer Plus Upright...
Can this model clean tile floors
Well the answer is yes, yes you can use it to clean tile floors.
Good Luck!!
Thanks for using FixYa!!
Jan 26, 2011 | Bissell 1950-3 Quicksteamer Plus Vacuum
Need to download PDF format Parts Manual for Bissell 1950-3 Quicksteamer plus -- is there one available?
BISSELL User's Guides can be downloaded at www.bissell.com
On the front page under Customer Service click on User's Guides and enter the model number of your unit.
User Guide will be displayed as a PDF file.
Sep 19, 2010 | Bissell 1950-3 Quicksteamer Plus Vacuum
I have a bissell quickwash model 1950 j 02175. it
the pump belt is off or broken, sometimes when you put too much soap or cleaner in device the belt will slide off the end of the roller, use pinesol to clean this works and doesn't do that, not too much cleaner.
Jul 19, 2010 | Bissell 1950-3 Quicksteamer Plus Vacuum
Won't extract water from carpet.
Seems the 1950W is now obsolete, cna't even bring up a drawing of it. Usually when the vac. motor is running, then there has to be suction. But if a seal or gaske is missing, then the suction will be lost. So you might check the dirty water tank to make sure there isn't a part missing or out of place. Check this out, it is for a 1950-3:
http://bissell.com/images/schematics/1950.pdf
Jan 29, 2008 | Bissell Powersteamer 1694 Upright Vacuum
Cleaning
Either you have a pinched or clogged water line, or the rod in the handle is pushing down like it should. The drw back is Bissell has deemed this unit and its parts obsolete. So any parts are hard to find.
Nov 04, 2007 | Bissell 1950-3 Quicksteamer Plus Vacuum
Bissell 1950-3 Quicksteamer Plus Vacuum Logo
339 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
