Question about Bosch 24 in. SHY66C05 Stainless Steel Built-in Dishwasher
Dishwasher will not start. Several cycle buttons
Dishwasher will not start. Several cycle buttons are lit up and the display panel shows a P
  • Anonymous Mar 24, 2014
    dishwasher will not cycle, h:15 on display panel
    Sergeant:
  • 228 Answers
Check carefully on display buttons 2 buttons are marked reset push these together as you turn mchine on this should clear error if not you may have control pcb fault will need service tech.
Posted on May 27, 2010
Our 2 draw dishwasher stops mid cycle once or sometimes several times. The red light comes on and it bleeps until we press the start button then it will continues the cycle.
The red light and beeping indicates a fault. The fault code number will be indicated in the display or by other LEDs being lit. If you post back with the details of the display we may be able to help you.
Jan 25, 2015 | Fisher and Paykel Dishwashers
Lighted "3" shows, dishwasher won't start
PRESS AND HOLD THE BUTTON NEXT THE LOCK3 LIGHT FOR 3 SECONDS TO UNLOCK THE CONTROL PANEL. TO RELOCK THE CONTROL PANEL PRESS THE SAME BUTTON FOR 3 SECONDS. THANKS AGAIN
Apr 20, 2014 | Maytag MDB7100AWB Dishwasher
Howdens dishwasher hja8362
The water in the machine is normal there is nearly always 1/2 a lit to a lit of water when a load is finished. Also if you dishwasher is out of warranty there Re a few things you can do one go buy a $20 voltmeter and unscrew the face plate and see if anything is lose mine hade a wire come lose and made the hole thing misbehave.
Jan 26, 2014 | Dishwashers
Reset button maytag dishwasher
  • 1 Open and close the dooricon1.png of your Maytag dishwasher.
  • 2 Locate the "Rinse" button on the dishwasher control panel. Press and release the button five times in quickicon1.png succession.
  • 3 Press and release the adjacent "Drain/Off" button on the control panel two times; this will deactivate the dishwasher's demo mode and reset your dishwasher.
  • If you need to restart your dishwasher or forgot some dishes and want to open it during a cycle and restart it
  • 1 Press the "Cancel Drain" button on the display. Allow about 2 minutes for the dishwasher to completely drain.
  • 2 Choose a cycle under "Cycles" on the panel.
  • 3 Select an option or options under "Options" on the panel.
  • 4 Push the "Start Resume" button.
  • Oct 24, 2013 | Dishwashers
    Display not showing
    have you pressed the home button? on many systems the display times out after several minutes and you have to press the home button. If that is not the solution try power cycling your system. Dis-connect the battery inside the panel and the power and then reconnect the batter and then the power. You will have to wait a minute or two for the panel to power cycle up. Always call your monitoring station before opening the control panel and advise them you are doing so.
    May 11, 2013 | 2gig Z-wave Wireless Control Panel Cntrl2
    Are lights supposed to be on when the dishwasher is running and the door is closed?
    The buttons and the display panel are not lit when the machine is running. This is to save energy according to frigidaire. I wish I had know this before purchasing it about a year and a half ago. The cycle count down timer was a big reason I purchased this one, but what good is it if it only works when the door is open?
    Jan 15, 2013 | Frigidaire FPHD2491KF Dishwasher
    My new bosch axxis washer was20160uc does not start
    Open the dishwasher door if the desired cycle does not perform as selected on the control panel. Press the main power switch "Off" and then "On" again. Select a cycle, press the appropriate button, press "Start" and close the door. Make sure the door is closed completely.
    Check the circuit breaker and water supply if the dishwasher does not start after selecting the appropriate cycle on the control panel and shutting the door.
    Turn "Off" the dishwasher and disconnect the dishwasher from the power supply if an error code between "E01" and "E30" appears on the digital display. Reconnect and turn the dishwasher "On." This should reset the control panel.
    Terminate a program on the control panel by holding the "A" button and pressing "Start" at the same time. The display will read "0:01". Close the door to start the program sequence. The display will read "0:00" when finished.
    Oct 15, 2010 | Dishwashers
    I have an electrolux edw5505eps dishwasher. The control panel start button does not function, the delay button does noy cycle thru the delay time. Does the panel need to be replaced?
    check out my thread on a similar issue. If your power button doesn't light and delay button does not light? Is the LCD screen display anything? check out my post several really good check lists.
    Nov 08, 2009 | Electrolux 24 in. EDW5505EPS Stainless...
    Bosch SHU 6800 Water hot at sink only luke warm at the washer
    BAD CONTROL BOARD TO TEST TO SEE IF THIS IS THE ISSUE RUN TEST PROGRAM
    To start test program, press and hold both SCRUB WASH and DELICATE/ECONO program buttons, then turn unit on by
    pressing ON/OFF button. Initially, control module version # will be displayed (e.g./ “20” = version 0 without jumper). When
    wash program buttons are released, lights above them will flash. To end test program, press ON/OFF button.
    To check each program indicator light, press its button. To check Cycle Countdown display, Refill Rinse Agent light and
    REGULAR WASH light, press REGULAR WASH button (press Delay Start button to test Cycle Countdown display
    alone). Cycle Countdown display will show "88" when REGULAR WASH button is pressed and "8h" when Delay Start
    button is pressed.
    To start testing, press both SCRUB WASH and DELICATE/ECONO buttons a second time. When testing has ended,
    Cycle Countdown display will show a fault using codes below. If more than one fault occurs, code numbers will be added
    together, (e.g./ “6” = faults 2 + 4).
    0 = No faults detected 2 = Heating fault 8 = NTC (temperature sensor) fault
    1 = Aqua Sensor ("Sensotronic") fault 4 = Filling fault F = Filling fault (display occurs during wash, not test)
    To check for heater, high limit or flow switch problems, start testing until heating starts. Using a meter with a current coil,
    measure current going into dishwasher. If current is ~ 11 A, then heater, high limit and flow switch are OK. If current stays
    at ~ 1.5-2 A, then heater, high limit or flow switch are faulty.
    If water level switch (f1) has failed (opened), display will show fault code "4" and unit will continually fill and drain where
    testing won't be completed. If flow switch (e5) has failed (opened), display will show "0", water won't heat (to 150ºF) and
    water won’t stop circulating. If NTC probe (f2/f4) has failed (opened), display will show fault code "8" immediately and
    testing will end shortly after water has started circulating
    Jul 18, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
    Bosch 24 in. SHY66C05 Stainless Steel Built-in Dishwasher Logo
    307 people viewed this question
    Top Bosch Dishwashers Experts
    Gerry Harvey
    Gerry Harvey
    shaun taylor
    Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
