Question about LG Vu CU920 Cellular Phone
Wont hold a charge phone shuts off not sure if its the battery or the phone
  • 973 Answers
That symptom is the battery, buy a new battery and it will work like new.
Posted on May 26, 2010
My Samsung 11 wont charge I replaced the battery but it started to hold a charges but it wont now
check to make sure the port isn't loose or damaged. the soldering might have broke from the board
Nov 28, 2014 | Samsung Cell Phones
My phone keeps shutting on and off and wont charge when plugged in
Cell phone batteries have what is called a "memory" over time if they are charged without being fully drained they can start to not hold a charge. Unfortunetly the only fix for an issue like yours is to purchase a new battery. Your local retailer / service provider should have batteries in stock or they can order one for you.
It is recommended to allow the batteries to drain completely before charging, then allow at least 8 hours or more to fully charge. Most cell phone will show a full charge after a few hours, but this is more a fault with the software that check the batteries charge, then an actual indication of the battery being fully charged.
Dec 28, 2013 | Samsung Galaxy Admire 4G MetroPCS
Stuck on start up screen, will not go to home screen
1.Check the device's battery level for at least two bars of strength.
2.If the battery level is low, charge the battery.
3.If the issue is not resolved, remove the back cover.
4.Remove the battery.
5.Wait 10 seconds.
6.Press and hold the W key.
7.While pressing down the W key, re-insert the battery.
•The device restarts and after approximately 15 seconds, the 'Recovery' screen appears
•Release the power button but *continue holding the home button*, for another 30 seconds.
Step
Thanks
Nov 03, 2012 | Virgin Mobile - Lg Optimus Elite Mobile...
My sanyo pm 8200 wont hold charge!
Since the battery and charger are new and yet it does not still hold charge.
Have put the battery in another similar phone and try to charge with your charger to see if it will hold charge? if you have.
It means the charging port of your phone is bad and you will need to replace it.
The charger is not charging the battery in anyway because the charging port is bad, so just change your charging port, your phone will now hold charge.
Take care.
Apr 14, 2010 | Sanyo PM-8200
Phone wont turn on. occassionally says download, occasionally goes to pin code screen and shuts off
Sounds like its your battery not holding charge it may say all is well when charging however if the electrolyte has perished then it won't hold the charge and will fail to produce power when you turn it on.
New cellphone batteries cost about £15 on ebay
Jan 05, 2010 | Cell Phones
My philips cordless phone wont charge with new batteries
try the old battery if you still have it then see if it holds a slight bit more once charged.If it does then go back to the seller of the new battery for a replacement.
Aug 31, 2009 | Philips SINGLE HANDSET USB VOIP PHONE
Wont charge/hold a charge
That definitely is a battery issue. The battery is either Low Soc or it is a failed battery. Most batteries on PDA's usually fail within a year because of the immense amount of use the phone has and the majority of the time the batteries are smaller in a PDA. Take your battery to a service center if one is in your area or call your carrier and inquire about the warranty on batteries (usually 1-year).
Dec 26, 2008 | T-Mobile Dash Smartphone
My phone wont turn on!!!
Your battery might be dead. How long have u had the phone?? i had mine for 1 year and like 2 months b4 i had to buy a new one because it wouldnt hold a charge
Apr 07, 2008 | T-Mobile Dash Smartphone
Phone wont hold a charg and wont turn on
what you have to do is to clean your phone using isoprophyl alcohol i mean you clean the main mother board then you dry it using hair dryer ,after all that try to replace the battery it has reach it death neal the cells inside they are no longer able to hold the charge.advice by dogy.
Jan 04, 2008 | Motorola Mobility RAZR V3c Cellular Phone
Sidekick 3 has black box in middle of screen but wont shut on!!
gets stuck on the key-jump.gif symbol? Do a soft reset @ + 1 + 0 and hold down the W or you can pull the battery out and place it back in while holding the W and see what happens when you startup while holding W. __________________
credit: Sweet Peaches vbmenu_register("postmenu_999614", true); http://www.poweredbydanger.com/forums/showthread.php?t=97974
Nov 08, 2007 | T-Mobile Sidekick® 3 Cellular Phone
LG Vu CU920 Cellular Phone Logo
105 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
