I reecently installed at&t fast access dsl on my desk top computer and installed the Westell router that came with it. I have a new dell laptop I want to add to this wireless router. Dont know much about computers and need someone to walk me through the steps slowly.This laptop has an intergrated 10/100 network card and modem installed.(Dell wireless 1390 802 11 g Mini Card.
  • gbarney58 Apr 07, 2008
    I have already tried that. The wireless network it picked up was W 4615.. When I clicked on it the message read connected with limited access. Nothing else happens. I have the laptop across the room from my deak top comp and only pluged into the power outlet. Any other suggestions.
    How can I get online with my AT & T web page?
    The router is a Westell 327 W.
    Master:
  • 788 Answers
The driver for your Dell wireless card should have installed a wireless client application. If you open up the application you should see all the available wireless networks within range. The one with the best signal is yours, not sure what AT&T would've named it. It may be open then you just need to connect to it and that should be it. If it's secured then you will be asked for a password/key to connect, this would have been provided by AT&T most likely, enter the key and your notebook should connect. If you don't know the key then call customer support, they will have to provide you what the key is.
Posted on Apr 07, 2008
  • Dean Joly
    Dean Joly Apr 07, 2008
    Did you try plugging in the notebook with a network cable directly to the router? If that also gives you limited connectivity you might have a static ip address configured.
    Try plugging it in. Then type cmd in the Run box. Then type: "ipconfig /all" without the quote at the command prompt. Copy the info that provided for us. Thanks.
    Genius:
  • 3,422 Answers
HI,
Can you please tell me which wireless router you have so that i can give you the manual for that model and your problem will be solved.Everything will be explained step by step in the manual with the diagrams.
Goodluck,
Please don't forget to rate the solution.
  • Priya darshan Apr 07, 2008
    Alright Click HERE to download the user manual everything is explained step by step.
    You need to have
    adobe acrobat reader to view the manual in pdf format.
    Click here
    to download it if you don't have..
    Please don't forget to accept the solution no.2 which is mine as fixya .
    Do not rate sol no.1 by mistake..
SOURCE:
I need to know how to hook up a westell versalink ? i dont have directions & i have a dial up connection on my desk top . do i need a server ? i have no idea what to do !!
In order to setup the versalink you need an active DSL account, a phone line cord, a phone jack, a pc or mac, and an ethernet cord or wireless ethernet card. Plug in the phone cord to the phone jack and to the DSL port on the versalink- once the DSL light is solid, plug in the ethernet cord to the computer you have, or enter the wep key on the bottom of the modem into the wireless manager for your system. At that point, if you need further assistance in getting online, contact Verizon or Bell (whichever is your DSL provider)- they can and will walk you through setting up the versalink to connect to the internet.
I’m happy to help further over the phone at https://www.6ya.com/expert/susan_42b401e0b1603d8a
Oct 03, 2010 | Westell Wirespeed VersaLink...
When I hook up my Dell2350 router to my westell dsl modem i can not access internet with my desk top or my laptop. When i disconnect the router I can access internet through dsl for desktop with no...
You will need to check the settings of the router. You are able to go online when you connect the computer directly to the modem. Your internet service provider is DSL. You can try to reconfigure the router. Press the reset button on the router for 30 seconds. release it. unplug the power to the router. plug it back in. wait for 1 minute and try to reconfigure the router. Click Here for step by step set up
Nov 18, 2009 | Computers & Internet
I need help setting up my laptop with my Dsl service. I have a Desk Top computer with DSL and ot one time I had my laptop and my Desk Top pn the same service line. My wireless Gateway 2wire router with...
You can manually go into the network settings and delete the old network configuration, and set up a new one. If all else fails, go to your desktop (which I am assuming connects OK) and check the settings on it, and use those to set up the laptop. Hope this helps
Oct 26, 2009 | Computers & Internet
This is my situation; I have a hard wire connection from my wall phone/DSL outlet to a Westell model C90 DSL router/modem. Since this allows for only one single hard wire connection to one desk top (I have...
So you are connecting the DSL Modem output to the D-Link's LAN port 1, right? In this case, you should connect the DSL Modem output to the D-Link's WAN Port, which is between the power input and the LAN outputs.
If it doesn't work that way, check this out:
http://www.voipmechanic.com/westelltobridge.htm
Aug 24, 2009 | Computers & Internet
DSL line disconnects on WRT54GS only
Try to change the LAN IP address of your router to 192.168.2.1 by accessing the router's Setup page. You also need to set your Westell modem to "full-bridge mode". You need to ask assistance from your ISP to bridge the modem. After that, set-up the Linksys router to PPPoE then power cycle it.
Apr 15, 2009 | Linksys Wireless-G WRT54G Router
Wireless connection set up
Are you trying to hook up the laptop wirelessly to the pc? because then the pc would need to have a wireless card as well....sounds like I need more info, but if you are trying to do what I think you are, you should just get a wireless router instead, hook the pc tower directly to it via ethernet cable, and then setup the laptop to connect to the router. The router would hook to your dsl or cable router....what service do you have?
Mar 10, 2009 | Dell Dimension 3100 PC Desktop
Changing from DSL to Road Runner Turbo
I'm sorry to say but you cannot bypass the modem capability of the DSL Westell Modem/router because that is really made to function as a DSL modem and a router at the same time, so the best way to make everything work here since you change from DSL to Cable internet just need to get a wireless router like a Linksys WRT54G that can make everything work again like before.....
Nov 05, 2008 | Westell Wirespeed VersaLink...
Need the installation drivers
The Westell 327W (VersaLink) combination DSL 'modem', router and wireless access point will, for most people, be supplied with their new DSL service. Were you using a DSL service and suspended or disconnected? You should still have the drivers in your original computer. If not, the DSL people will install from their side.
I'll keep looking for you.
May 04, 2008 | Westell Wirespeed VersaLink...
Wireless connect
Call your ISP and demand a DSL tech visit. It sounds like either you do not have the correct password in your gateway to allow for access OR you have your computers wireless connection trned off. On my dell, i use Intel pro wireless set to connect. Your ISP's csr support should be able to get this up and running for you.
Mar 14, 2008 | Westell Wirespeed VersaLink...
Open Questions:
Computers & Internet Logo
Ekse
Alun Cox
