Question about Nikon COOLPIX L10 Digital Camera
Nikon Coolpix L10 - 'lens error'
Hi there - batteries are charged (thought was this initially) but now when trying to do anything with camera it just comes up with 'Lens error' and a solid red circle containing a '!'. Lens is open fully and have cleaned the lens window..... How can I resolve this please? Thanks, Janiene.
  • janiene May 27, 2010
    Very fast efficient help - solved all problems - cheers!
  • 10,515 Answers
I am Sorry to hear regarding the Problem.This is a ' Lens Problem ' which is Quite Common on these Models.
It is not worth to get it Repaired, as the Cost of repair would be quite high as compared to the cost of the new camera.
There are a number of things you can try:
1. Ensure batteries are fully charged
2. Look carefully between the lens and the camera body for any sand or other dirt etc
3. Try turning the camera with the lens facing down and shake to dislodge anything stuck
4. Try removing batteries and memory card, wait 2 minutes and refit
If no luck then we have to try some things that could possibly result in damaging your camera so should only be tried if happy to take that risk...
5. Try thumping the camera into your other hand, by thumping into your hand you are trying to jar the mechanism loose, by using your hand you will hopefully not do it too hard or it will hurt. You may need to do this a dozen or so times in different places to work. I have found the flat of the camera bottom into the flat of your hand best..
6. If the lens is stuck in the out position then remove the batteries and try twisting the lens first one way then the other, do not apply excessive force when doing this or you can break gears, you are trying to reposition not force... Likewise if the lens looks like it is crooked you can try pushing it back into position. This has a higher chance of doing more harm than the thump so please be careful...
7. Dismantle the camera, not for the faint hearted, you need to dismantle the lens assembly into the main body of the camera
If no luck then only other option is a serviceman I'm afraid, be sure to get a quotes as camera repairs can be uneconomical
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on May 27, 2010
    Thank you! .....when you said to 'twist the lens', I noticed that one of them was slightly crooked. I pulled the part of lens that was in further, out - then the lens went back into camera. All working now. (think I might be buying my 5yr old daughter a 'kids' digital camera!!).
    Cheers
  • taran_2005
    taran_2005 May 27, 2010
    Thanks for your response!!
    Glad that i would be able to assist you.
    Let
    Hope i helped you.
    Thanks
    PS - Do Accept the Solution,if 100% satisfied and close the thread.
Hi I have a Nikon coolpix L10. Took 2 photos, turned it off. Wont start up and red light stays on, any ideas
There is a capacitor dump that you can try.
Remove the batteries, wait 5-10 minutes.
With the batteries out, press and hold the power button for 10 seconds or so.
Put the batteries back in and your camera will start over (re-boot). You will know if it worked if you have to reset the date. But if that lens is really stuck you may be out of luck. The cost to repair it will exceed the cost of a new camera.
Sep 19, 2010 | Nikon COOLPIX L10 Digital Camera
Lenns error
MIne was doing that, but only with one of my two batteries. Never have problems when I have the other battery in the camera, so think the battery doesn't hold a strong enough charge to operate the lens. So I just use it as a spare while the good battery charges.
Get a new battery and see if the problem goes away.
Jan 19, 2010 | Nikon COOLPIX S10 Digital Camera
Lens error on nikon coolpix s210
This is probably THE most common failure among digital cameras. There's a halfway chance of fixing it yourself, described here: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Jun 15, 2009 | Nikon COOLPIX L10 Digital Camera
Lens error message on nikon coolpix L18 I purchased my Nikon L18 Cool Pix camera last September ('08). Last week when I turned it on, the lens extended fully, then retracted fully as I got a "lens error"...
When system control does not get lens initialize signal while extending it, then it try again by folding it and extending and still no required initialize signal then generate error and stop further functions.
Please remove battery and open camera and remove flexible wire of lens mechanism from connector, there would be lock that needs to release to remove flexible wire. Clean wire terminals with alcohol, let it dry and put back flexible wire in connector and lock it. Now put battery and power camera up, hopefully lens will work properly.
Hit "add a comment" button for further query / info.
Thanks.
May 01, 2009 | Nikon COOLPIX L18 Digital Camera
Lens stuck/lens error
Hello
there are tiny plastic gears inside and may have chipped or a small piece of sand got in causing the lens to jamb. "very fragile"
one solution is to ask a camera repair shop how much a lens mechanism would be to replace. (if cost is more than 1/2 of what you paid dont bother)
another solution is to have someone sell your camera on an auction site for parts, to make some money towards another camera purchase
Aug 19, 2008 | Nikon COOLPIX L10 Digital Camera
Nikon Coolpix L10 Batteries.
dear sir
i have purchase new coolpix nikon L10 camera but batteries are fast down replay me
Aug 11, 2008 | Nikon COOLPIX L10 Digital Camera
Lens Cover Won't Come Out! What Do I Do?
I have a solution for Nikon coolpix S5/S6. I am not shure but it might be similar for your  camera, You can try my document "nikon s5 s6 lens cover error repair.doc"  uploaded on site
http://www.esnips.com/web/papputatiyasStuff
Regards Mukesh
Apr 13, 2008 | Nikon COOLPIX L10 Digital Camera
Camera
Anything you would try to do yourself would void your warranty. I suggest taking the camera back and see if they won't give you a replacement.
Usually, zoom errors occur when the lens is extended and gets bumped or dropped. Liquid and or sand can also cause these problems
Jan 02, 2008 | Nikon COOLPIX L10 Digital Camera
Dropped camera and now lens will not move
This worked for my camera, Nikon Coolpix L10!! I'm so happy I didn't go out and buy another camera!!!
Remove the batteries, then remove the memory card. Then install the new batteries, when you turn it on it should come back to life. Error E30 means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Kathy
Dec 10, 2007 | Nikon COOLPIX L3 Digital Camera
Nikon COOLPIX L10 Digital Camera Logo
182 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
