Question about Proform CrossTrainer Treadmill
Belt won't move
I have tried the reset/off circuit breaker ....maybe I am not doing that right. DIsplays seem to work fine...I just ordered new keys from Sears for this 405E proform crosswalk...They beep when placed on treadmill. You can change speed, etc...set the programs...BUT the BELT won't move.. I called Sears...sorry, my 90 days are up and they won't advise me..
HELP !!  It sounds and acts normal but the belt won't move.. I don't use Facebook.
Thanks. Shirley....
  • 15 Answers
Does is just not move when you're standing on it, or not even move when you're not standing on it. It may be a simple belt adjustment or if the motor is running but there's no track movement you may be looking at a loose/broken drive belt. Take the cover off, start it up and look at the motor/drive pulley assembly. If the motor turns and the front roller doesn't, tension the drive motor by moving it back. If the front roller turns but the track doesnt, do a track adjustment as per your users manual.
Posted on May 27, 2010
My trimline 2200 treadmill will not start the belt. I started having problems where it only worked on very slow speed now the belt won't turn at all. I tried pushing the circuit breaker reset
Likely your motor wore out, or that the circuit for the motor driver is shot. If the panel is starting it is likely that the motor is not getting any power at all.
Jan 21, 2015 | Exercise & Fitness
I have the 1750 NordickTrack Treadmill and the screen is "froze" on the SD or WiFi screen. I tried pushing the stop button, shutting off the power, and even unplugging the power cord and it still shows...
try this steps and fix it. God bless you
Step 1
Plug the power cord into a UL 1449 single-outlet surge suppressor and then plug the surge suppressor into an electrical outlet that is not GFCI-equipped if the power does not turn on. If the treadmill is plugged in and the power still does not work, make sure the key is in the console and that the Reset/Off circuit breaker has not been tripped. Press the switch to "Reset" if it has been tripped.
Sponsored Links
Gym Equipment Choose from 1M+ Verified Suppliers. Contact Directly & Get Live Quotes! www.alibaba.com/Gym-Equipment
Step 2
Check the Reset/Off circuit breaker if the power switches off while in use. Wait five minutes and switch the button to reset. Check that the power cord is still plugged in securely; pull the plug out and plug it back in after five minutes. Pull out the console key and reinsert to see if the machine will turn back on.
Step 3
Place the chest pulse sensor tightly right underneath your pectoral muscles or breasts for it to operate properly. Position it lower or higher on your chest if it does not work properly. Wet the electrodes with a saline solution. Walk near the walking belt's center within an arm's reach of the console.
Step 4
Remove the console key and unplug the treadmill to loosen the walking belt if it slows when in use. Turn the rear roller bolts counterclockwise with the hex key 1/4 of a turn until you can lift the walking belt's edges 3 to 4 inches from the platform.
Step 5
Remove the key and unplug the treadmill to adjust the walking belt if it is off-center or slips when in use. Loosen the rear roller bolts with the hex key and reposition the walking belt. Tighten the roller bolts. Walk on the treadmill to determine if the walking belt is centered. If not, loosen the roller bolts again and make adjustments until the walking belt is centered.
Step 6
Recalibrate the incline system if the treadmill's incline does not adjust correctly. Press the "Incline" button and remove the console key. Wait a few seconds and replace the console key. The incline will automatically recalibrate by moving to the maximum incline level and then the minimum level.
Step 7
Press the "Stop" button for a few seconds to turn off the demo mode if the console display stays lit after you remove the console key.
Read more: http://www.livestrong.com/article/241157-nordic-track-treadmill-troubleshooting/#ixzz2geWlKdPR
Oct 02, 2013 | Nordic Track NordicTrack COMMERCIAL 1750...
Why is my frigidaire washer not spinning?
  1. Stopped Mid-cycle
    • If your Frigidaire washing machine started spinning, but then stopped, verify that the power cord is still connected to the outlet. See if the outlet blew by plugging in a different appliance into the outlet. See if you blew a fuse. A blown fuse usually is either black or has broken wires. Replace the fuse. If you have a circuit breaker instead of a fuse box, reset the circuit breaker if it's been tripped. Check the lid switch, which is located inside the main housing of the washing machine, near the door frame. If the switch is burned out, order a new part from a Frigidaire parts dealer.
    Pump
    • The pump's sole responsibility is to remove water during the spin cycle. If the pump isn't working properly, see if it's clogged with debris or clothing. Use needle-nose pliers to remove these items. Check the pump pulley, which is connected to the pump. This component must move freely for the pump to work. If it won't turn, purchase a new pump pulley since you can't usually fix this component.
    Lid
    • Check the door latch assembly if the door isn't closing correctly. If any of these components are broken, order a new part from a Frigidaire parts dealer. If you do not, the washer won't start spinning since it believes the door isn't closed. Your Frigidaire washing machine won't start the spin cycle until the lid or door is closed. Always close the lid, and remove any items preventing the lid from fully closing. Always close the dispenser drawer.
    Additional Concerns
    • Never over- or under-load your washing machine. Your Frigidaire washer may not enter the spin cycle if the load is too large, since this can damage the washing machine. Remove a few pieces of clothing. If the load is too small, add a few similar items to the washing machine. Check the internal belt, drive motor and motor coupling. If any of these components are broken or very worn, they may not work properly, preventing the washer from entering the spin cycle. Order replacement parts from a parts dealer. Check the tub and basket bearings, and get new ones if the current ones have broken components or are defective.
Sep 27, 2011 | Washing Machines
I have a proform 300 treadmill. we moved into a new home and it just stopped working. it was perfectly working before the move. now, nothing comes on, no power, nothing.
Dear Sir:
I will help you.
1. NoPower
o 1 Make sure that the surge protector being used isproperly grounded and turned on. Check that the treadmill power cord isproperly plugged into the surge protector. o 2 Check to see that the key is inserted in theconsole. o 3 Check the circuit breaker on the frame near thepower cord. If the reset/off circuit breaker has tripped, wait 5 minutes andthen reset the breaker by pressing the switch in.
2) Circuit Breaker:
Please check the circuit breaker from the main panel, and reset, or put some Lamp for to see if turn on. if do it. the problem could be the wires and the plug, Test it with A VOM(Voltimeter) for a continuity.
Thank you in advance, sincerely.
If you need extra help, please do not hesitate to reach me. .
blessing.
E.CUADRA
MANAGUA, NICARAGUA. C.A.
Sep 13, 2011 | Proform 810 TR Treadmill
I have a Nordictrack exp 1000x and it won't turn on. Any ideas?
Right next to the power cord is a circuit breaker. Check it to be sure it has not tripped. If so, reset the breaker.
Check the outlet, be sure there is power.
If that checks out, remove the motor cover (unplug the machine from power first) and check the fuse on the controller board. Chances are if the fuse is blown, the controller might be defective. Replace the fuse and try the machine. If it blows again, the controller is defective..
Dec 17, 2010 | Nordic Track NordicTrack Treadmill, A2550
Dryer was working fine a load finished and when i started a new load it would not work meaning when i pushed the button nothing happened
Might be something as simple as the "settings" knob is not completely reset.... or the circuit breaker is open at the fuse panel... or the door latch sensor is not tight.
So, check each (in the order listed) and I suspect that you will correct the problem
Feb 03, 2010 | Dryers
MP4 Player, Model no: Jxd661+
on my jxd mp4 & mp3 player THERE IS WHITE SCREEN
Nov 26, 2009 | NRS Siemens Ite 400a 600v Circuit Breaker...
Frigadaire Dishwasher PADLOCK Icon lit, dishwasher won;t run
I have an FDB1502RGB0 model but had the same problem. I reset the circuit breaker and its working fine now. I'm not sure what caused the problem but it seems to be fine now.
Jan 04, 2009 | Frigidaire 24 in. FDB1050REC Stainless...
Hotpoint aquarius1100 electrical prob.
you say tripped the switch?... are you talking about a circuit breaker???.. I was thinking maybe you have a bad breaker... If you had no problem before... maybe try in a differt plug in reciptical... if the washer has a short.. hard to find sometimes..like looking for needle in hay stack..
Sep 02, 2007 | Washing Machines
Proform CrossTrainer Treadmill Logo
770 people viewed this question
Top Proform Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Matt Olenzek
Matt Olenzek
Electro Med Services...
Are you a Proform Exercise and Fitnes Expert? Answer questions, earn points and help others
