Question about McCulloch 16 Inch Gas Chain Saw MCC1635AK
Won't start never had a problem starting before...aprox. 10 yrs old. Like a bad owner I don't remove fuel during non use. Humm, could that be it? Help!
    Problem Solver:
  • 13 Answers
Fuel goes off in plastic containers,ie 3 months.try fresh fuel.metal jerry cans good for storing petrol.
Posted on May 27, 2010
My toyota 4-runner sat for 3 yrs and now it turns over and wants to start but won't what may be the problem
If it sat for 3 yrs without starting then chances are it is the fuel. I belive most of the older toyotas had a drain on the gas tank, I would reccomend draining the gas and replacing the fuel filter to start with, just keep in mind that if it has an electric fuel pump there is a good possibility that it has gone bad from sitting. P.S. if there is no drain and you can't get the fuel pump to work and pump out all the old gas then I would suggest getting a universal fuel pump to remove all the old gas, or you can try to syphon the gas out and is a pain. Hope this helps you out, if you have any more questions then add a comment and I will get back to you.
Jul 02, 2012 | 1995 Toyota 4Runner
1999 astro/4.3L/starts cold /runs 10-15 min. then dies will not start hot new battery.new coil/clean filter/pump 2 yrs old installed new/battery shows 14 amps when running/ won t crank when hot either/...
car shuts off when it gets to normal operating range. it takes 10-15 minutes to reach normal range. causes: low coolant, failing coolant tempurature sensor, air in water pump, check the coolant temp. sensor. if it is bad it will send wrong info to engine when hot, and shut it down. ITS WORTH A TRY!! good-day!
Sep 15, 2011 | 1999 Chevrolet Astro
1994 gmc surburban turns over fine but engine won't start
You can check to see if the fuel pump is bad..Remove gas cap and listen into tank while another person turns key on.If you here a buzzing noise the fuel pump is most likely OK...If you don't here anything Check owners manual for fuse location and check to see if there are any blown..There is also a fuel relay fuse under the hood
Jun 11, 2011 | 1994 GMC Suburban
Hello. My 1997 Chevy Tahoe refuses to start. The problems began with a bad fuel pump. I changed. It worked. The fuel pump died again. I changed it again and it has been working. I parked it for two weeks....
Now you have a good battery & a starter that turns over the motor
Have you cycled the key on & off with a fuel pressure gauge on the
fuel rail?
Do you have a fuel filter that isn't over 3 or 4 years old?
Have you checked for spark while cranking ? Use an old plug on the wires,
if you have ignition wires,don't ground the wire without resistance
If you removed the ducting & MAF Sensor it won't start
Tell us what you checked & exactly how that was done.
Jun 09, 2011 | 1997 Chevrolet Tahoe
Have 1985 f-150 has a qt.tank gas which has been sitting for aprox 4 yrs. i did not get it out and have tryed to start trk. now do what? .is there some way to get injectors clean after i get the old gas...
PUT IN FRESH GAS AFTER REMOVING OLD. PUT IN SOME "GUMOUT" FUEL INJECTOR CLEANER. FOLLOW THE INSTRUCTIONS. OR U CAN REMOVE THE INJECTORS AND HAVE THEM PROFESSIONALLY CLEANED FOR A FEW HUNDRED BUCKS.
Dec 15, 2009 | 1985 Ford F150
Buzzing (a little bit louder than normal humm), but no popping
WHEN THERE IS A BUZZING NOISE IT MEANS THAT ONE OF THE INTERNAL COMPONENT HAS FAILED .RANGING FROM A SMALL DIODE TO LARGE PARTS LIKE
THE MAGNETRON OR TRANSFORMER OR CAPACITOR. IF IT IS 10 YRS,OLD YOUR BETTER
OFF GETTING A NEW ONE .BECAUSE YOU COULD INVEST MONEY IN THIS ONE AND HAVE SOMETHING ELSE GO TWO DAYS FOR NOW.WITH A NEW ONE YOU ALSO END UP WITH THE NEW WARRANTY. HOPE I HELPED. KEN62 GOOD DAY!
Jul 22, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
1997 s-10 sames to get vapor lock. after filling up with gas,drove truck home (4miles} left sitting in drive way (hot sun) tried to start 4:pm. 9:pm 9:am removed gas cap started up first time. Aprox....
Change your fuel filter, it may have gone it's life time and is getting to dirty to let fuel flow properly. Your fuel pump to may be getting weak, if the fuel filter is dirty the pump works harder and heats up and could be over heating the fuel pump relay too. The fuel pump relay i believe is in the glove box behind a panel that say relay, there should be (3) in there and the middle one is the fuel pump's. switch then around after you change the fuel filter and if you get a chance, check your fuel pressure at the shredder valve. Good luck and hope this help's if there is a Auto Zone around you, you can ask to use the fuel pressure gauge to see what fuel pressure you have and they'll have the step by step instructions on how to do it and takes about 5 min to do and will have the fuel filter and step by step to replace that too. Keep me posted, be glad to help.
Jun 08, 2009 | 1997 Chevrolet S-10 Pickup
87 celica sitting for 10 yrs, will not start
You need to drain all old fuel out of the fuel tank, the fill with fresh fuel, clean or change filters (air and fuel)
and if possible blow fuel lines through with compressed air. Check the plugs are clean and gapped correctly, check the engine oil is ok.
Then use some easy start in the air filter to get it to fire up, after 10 yrs it will be difficult to start, but should be alright after a few runs.
I hope this helps
May 14, 2009 | 1987 Toyota MR2
McCulloch 16 Inch Gas Chain Saw MCC1635AK Logo
127 people viewed this question
Top McCulloch Garden Experts
Roland W VanLue
Roland W VanLue
roeb
Are you a McCulloch Garden Expert? Answer questions, earn points and help others
