Question about Toshiba Satellite M30 Notebook
My baby was typing all different things on my comp and now it wont open windows it gives me an error of status 0xc000000f. i have only to options one is to repair with windows CD that i dont have and the other is to continue normally when i select that it just takes me to a blank black screen . Thanks
  • 315 Answers
Can you borrow a disc from someone you know??
Once you have the disc you will need to do the following:
Simply boot from the Vista DVD, go to the repair options (if you cannot select any valid current installtions of Windows do it without selecting anything; it will work) and from there open the command promt. And no do a simple copy:
copy c:\windows\system32\boot\winload.exe c:\windows\system32\
There are other things that could work but unfortunately I'm not sure I could explain well enough how to do it on here as it gets a bit complicated with Command prompt and things.
How good are you with computers?
If you manage to get a disc and your feeling brave, have a look here: http://social.technet.microsoft.com/Forums/en/itprovistadeployment/thread/189dc129-551f-4336-8c88-fdfaa2fd75d3
Remember to print these pages off though unless you can get online and use your laptop in the same place.
Posted on May 26, 2010
I keep getting error code 0xc000000f on my asus laptop and don't have the start up disc
Solved] Fix Windows 8 Boot Error 0xc000000f go here for instructions http://www.smartpctricks.com/2013/09/solved-error-code-0xc000000f-windows-8-a-required-device-isnt-connected-or-cant-be-accessed.html
Sep 30, 2014 | ASUS Computers & Internet
Google com
Possible hdd failure or a damaged file.
Windows Boot Manager
Windows failed to start. A recent hardware or software chance miht be the cause. To fix the problem:
1. Insert your windows installation disc and restart your computer.
2. Choose your language settings and click "Next."
3. Click "repair your computer."#
Status: 0xc000000f
Info: The boot selection failed because a required device is inaccessible.
Aug 04, 2014 | Acer Aspire Computers & Internet
Status 0xc000000f
You should be able to create a boot able stick for this kind of issue.
Sounds like you have hard disk errors. Open the Command Prompt when the Installation DVD Loads and type the following commands.
chkdsk /r c:
chkdsk /r d:
chkdsk /r e:
chkdsk /r f:
.etc until you get the message that the volume could not be opened for direct access. For any drives that do not give the message:
"Windows has checked the file system and found no problems"
run chkdsk again as above. In other words, if it says:
"Windows has made corrections to the file system"
after running the disk check, run the disk check again.
I realize you may only have one disk show up in Windows explorer, but you may have more than one disk through recovery options. This is because the system creates a hidden boot partition (which will be C: in recovery), you may have a recovery partition for your PC that is hidden (which will be D: in recovery), and you will have your primary Windows partition (which may be E: in recovery). A custom PC will likely have at least C: and D: to scan.
Nov 01, 2013 | Acer Computers & Internet
Error 0xc000000f while formatting hard drive
try some formating toos .. like hiran boot cd or disk or diskformater ...u can use usb bootable device to install windows, u can make ur personal pen drive to bootable pen drive.
Jun 02, 2013 | Packard Bell Computers & Internet
Windows failed to start, Status 0xc000000f acer aspire 4730z
aspire aspire d257 status 0xc000000f Info: the select entry could not be loaded because the application is missing or corrupt
Jun 30, 2012 | Acer Computers & Internet
When i start up my computer it goes straight to boot manager and gives an error code file\ windows\ system32 \ winload exe,,, status 0XC000000F file missing or corrupt, what is the issue please, system is...
The problem you have is with the system boot files. There is a corrupt file and that is stopping the system from booting.
Press F8 as the system starts up, that will let you into the special boot menu and hopefully will give you the option of repairing your system. The timing can be quite tricky as there is only a very short time window. Trying a few times should get it.
Hope that helps.
Nov 21, 2010 | Packard Bell iMedia 6826 (P481000502) PC...
Have a toshiba satetllite laptop and i have error code 0xc000000f but was not givin a recovery cd and the old press f9 is not working. any ideas?
try going into safe mode with command line utility enabled. (F8 on bootup). in command console type chkdsk /f /r and enter y for yes at the prompt. wait for it to finish, it may take a while. If that doesn't solve it try typing fixmbr. If that doesn't work, manually load the os to boot from cd-rom. tap F1 while rebooting. in the BIOS go to boot options. in boot options change first boot device to cd. put the cd in the tray, save and exit your settings. The comp will boot from the windows disk. follow the prompts.
May 04, 2010 | Toshiba Satellite A100-S8111TD Notebook
Cant logon my acer 1640 it wont even get to the windows page
This is the menus that you get when you boot from the CD:
http://www.bleepingcomputer.com/tutorials/tutorial148.html
When you run the Startup Repair from your Vista CD you get that error "No OS files found on disk."correct?
Instead of choosing the Startup Repair option try the System Restore option and see if i allows you to take the computer back to another day ,if it gives you an error then choose the other option that says Command Prompt ,it will load to a blinking white cursor.
Type in the following and press Enter key after each one:
bootrec.exe /fixboot
bootrec.exe /fixmbr
When finished Restart the computer and see if it will load normally.
If it doesnt resolve it then it could be a hardware problem on the laptop itself.
Apr 09, 2009 | Acer Aspire 1640Z Notebook
Key Ports
Try connecting to this URL:
http://status.messenger.msn.com/Status.aspx
If you can connect, then there are several different things that could be wrong:
I use XP. What worked for me was
Start > Run
Type:
netsh interface tcp set global autotuninglevel=disabled
Done.
Restart messenger.
If that doesn't work, try:
Start > Run
Type:
regsvr32 Softpub.dll Mssip32.dll Initpki.dll
Wait for all three boxes to popup confirmation.
If that doesn't work:
Start > Run
timedate.cpl
Internet Time Tab
Update Now Button.
After sync, try again.
I hope that fixes everyone's problems. I've never had this problem until I installed the latest Messenger.
Jan 10, 2009 | U.S. Robotics (USR8200USR8800KIT)
Toshiba Satellite M30 Notebook Logo
136 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
