Question about Canon imageCLASS MF5730 All-In-One Laser Printer
MF5730 DOES NOT PRINT DARK ENOUGH - Canon imageCLASS MF5730 All-In-One Laser Printer
    Sergeant:
  • 284 Answers
Maybe you should replace the TRANSFER ROLLER
Posted on May 28, 2010
My eltron ip2844 wont print dark enough. I went into setting and turned the burn darkness to 15, but still not dark? Help!!
This may be due to your thermal paper.
This printer doesn't deliver enough heat to your paper or you have a problem with the head pressure.
Press on the bloc while printing to see if it's this reason?
You may also have a mis-alignement of the thermal head.
Try also to change the print speed?
Aug 05, 2011 | Zebra Eltron LP 2543 Thermal Label Printer
Zebra Z4MPlus not printing dark enough
In your label software there should be a setting option for print darkness (I assume it adjusts the head temperature) In ours (bartender) you can get to it when you select 'print' and a window appears with a 'documents properties' button. Click on this and select options and a darkness bar appears which you can adjust. You may also need to slow the label print speed if the darkness adjustment is not enough. I suspect it isn't in the printers best interest to run the print head at maximum darkness/heat so a sensible balance of darkness and print speed is best.
Another, less likely, possibility is an incompatability between the label material or surface finish, and the ribbon type. We did have a problem once whem Homebase changed their price label design and we had to test a load of other ribbon types until we got one that did the job. A chat with the label or ribbon supplier is always usefull, they sent us several sample bits to test.
Sep 30, 2009 | Zebra Z4Mplus Label Printer
False Paper Jam Signal Canon MF5730
Try changing the quality of your paper.
Roughen up the rollere guides a little to you get better grip. Clean rollers with alcohol and use a green scrub mit to lightly rub the surface of the guide reels.
Hope that helps yours work too
Please rate our help to keep service online
Aug 19, 2009 | Canon imageCLASS MF5730 All-In-One Laser...
Printer not printing dark enough
go to the print settings select the dark scale
u can get print darker than the previous
May 27, 2009 | Samsung CLX 3160fn All-In-One Printer
My hp 1200 printer is not printing dark enough. this problem just started/ I can barely read the print. MY hp 1200 printer is not printing dark enough I installed a new toner cartage but it still does the...
If you have installed the toner cartridge correctly then it is a hardware problem called the Fuser and is the most common problem with printers...the fuser is a part of the printer which actually melts the toner onto the paper. The fuser has to get up to a high enough temperature to be able to melt the toner, if it is malfunctioning then it cannot give you a dark print. You may search google for Fuser information: Recommendation is change out fuser to repair problem. Pls rate this solution.
Apr 20, 2009 | HP LaserJet 1200 Printer
Service manual canon laserbase mf5730
hello friend, you can find the canon mf5730 service manual in below link:
Canon mf6550 service manual:
http://goo.gl/79EPf1
thanks
Aug 27, 2008 | Canon Office Equipment & Supplies
Am have Problem with Canon MF5700.
hey, I keep getting a paper jam message but there is no paper jam. Opening the cover does not reset, nor unplugging the machine. Bob
Jul 02, 2008 | Canon imageCLASS MF5730 All-In-One Laser...
Canon imageCLASS MF5730 All-In-One Laser Printer Logo
148 people viewed this question
old marine
old marine
