Question about GE JTP45 Electric Double Oven
Display panel is dim. - GE JTP45 Electric Double Oven
  • 523 Answers
First check the power then if shows to be good replace clock assy
Posted on May 27, 2010
Testimonial: "Thanks - if only I can find one. "
Clock light and temp.light fading out.what needs to be fixed
LED clock/temperature light fading an - Appliance Repair Forum
forum.appliancepartspros.com/oven...ranges.../650-led-clock-temperatur...
Aug 20, 2007 - 3 posts - ‎3 authors
The LED clock/temperature/etc control light has been becoming less ... needs to be replaced (board being the oven clock/erc/control board). Control pad temperature light out
Jun 15, 2014
Dim temp lights
Feb 7, 2014
Frigidaire range LED display is dim
Aug 28, 2009
Oven clock & light
1 post
Jun 21, 2009
More results from forum.appliancepartspros.com
Cheap Fix for a Dim Display on an Oven Control Panel ...
Nov 29, 2015 | Whirlpool 30" Self-Cleaning Freestanding...
DIM DISPLAY ON GE PROFILE WALL OVEN
when they are dim like this,it needs replacing as its a driver chip that drives the readout and illuminates it you can send in the board for rebuild or purchase outright,as they dont supply any component specs to repair the control panel
Feb 03, 2013 | Ovens
The control panel is very dim on my Thermador RDSS30 oven
Cannot Read Display or See Temperature Thermador RDDS30
FixYourBoard.com repairs this failure and back their work with a two year warranty.
May 14, 2011 | Thermador Ovens
Oven digital lighted display is dim
You need to replace the C3 capacitor on the control board
http://fixitnow.com/wp/2009/01/28/cheap-fix-for-a-dim-display-on-an-oven-control-panel/
You can replace only the C3 - it is 68uF / 35V and you can go to Radio Shack and get their part # 272-1028 - 100uF/35V one. It takes all but 10 minutes to re-solder the new one in place
May 31, 2009 | Jenn-Air JJW8530C Expressions Collection...
My clock and temperature display is dim
Hi, this will happen over a period of time and its just heat related. the control panel isn't insulated properly and , there has been a larger than normal transfer of heat to the inside of the control panel where the circuits are housed.
If this is a problem, i recommend replacing the control board. it will fix the dim issue.
May 22, 2009 | Jenn-Air JMW9527C Electric Double Oven
Dim light on oven display w30400b jennair
The circuit board is for the display/touch panel. It is mounted on the back of the display panel itself and connected to the other circuit boards by two multipin connectors. When you remove the display panel (3 screws on top, 4 on the bottom) you will be able to GENTLY detach those connectors. They are low voltage and may be handled safety even when the oven is powered, but I agree that turning off the oven circuit breaker is good practice.
To remove the circuit board, GENTLY release the two black plastic tabs; the solder pads are underneath. I too used a 100 mf capacitor because no local supplier had a 68 mf hi-temp. Observe polarity; the (-) lead goes towards the center of the board (away from the edge connector.)
BTW, I had exactly the same symptoms (display goes dim, then goes out altogether.)
Jan 16, 2009 | Jenn-Air W30400P Stainless Steel Electric...
Jenn Air JJW8530C stopped working
can you hear audible tones form the machine when trying to set?? and just hte display has dimmed( amore normal complaint). all functions are working just the clock/display has dimmed to non readable state. if thats the issue youll need to replace the display part number 71003424 retails for about $165
Nov 04, 2008 | Jenn-Air JJW8530C Expressions Collection...
Display panel
Dim display indicates a "failing" electronic oven control. It will continue to get dimmer and dimmer until it fails completely. You need to replace the "clock" (sometimes called the ERC <---Electronic Oven Control)
This is a tricky repair. Be sure you have the power off (at the breaker box) before attempting this.
Tracy
Oct 28, 2008 | Jenn-Air WW27430P Stainless Steel Electric...
Thermador model sc272t oven 2 doors have dim display
there is a dispay kit you can order from bosch to fix this problem. it will come with a new display board and power control which is located behind control panel as well
Nov 18, 2007 | Thermador SC272T Electric Double Oven
GE JTP45 Electric Double Oven Logo
191 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Dan Webster
Dan Webster
Are you a GE Oven Expert? Answer questions, earn points and help others
