Question about Proform 760 CrossTrainer Treadmill
Belt skips - Proform 760 CrossTrainer Treadmill
  • 15 Answers
Take the cover off, if the front drive roller continues to turn when the running belt stops, tension the running belt by using the rear adjustment screws. One full turn on each side should do it. If the front roller stops turning but the motor doesn't, tension the drive belt by adjusting the motor back.
Posted on May 27, 2010
I need to know how to fix my timing if it skipped a tooth i dont think anything is bent
double check all the belt timing marks and if it really has skipped a tooth you will have to release the belt tensioner, reposition the belt and re-tension it. you often get lucky if its out by just one tooth, but if it happened once it can happen again and cause real damage so don't drive it until its fixed, and make sure the tensioner is set and working correctly
Apr 06, 2012 | 1996 Mitsubishi Eclipse
I have a Image 15.0 R treadmill. It skips and I tried tightening the belt 1/4 turn as directed and not over tighten it. Still skips and actually squeaks now especially when running on the treadmill at 6...
3 different possibilities in my opinion:
belt is too loose, belt is too tight, belt is worn out.
Try to lift the belt and get your hand under it in the middle of the deck. If you cannot reach, it is possible that your belt is too tight. Another clue for this would be the belt "curling" on both sides at the edges. Try to loosen the belt, gradually and testing it along the way.
If on the contrary you can easily slide your hand under the belt from one side to the other, it is more likely that the belt is too loose. The squeaking might be due to the belt not being "square" on the deck. Try to loosen it even more until you can slide it with your hands across the deck. And have it aligned evenly at the front and back. Then retighten and adjust the tracking at low speed.
!!! Do not over loosen as the bolts might come out of the back roller.
A worn out belt might squeak and skip when its old.
Mar 04, 2011 | RTO Image 15.0R Treadmill Walking Belt
I have a JVC L-L1 turntable. The linear arm is quite sluggish and is actually making records skip. Any ideas other that replacing the motor?
I have this exact turntable. If the tone arm looks like it's not moving or not moving fast enough, it will make the record skip. It is NOT the turntable drive belt that is bad. It IS a 2nd belt that makes the tone arm assembly move. That belt is only about 1 3/4" diameter. I have yet to find one for mine. Turntable drive belts are readily available, but not this belt for some reason.
Jan 01, 2011 | JVC Audio Players & Recorders
Belt skips
This typically means the belt is worn - or not tensioned properly.
Look in your owner's manual - and it will tell you how to properly tension the belt with the included spanner wrench.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jul 27, 2010 | Proform 540ls Treadmill Walking Belt
My treadmill belt skips. I have tightened it as far as it can go and it still skips
This sounds like either the drive belt is loose or the walking belt is old. First, check the tension on the drive belt. If the drive belt is not slipping, then walking belt may need to be replaced. I say may because without working on the unit, I cannot say that IS the problem.
Apr 17, 2010 | Exercise & Fitness
When to change timing belt and it acts like it want to skip.
Most manufacturers will tell you to change the timing belt every 60,000 miles or so. If it's true that it's actually skipping time now, CHANGE IT! Are you sure it's the timing belt skipping or is it something else like an ignition problem? Is your check engine light on?
I hope this helps! Let me know if I can be of further assistance. :)
Dec 07, 2009 | 2005 GMC Canyon
Power stearing pump works in the morning but only for a short time wat could this be
Does it stop working completly or just start skipping. If it skips check your serpentine belt.
Oct 30, 2009 | 1995 Jeep Grand Cherokee
Teac PD-D880 5-CD changer Disc Skip
The belt for the carousel has snapped and the noise is the gears continously turning and not being caught by the belt.
Oct 27, 2009 | Teac Audio Players & Recorders
1997 2.0 y code engine mitsubishi eclipse
P1390 - Timing belt skipped 1(or more) tooth
(click for full size)
Jan 21, 2009 | 1997 Mitsubishi Eclipse
Car skipping and not getting gas
sounds like the timing is out 1. check timing 2. check timing belt is fitted correctly if the timing marks top and bottom arent in then it would cause this problem 3. you may have bent valves this is usually when the belt snaps and the engine is turned over exessively to try to start it from your description i would first think number 2. above
Jun 11, 2008 | 1995 Acura Legend
Proform 760 CrossTrainer Treadmill Logo
193 people viewed this question
Top Proform Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Matt Olenzek
Matt Olenzek
 Atlanta Fitness
Atlanta Fitness
Level 1 Expert
Are you a Proform Exercise and Fitnes Expert? Answer questions, earn points and help others
