Question about Toshiba MV13L2 13 in. TV/VCR Combo
Have a Toshiba TV/VCR combination, auto clock set. Also says MV13MS. The video casette is stuck inside. will not eject. How to open and retrieve is my problem. do you have instruction?
  • Toshiba Master
  • 3,866 Answers
Opening any unit is dangerous as there is nice Voltage that will not go your way. But on this model you need to pop off the back and access the bottom over witch is a flipped situation. There is not really any step by step if you got a screw driver its basically your friend here, You need to open the back cover and remove it to access the rest the VCR is on the bottom of the unit and that is what needs to be accessed. When in doubt here seek a local tech because anything that has to to with online will be limited on Do SEE Do's But my first recommendation is to stay away from any deflection boards and the flyback transformer. Lets get the back off first and let me know if you have any additional questions after that.
please do click the accept button for my efforts.
Posted on May 27, 2010
We have a Sylvania TV/VCR combo with a tape inside that won't eject. The result is that the TV shuts off after a couple of seconds. The model number is SSC192
Hello
The belts in the VCR mechanism should be replaced. They are loose and elongatee. Due to this, proper loading of casette won't take place. If so, the video casette will not load properly, willl stop at its middle, will cause a short for the secondary supply; and finally will shut down the TV, and that is happens now with your device now. The inserted casette wont come out. You ahve to open the system, and take the casette out manually by turning the mechanism. If you have enough knoledge you can do it by yoursef. If not get it repaired by any experienced service technician. Never switch ON and OFF this set at this condition. It will make mor faults to get in with power supply system. OK.
Aug 08, 2011 | Sylvania Televison & Video
THE DVD WON'T OPEN OR PLAY ON MY TOSHIBA TV/VCR/DVD COMBO MW27FN1
check either the front or back of television for a small pinhole, that should be the emergency eject hole, place unwound paper clip in hole to eject disk, however, this will probably be re-occuring and dvd player will need to be replaced.
Oct 17, 2010 | Toshiba MW27F51 27 in. TV/VCR/DVD Combo
Set clock on sd-kv550-su
There are two ways to set the clock on your machine, firstly by using the 'auto clock' feature and also a manual setup, if the auto setup doesn't work then you will need to setup your machine manually. the 'auto clock' feature will atempt set itself up and will take approx 4 mins for the machine to adjust itself. There is also a daylight saving setting which you can either have set to on or off. The auto and manual steps that I have added below have been taken from the user manual for your your Toshiba SD-V295 pages 24 - 26.
Hope this helps,
James
Auto Clock Adjustment
Preparation:
• Turn ON the TV and select the corresponding video input.
• Press VCR DVD selector to select the VCR mode.
(The VCR mode indicator will light.)
1. Connect the Antenna or Cable system.
If you use a cable box, turn it on.
2. Plug the AC power cord to the AC outlet.
3. Make sure the DVD/VCR is turned off.
If you press POWER, the Auto Clock set is not programmed.
4. Wait at least three minutes and press POWER.
5. Press CALL DISPLAY to check the clock setting on the on screen display.
6. If the clock is not set, check the antenna
condition. The AUTO CLOCK may not function properly if the reception condition
is not good.
Manual clock setting
1. Press VCR MENU.
2. Press SET + or – to select “SYSTEM SETUP”, then press ENTER.
3. Press SET + or – to select “CLOCK SET”, then press ENTER.
4. Press SET + or – to set the month, then press ENTER.
5. Set the day, year and time as in step 4.
6. After setting the clock, date and time starts functioning automatically
Apr 25, 2010 | Toshiba SD-V295
It does not eject the tape,it gives out error c3211
Reel of the cassette must be stuck inside. open the top cover and have a look inside. release the reel if it is tangled up inside. Reset the switch at the bottom of the frot pannel and try to eject the cassette. It will slove your problem. If it is not then you must consult the nearby sony service centre.
Aug 07, 2009 | Sony DSR-45P DV / Mini DV VCR
Tape stuck in vcr
Carriage has been set out of alignment due to improper extraction- need to repair or replace the carriage loader...accordianman
Jul 10, 2008 | Symphonic SC319C 19 in. TV/VCR Combo
Dew and casette eject
With the dew indication, the tape will not load. This is to prevent the tape from getting stuck inside the unit. If "drying out" the unit has had no effect, either the sensor itself is bad or the connections to it are defective. Opening these is no simple task for the novice. Bring it in for service. It should not be more than about $100 to fix this problem.
Dan
Apr 09, 2008 | Sharp Viewcam VL-Z1 Mini DV Digital...
TVSC1320 13 in. combo from January 2000 VCR Tape is Stuck
i took mine out with 2 butter knifes. 1 pressing on each side of the tape forcing it outward while pressing eject at the same time
Dec 23, 2007 | Zenith TVBR1330 13 in. Combo
Toshiba tv/ dvd /won't open
Unplug the TV ...wait 30 seconds then plug back in. Worked fine.
Nov 28, 2007 | Toshiba MW30G71 30 in. TV/VCR/DVD Combo
SERIES LXI TV & vhS
I'm guessing the "black thing in side" is referring to the actual tape itself- ribbon like which can be spooled out of the tape case. If so, then your VCR may have a mechanical problem of some sort, which results in a "no tape transport" or "no tape takeup" problem. If the latter, the right reel (takeup reel) is not being driven. Older VCRs often used a small rubber rimmed drive mechanism to drive this reel. Newer VCRs (10 years old or less) pretty much use a gear drive. Something may be broken here, or perhaps the gear is stuck. This gear assembly has to swivel back and forth, from left for rewind, to right for takeup or fast-forward. Unfortunately, you can't see the gear once the tape is in the machine, at least not from the topside. Suggestion: Take the top cover of VCR off, look for this gear, and see if it swivels freely, look for broken gear teeth.
Apr 14, 2007 | Rio Go Video DDV9475 Dual Deck VCR
Toshiba MV13L2 13 in. TV/VCR Combo Logo
93 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
