Question about KitchenAid Ovens
Model YKERS507HWO the oven is not working, no display is lit up but the electric hob is till working
  • 213 Answers
SOURCE: oven not switching on
the f-01 means the oven control is bad. when your pot spilled it shorted out the control board
Posted on Nov 28, 2007
barkencoa
  • 3463 Answers
SOURCE: fan oven on zanussi electric cooker does not heat up
From symptons, I would say the fan oven element is faulty, more so if the fan is working. Remove inner rear panel of oven and see if element gets warm, let it run for a minute, switch off and feel if element is warm, if not, then replace.the element.
Plz rate this solution.
Thanks.
Posted on Dec 27, 2008
  • 16 Answers
SOURCE: Ignition switch on a gas hob/electric oven not sparking
Some have a AAA battery under the button - replace this, others use mains to create the spark, ensure you have the ignition wired up
Posted on Jun 01, 2009
SOURCE: Samsung PKG001 Stainless steel Single Oven and ceramic hob
Had exactly the same problem and just had the samsung engineer out (as it was only 3 months old ) who replaced the thermostat. all is now working ok
Posted on Sep 04, 2009
SOURCE: have a new electric cooker but the oven and 1 of
hi chances are that the internal thermal cutout fuse has gone this fuse is situated on the right hand side of the cooker when you have taken the back plate off about half way down it has two wires attached to it and is screwed with a self tap on the right hand corner of the body of the cooker near the middle of the cooker. You can buy this part and have it delivered for about £6 so is a very cheap fix.
Posted on Dec 03, 2010
Please can anyone help? We are in a rented property and we have an NEB Venezia SS electric oven with gas hob and all the writing on the knobs has been erased over the years. The hob works fine we need to...
Look up the oven on the web the knobs vari in calabration figures so I have never worked on this model, try a search engine you may find a showroom near you pop in and have a look.
hope this has been helpful
John
May 31, 2011 | Ovens
The heating light under the lid on my holagen oven needs replaced, how do i do it.
Charliedaze
Need more information on the issue, is this light for the oven or hot plate.
when working on electrical appliances ISOLATE THE MAINS POWER BEFORE OPENING
If the light is in the oven panel some models are part of the display, and the whole display would have to be replaced. If however the light is separate this can be replaced on its own, some models have a sealed LED, others have a small builb, on the hob the lights are usually sealed two wires are soldered to them, removal requires total dismantal of the rear of the hob and then a replacement soldered back in be careful of the polarity as incorrectly connected it will not light up. You can get parts from a local elecrical appliance store.
Or whitegoods.co.uk the model and serial numbers will be required.
Hope this is helpful
John
May 17, 2011 | Ovens
Our beko dv 555 w double oven bottom oven is not working as the clock display is not on
Beko DV 555w Electric cooker.Oven and clock is not working.
The hob and grill work.
Nov 19, 2010 | Ovens
MY STOVES COOKER'S OVEN AND GRILL HAS STOPPED WORKING?THE HOB IS WORKING FINE.
The hob is normally totally independent of the oven. What is actually working or not working on the oven? i.e. does the grill still work, is the clock OK and can you set it, or is everything totally dead?
Oct 16, 2010 | Stoves 720EF Electric Double Oven
Is this oven suitable to have a Induction Hob
Provided there is a space between the top of the oven and the hob, it should present no problem.
You will of course need a seperate plug outlet for hob
May 21, 2010 | Neff B1421 Electric Single Oven
I have replaced a Kelvinator hob with a ceramic hob. It works but the owen is not working. What is the problem?
There are possibly a number of options. It could be that in wiring the hob in you have disturbed the wiring for the oven. Normally the oven works off the main oven control switch on the panel and the hob could be wired into something else.
Is the oven totally dead no power at all for everything, or is the clock running but the oven will not switch on?
Dec 29, 2009 | Stoves 720EF Electric Double Oven
Candy sprinter hobb all on L locked?
Ours started doing the same Displaying L on four hob displays. I figured to press the bottom right hob and the minus button at the same time should unlock it.
Thanks
Trev
Oct 07, 2009 | Candy Ovens
Samsung PKG001 Stainless steel Single Oven and Ceramic Hob : Hob working ok oven light comes on and fans work ok no display on oven and no heat any suggestions
Jul 15, 2009 | Ovens
Jun 01, 2009 | Ovens
Oven not switching on
Nov 27, 2007 | Ovens
Ovens Logo
24 people viewed this question
Top KitchenAid Ovens Experts
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
ashburton
Are you a KitchenAid Oven Expert? Answer questions, earn points and help others
