Question about Bose Wave Radio
A cd is stuck in the player, will not eject, and the display says "no disc". How do I get the disc out?
There is a "rubberized" roller assy. A bar 1/8th inch diameter..about 3/4" wider than a cd. When you place the cd in the slot ,it activates the roller assy to pull the cd into the tray.[Kinda like an old wringer washer machine...only SOFT!!!
The "Input Slot" has a cleaner, if gunk gets on your cds the slot eventually clogs and gunk gets imported to the roller..can't always pull cd in..back and forth a little oil makes all worse. Eventually the will tend to "CHATTER". Pull the plug ,place on soft cloth-upside down.remove 5 black screws from bottom..and carefully separate by lifting bottom up. P.S.- The Green display cover is EXTREMELY EASY TO SCRATCH.. 1ST BRUSH WITH SOFT ARTISTS BRUSH .SOFT LINT FREE CLOTH IF ANY THING MORE IS NEEDED. Use a few drops of dish soap in a cup of hot water to clean roller..IF stronger means are needed you can use 70% iso alcohol Q-TIPS.. BUT GET alcohol OFF QUICKLY AS IT WILL DRY AND CRACK THE ROLLER OVER TIME.
Keith Craig Craig's Electronics Since 1968
Posted on May 30, 2010
  • 3,866 Answers
If the tray does not open the only way to get this out is opening the unit up. Many times the hat gets stuck thus the tray does nto open. So the only way that disc is going to come out of that unit is by manual extraction.
Thanks and please do be considerate and leave a rating and feedback
Posted on May 26, 2010
  • 4,234 Answers
These particular units are a bit tricky to open up. Please be careful if you attempt it. The most likely problem is a dirty lens along with a slipping load belt. This is a fairly common failure. Parts cost around $4 for the belt. The unit won't eject because the slipping belt cannot release the magnetic clamper that holds the CD onto the table. This should be a simple fix for any audio repair shop.
With experience, this repair takes less than an hour. It actually takes longer to open up the unit and get to the optics than it takes to replace the belt and clean the lens.
Dan
Posted on May 28, 2010
CD will not eject from 06 nissan maxima factory cd player
Stock CD changer stuck on EJECT - Maxima Forums
maxima.org/.../6th...maxima.../550345-stock-cd-changer-stuck-eject.htm...
Jan 9, 2008 - So when I tried to play a CD that has been in there forever, ... had that problem too! it would be in 50 degree weather.. discs wont change, play or eject. garaged the .... So last week I took my 06 (w/ Bose) in to the dealer for the stuck CD. ... said they send the CD player back to the factory and they will get the ...
Factory CD player
Aug 3, 2014
Bose 6 Disc Lockup CD ERR F0 !!FIXED!!
Apr 14, 2008
cd won't eject
Sep 8, 2002
More results from maxima.org
Nissan Maxima Car Stereo Removal and Repair - YouTube
? 8:52
https://www.youtube.com/watch?v=RT-SZEfeA4Q
Sep 16, 2012 - Uploaded by Factory Car Stereo Repair
Factory Car Stereo Repair ... Is it hard to fix cd inserting/ejectingproblem and what is needed? ... hey i ...
Dec 25, 2015 | Nissan Cars & Trucks
I have a cd stuck in the radio & it won't eject it (states no cd), makes a clcking sound. how to fix it?
Usually there is a hole in close to the cd slot, where a pin can be inserted in order to push out a cd manually or a similar manual override.
Which CD player/ radio are you using?
Jul 01, 2017 | 2004 Chevrolet Avalanche
CD player is stuck
Hello, it is possible that your disc is not recognised. What happens when you try to eject - is there a manual or emergency eject button?
Apr 07, 2014 | Cambridge Audio One Plus Mini CD-FM-iPod...
CD player "bad disc" CD stuck in
Use a plastic object to get under the disc while hitting eject. sounds like the gears are skipping or off.
Nov 09, 2013 | Ford Escort Cars & Trucks
There is a cd stuck in my cd player, how can I get it out?
Try pressing the reset button. This sometimes helps eject the disc. If not i have found that by holding a second disc slightly above the stuck cd and very gently pressing down on the stuck cd, it can help eject the stuck disc. DO NOT INSERT A SECOND DISC. there is also a possibilty that the ejecting mechanisim is broken in that case taking in to the repair man would be the wise choice.
Respectfully
dreamsystems
Feb 04, 2011 | Pioneer DEH-P6900UB CD Player
Cd will not eject. Keeps giving message "Now OPC" but will not do anything and will not eject cd either.
To remove a stuck CD from Tascam CC222 MKII
This solved the "Now OPC" problem
1. Unplug unit
2. Remove the top cover, (3 screws on each side and 3 on the back, lift cover).
3. Plug in unit.
4. Power on the unit to observe the drive spindle spinning clockwise, (1" disc on top of drive).
5. Turn off unit, do not unplug at this time.
6. Use a small screwdriver to prevent the drive spindle from spinning.
7. Power on the unit preventing the spin.
8. In approximately 10 seconds the display will read "Disc Error" and the CD tray will open.
9. Remove the screwdriver and the disc.
10. Turn off the unit and unplug.
11. Replace the cover.
12. Use a better quality disc.
Sep 23, 2010 | Tascam CC-222mkIII CD Player / Recorder
Stuck cd
if the eject button doesn't eject the disc the the CD mechanism is most likely damaged
Jun 15, 2010 | JVC KD-G420 CD Player
Hyundai CD player displays ''error'' for all functions
my cd player in my sonata keep eject the cd can anybody help
SOS
Dec 11, 2009 | Car Audio & Video
Bose Wave Radio Logo
568 people viewed this question
Top Bose Audio Players & Recorders Experts
jjcicala
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
