Question about ASUS Computers & Internet
My wireless won't work, internet connection shakey, various network adapters failed to start, error code 10, system says drivers are up to date. What's going on here?
    Genius:
  • 1,189 Answers
Hi, a [Code 10] identify that the "Drivers are missing or not working properly; you need to "Update the [Drivers]. You can go to the "Control Panel," and Update the Network Adapters in the ("Device Manager"). Next, you can go to the [Start Menu] and select to Search / Scan for "Windows / Microsoft Updates" or you can click on this site; where you may find the Drivers you need. "If this helped; let me know by giving a "Helpful Rating, thanks." softpedia.com/get/NETWORK-CARD/Asus/
Posted on May 27, 2010
My cisco linksys ae1000 adapter does not have internet connection
If haven't yet check Device Manager, go to Network Adapters and look for Linksys Wireless Adapter. Check the status of the adapt
Also look for errors codes on anything. Make sure all is enabled or need to install drivers.
If all fails remove adaptor and all drivers for it, restart computer and reinstall adaptor.
Aug 04, 2014 | Cisco Linksys AE1000 Wireless-N USB...
I cannot connect to the internet
Which operating system ?
Click start control panel administrative tools computer management then select event viewer this may vary depending on what operating system you have
extend the events there you will see errors in red you will no what exactly what the error was and at what time it occured
Right click on the error message select properties you will see all details about the error
or click start type in event viewer press ENTER
you might be able work your way through the problem
Set up your wireless Internet for your desktop PC according to the instructions that came with the wireless adapter.
The usual procedure is to plug the wireless adapter into an available USB port.
Windows will install the appropriate driver.
After your PC recognizes the wireless adapter, select the "Connections" icon in the taskbar (represented by vertical bars).
A list of available connections will appear.
Select the desired connection.
If you are prompted for a password, enter the appropriate password.
Click "Connect."
You are subsequently connected to a wireless network.
Launch your browser and enjoy surfing the Internet wirelessly.
If you are the owner of the wireless network, secure your wireless network with a password. To do so, navigate to the "Start" menu and select the "Control Panel."
Then select "Network and Internet" and "Network and Sharing Center."
Click "Change adapter settings" in the left pane.
Double-click the icon of the appropriate wireless connection.
The Wireless Network Connection status window appears.
Click the "Wireless Properties" button.
Select the "Security" tab and select an encryption type from the drop-down selection.
Enter a password in the Network security key field.
Make sure that the password matches the router settings.
Press "OK" when done.
Get a wireless internet router for your Internet connection if there is no wireless Internet already in your area.
You can buy these online, or at electronic stores.
You'll need to set up your router using the accompanying instructions and your own Internet service provider.
This is best in a home with multiple computers.
You will have to open up your network connections
Click start control panel network connections this may vary depending on your operating system look for local area connection if you see a red x or a yellow exclamation or question mark ! ? you will need to update or install the driver or it could be firewalled,
If you are trying to connect through a modem/router you it should have come with a disk then
you might have to connect the usb lead to your modem to get a connection then
Click start control panel administration tools computer management device manager scroll to network adapters should see a yellow question ? exclamation mark ! or a red X right click install drivers.
The driver might be on the disc supplied by your ISP internet service provider
or the motherboard disc
Click start type cmd press enter you will be in DOS mode
type in ipconfig press enter
you will see all of your internet connection details type in your default gateway adress into your internet search should read something like 10.0.0.138
You only need to check the following if a driver cant be installed
Make sure you Ethernet/internet is enabled in bios restart your computer during the boot up process you will see on your screen a certain key to
press to enter set up (BIOS) press and hold that key to enter bios using arrow keys navigate to integrated peripherals look for SiS On Chip Pci Device press enter scroll to SiS 10/100m press enter make sure its
"Enabled"imake
May 30, 2013 | HEWLETT-PACKARD RECERTIFIED TOUCHSMART 300...
Won't Connect to the Internet
With a wireless connection, your PC can connect wirelessly to a network printer. In addition, you can set up your PC in a location where no phone line or cable connection exists. Outfitting your desktop to a wireless Internet connection is very easy. Just follow these simple steps and you'll be surfing the net wirelessly in a matter of minutes.
Find out if wireless Internet reception exists where your computer is located. If you're located very close to a W-iFi hotspot, like a coffee shop, you may be able to use this network to get wireless Internet for desktop PCs. Also, some apartment complexes and college dorms have free wireless Internet. Your neighbors may have wireless Internet too, which you can ask them if you can use. Buy a wireless network adapter for your desktop. You can obtain an adapter from most electronic stores. Be sure to get a wireless adapter with the proper strength, which depends on how far you are from the wireless hotspot. The easiest adapters to install are those that just plug into an available USB port. Set up your wireless Internet for your desktop PC according to the instructions that came with the wireless adapter. The usual procedure is to plug the wireless adapter into an available USB port. Windows will install the appropriate driver. After your PC recognizes the wireless adapter, select the "Connections" icon in the taskbar (represented by vertical bars). A list of available connections will appear. Select the desired connection. If you are prompted for a password, enter the appropriate password. Click "Connect." You are subsequently connected to a wireless network. Launch your browser and enjoy surfing the Internet wirelessly. If you are the owner of the wireless network, secure your wireless network with a password. To do so, navigate to the "Start" menu and select the "Control Panel." Then select "Network and Internet" and "Network and Sharing Center." Click "Change adapter settings" in the left pane. Double-click the icon of the appropriate wireless connection. The Wireless Network Connection status window appears. Click the "Wireless Properties" button. Select the "Security" tab and select an encryption type from the drop-down selection. Enter a password in the Network security key field. Make sure that the password matches the router settings. Press "OK" when done. Get a wireless internet router for your Internet connection if there is no wireless Internet already in your area. You can buy these online, or at electronic stores. You'll need to set up your router using the accompanying instructions and your own Internet service provider. This is best in a home with multiple computers.
You will have to open up your network connections Click start control panel network connections this may vary depending on your operating system look for local area connection if you see a red x or a yellow exclamation or question mark ! ? you will need to update or install the driver or it could be firewalled, If you are trying to connect through a modem/router you it should have come with a disk then you might have to connect the usb lead to your modem to get a connection then Click start control panel administration tools computer management device manager scroll to network adapters should see a yellow question ? exclamation mark ! or a red X right click install drivers. The driver might be on the disc supplied by your ISP internet service provider or the motherboard disc Click start type cmd press enter you will be in DOS mode type in ipconfig press enter you will see all o fyour internet connection details type in your default gateway adress into your internet search should read something like 10.0.0.138 Make sure you Ethernet/internet is enabled in bios restart your computer during the boot up process you will see on your screen a certain key to press to enter set up (BIOS) press and hold that key to enter bios using arrow keys navigate to integrated peripherals look for SiS On Chip Pci Device press enter scroll to SiS 10/100m press enter make sure its "Enabled"imake
Feb 10, 2013 | Gateway LX6810-01 PC Desktop
802.11n code 10 error no wireless internet access
Make sure it is in the expansion bay properly, if it is not connected, it might not work. if it still does not work, add a different network or sound card to that bay and see if it works, if not, your PC's expansion bay is damaged, if it does work, you need a different Network card
Aug 16, 2009 | Broadcom BCM5704 Network Adapter
My system was working fine one day. The next day, it won't connect to the internet, saying that Windows can not manage my linksys connection. I have a Dell PC using Windows XP Service Pack 3
There are two solutions that you can try first
Perform system restore to the earlier date that connection working fine
OR
Re install the driver of the wireless adapter
If you need further help please post.
Good Luck
Jul 06, 2009 | Linksys WUSB54GSC Compact Wireless-G USB...
I cant connect to my wireless internet
rollback your drivers or else restore your computer ... for restoring your pc go to start/allprograms/accessories/system tools/ system restore .. in that select the bold date i.e., when ur pc worked fine and then click next .. thats it ..your problem is solved ..
Jun 22, 2009 | Computers & Internet
Dell Latitude D610 -- Windows XP Professional
the freeze up problem is due to the limited HHD space or memories. please check your HHD and see how much free sapce you have, and check your memories. the base system came with 256MB, which is too little for anything to work porperly. for you to connected to teh wireless, you should have minimum 1GB of memories. some people may disagree with me, but that is what I found to work better, if you have more than required memories.
Feb 11, 2009 | Dell Latitude D610 Notebook
Wireless connecting to network but won't see internet.
Does your wireless ap have any security ie. WEP or WPA?
Oct 31, 2007 | Intel PRO/Wireless 2200BG 802.11g/b
Computers & Internet Logo
98 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
