Question about Facebook Social Network
My wall how do i go to my wall i need all the steps
  • 268 Answers
Simply log in Facebook, click on the top right link: "Profile", then on the tab in the center of the page that says "Wall" -- right under your name (it should actually open your wall by default).
Posted on May 27, 2010
How do you properly hang a mirror in a bathroom on a wall?
1. You should determine where you want the mirror to hang.
2. Make a small, light pencil mark on the wall immediately above the top and center of the mirror.
3. Determine if there is a stud at that location - or is close enough to still be an acceptable location for the mirror. If so, check the back of the mirror and got to step 4 - otherwise skip to step 8.
4. Measure from the top of the mirror to the hook, hanger or high spot of a wire if one is provided running from side to side.
5. Make a mark that is the same distance DOWN from the original mark on the wall.
6. Drive a nail or screw into the wall at the lower mark. Be sure that the nail or screw is long enough to get into the wood stud by at least 1-1/2" or more. Heavy mirrors should have heavy duty nails / screws that go deeper into the wooden stud.
7. Hang the mirror, erase visible marks - Done!
If there is no stud near the desired center location on the wall for the mirror,
8. You'll need to stretch and secure a wire between the left and right-most edges of the mirror - but the left and right-most edges should be at least 16" apart for this to work.
9. Project the mark you made in step 2 onto the closest stud to the left and to the right that you can locate These shouldn't be more than 16" from each other. Measure from the floor up or ceiling down to both of these marks to be sure both are the same height.
10. Perform step 4.
11. Perform steps 5 and 6 for each the two new marks you made in step 9.
12. Perform step 7.
Nov 03, 2015 | Home
What is the remote learning code for my 32" TV
Mounting an LCD (Liquid Crystal Display) TV on the wall may seem a bit overwhelming at first; but it's not that difficult. With a few simple tools, a proper mounting kit and a helper, the job will be a breeze. With a little bit of patience and an hour or two, your LCD TV will look great. Follow these steps to learn how to mount an LCD TV on the wall.
Things You'll Need:
LCD TV
Mounting kit
Tools
Step 1
Find the best spot on the wall to mount the LCD screen. Think about how much room you may want on that wall, especially if you plan on mounting speakers, too. You could hang a poster or picture relative to the size of the television on the wall to see if you like the placement.
Step 2
Pick a mounting kit. You can purchase mounting kits online (see Resources below) along with many other sites. Look to make sure the kit and TV are VESA compatible so that you have standard measurements and quick, easy attachment during the mounting process.
Step 3
You may already have tools needed to mount the TV. You'll need a set of screwdrivers, a socket set, a saw capable of cutting into drywall, a drill and a measuring tape. Having a stud finder with a built-in level is also great to pinpoint the exact location of the stud. The stud finder will be useful if you'll be running wires through the wall.
Step 4
Get the location for the TV picked out. Check near the bottom of the wall to see if the area you plan on using to run the wires is free of obstructions. Using the stud finder for this will make it easy.
Step 5
Find the studs. You should use at least one stud when mounting the LCD screen to make sure that the mounting bolts are driven into something solid that will support the weight of the TV and the mounting bracket. Using two studs is ideal for mounting larger TV's, those with screens larger than 37 inches. Use a pencil to mark the drill holes for the anchors and stud location.
Step 6
Secure the mounting rails to the back of the LCD screen. Double check them for proper fit. Make sure that they're hidden behind the body of the television for a finished look.
Step 7
Cut the hole for the wires to come through by using a drywall saw. The easiest way is to pull them out at the electrical box. This avoids having to go into the basement, closet or otherwise. You can purchase a wall box at your local home improvement store to place in the exit hole of the wires.
Step 8
Drill the holes for the bolt anchors in the locations that you measured and marked previously. Place the bolt anchors into the holes and tap them in with a hammer.
Step 9
Secure the wall mount to the wall. You'll need a socket wrench to ensure that the mounting bolts get snugged down tightly to the anchors. Use a level to make sure you've done an even job.
Step 10
Grab a friend or family member to help you lift the LCD screen onto the mount. Make sure it's locked down tightly and the screen is set to go.
Hope this helps and Good luck
Sep 25, 2011 | Televison & Video
Hp officejet 6500 all lights are flashing and mechine says turn off and on . Please can someone Help??
: Check the power cord
1.
Turn on the product.
2.
Remove the power cord from the back of the product.
3.
Check the power cord for any physical damage. If the power cord is damaged, replace the power cord.
If these steps resolved the issue , you do not need to continue troubleshooting.
If the issue persists , continue to the next solution.
Turn the product off and then on again
1.
Press the Power button ( ) to turn the product off.
2.
Wait 60 seconds, and then press the Power button ( ) to turn the product back on.
3.
If the product does not turn off when the Power button ( ) is pressed, wait three minutes, and then proceed to the next solution.
Plug the product into a wall outlet
Follow these steps to make sure the product is plugged in correctly.
1.
Unplug the power cord from the back of the product.
2.
Unplug the power cord from any surge protectors or power strips.
3.
Select a wall outlet to plug the product into. Test the wall outlet by plugging another electric appliance, such as a lamp, into the wall outlet and turning it on. Unplug the test appliance.
4.
Plug the power cord into the back of the product.
5.
Plug the power cord into the wall outlet.
6.
Press the Power button ( ) to turn the product on.
Solution six: Reset the product
Follow these steps to reset the printer.
1.
2.
Unplug the power cord from the wall outlet.
3.
Wait 10 seconds, and then plug the power cord back into the wall outlet.
4.
NOTE: Many power cords have an LED light on the power module or on the end of the cord that plugs into the product. Make sure the LED light is lit and steady.
5.
6. Perform a partial reset of the product
  1. Disconnect the power cord from the product.
  2. Wait for 20 seconds.
  3. Press and hold # and 3 while reconnecting the power cord.
  4. When the product turns on, release both buttons.
  5. Try printing again.
IF still won't resolve it by following steps mentioned above then your printer needs replacement. Malfunctioning hardware.
Mar 28, 2011 | HP Officejet 6500 Wireless All-in-One...
When i turn on my asphire 5050 nothing happens only the power lite is on
step one... unplug the laptop from the wall.
step two... remove the battery from the laptop
step 3...... plug the laptop back into the wall
step 4------ turn on laptop...
if it turns on you have a bad battery and it needs to be replaced...
if you have no wall power and turn on the laptop, the reverse is true... meaning your battery is fine and your power cord/inverter is bad.
If you need further help, reach me via phone at https://www.6ya.com/expert/jim_8aa10a90cbbc76ff
Mar 10, 2011 | Acer Aspire 5050-3242 Notebook
I have an ULPT-X Omni Mount that I will be using with a Samsung 65" LED. How do I mount the ULPT-X to make sure that the exact center of the TV will be in the center of the wall space it will be hung on. ...
What do you mean by centered on the top and bottom? It doesn't need to be centered in the exact part of the wall for the tv. it all depends on what your viewing height is for where you want the tv vertically. Once you figure that out you mount it where you want it for your personal viewing preference.
Thank you,
Lee
Oct 26, 2010 | Televison & Video
The ac adapter red light stays on and the counsole will not work
This problem occurs when the external power supply has detected a fault. The power supply has several built-in safeguards to help prevent damage to either the console or to the power supply. The power supply will turn off if one of the following conditions is true:
• There is too much current.
• The voltage is too high.
• The temperature of the power supply is too high.
When any of these conditions are true, the light on the power supply turns red. Here are some steps that you can use to try to fix the problem.
Step 1: Make sure that the power supply is cool
The red light might indicate that the power supply is too hot or that it has overheated. Follow these steps if the power supply light is red:
1. Make sure that your Xbox 360 console is turned off.
2. Disconnect your Xbox 360 Power Supply from your Xbox 360 console and from the wall outlet.
3. Let the power supply cool for two hours in a well-ventilated space. Do not connect the Xbox 360 power supply to the console or to the wall outlet during this time.
4. After the power supply has cooled for two hours, reconnect the Xbox 360 Power Supply to the console and to the wall outlet.
If cooling the power supply does not resolve the problem or if the problem persists, use the steps in the next section.
Step 2: Make sure that the power supply is plugged in correctly
Make sure that the power supply is directly plugged into a working wall outlet. You may have problems with the power supply if you use an extension cord or a power strip if the extension cord or the power strip is faulty or cannot supply the required power to the console.
If the power supply is still not working as expected, use the steps in the next section.
Step 3: Plug the power supply into a different wall outlet
To eliminate the possibility that the wall outlet you are using is faulty or that there is a blown fuse, plug the power cord into a different wall outlet in a different area of your place of residence.
If this does not resolve the problem, use the steps in the next section.
Step 4: Try another Xbox 360 Power Cord and Xbox 360 Power Supply
If you have a different Xbox 360 Power Cord and Xbox 360 Power Supply, try to use them to test the console. If the console turns on when you use a different power cord and power supply, you need to replace the faulty power cord and power supply. If the console does not turn on, the issue may be with the console itself.
Step 5: Obtain a replacement Xbox 360 Power Supply
If the steps in this article did not resolve the issue and the Xbox 360 Power Supply light continues illuminate red, you need to obtain a replacement power supply.
let me know how you get on or if you need further assistance ok
plz rate this solution as i have a whole page of unrated posts, thanks
Sep 18, 2010 | Microsoft Xbox 360 Console
Friends can't post on my wall
Follow the steps below:
Login to your facebook account > Click "Account" on the top right corner > "Privacy Settings" > "Custom" > "Customize Settings" > scroll down to "Things Others Share" and then enable "Friends can post on my wall", you friend can now post on your wall.
For your better understanding, you can refer to this step by step presentation:
1.
2.
Good luck.
Thanks for using FixYa.
Aug 12, 2010 | Facebook Social Network
How do I mount my Soyo MT-SYTPT3227ABMS on the wall
Things You'll Need:
LCD TV
Mounting kit
Tools
Step 1
Step 2
Step 3
Step 4
Step 5
Step 6
Step 7
Step 8
Step 9
Step 10
Aug 03, 2010 | Microsoft MT-SYTPT3227AB 32 in. LCD TV
Power surge - washing machine Not turning on.
Instructions Things You'll Need:
  • GE/ lg washer
    Primary Method---Newer models
  1. Step 1 Unplug the washer.
  2. Step 2 Twist the control dial around the cycle settings.
  3. Step 3 Place the dial on any setting other than the final spin.
  4. Step 4 Ensure that the water line is securely attached to the washer.
  5. Step 5 Plug the washer back into the wall (making sure it has gone at least 30 seconds without power).
  6. Alternate Method---Older Machines
  7. Step 1 Turn the dial around the cycle settings, but do not lift it to start the cycle.
  8. Step 2 Unplug the washer.
  9. Step 3 Plug the washer into the wall after 30 seconds without power.
  10. Step 4 Lift the washer lid five times, making sure it reaches a height of at least 6 inches or more. There should be no more than a 15-second interval between lifts.
  11. Step 5 Listen for a clicking noise. If a click is not heard, repeat steps 1 to 5 until you hear it.
  12. Step 6 Place a small load of laundry into the washer and start the cycle.
  13. Step 7 Watch the load throughout the wash to ensure the washer is working properly.
Dec 26, 2009 | LG Washing Machines
Do I need a new printer scanner
Please perform the steps below to resolve the issue:
Step 1: 0x error Weblink
Step 2: Clean the Rollers
Step 3: Ensure correct installation of the front panel overlay
Step 4: Connect the All-in-One unit directly to wall outlet
Step 5: Power Cycle
Step 6: Semi Full reset
Sep 21, 2009 | Office Equipment & Supplies
Facebook Social Network Logo
67 people viewed this question
Top Facebook Computers & Internet Experts
David Payne
David Payne
Are you a Facebook Computer and Internet Expert? Answer questions, earn points and help others
