Question about Whirlpool Dryers
Model# LGR7648KQ1 Serial# MP5127133 Just stoped turning on :-(
  • Terri Watt
    Terri Watt May 26, 2010
    It does nothing
    Top Expert:
  • Whirlpool Master
  • 76,630 Answers
Do u hear the motor running but the dryer doesn't spin over? does it heat up at all even though it doesn't spin, please clarify information and add more detail, u are there and i am here, so need your eyes and ears on this.
Posted on May 26, 2010
My turck has the 5.0 it is a 90 model it just stoped fuel pump is working and got fire it will turn over but want start why
my truck has a 4.9 engine 90 model f150 pickup it just stoped fuel pump is working and got fire it will turn over but wont start why
Oct 07, 2011 | 1990 Ford F150
Radio wont turn on cause the battery went flat and i replaced it then it asked for a code and i input the code i had but the radio stoped working
The radio SERIALNUMBER will be required for calculating the correct code On some radios, pressing Buttons 6 and 1 or 6 and 2 (together) maydisplay a Serial Number If not , then removethe radio from the dashboard. Then post the radiomake+model plus all the letters+numbers on any labels,barcodes or stamped inthe metal casing. This information canthen be used to see if a code can be calculated
May 14, 2011 | Car Audio & Video
My heater motor stoped turning and blowing but the heat strip kept heating and melted the rotating fan . It is a 20406D7F 077 can I order a whole complete replacement unit
Yes, you probably can. Plus, Dimplex should be made aware of this. Contact Dimplex Technical Service 888-346-7539, Monday -Friday, 8a -4:30p ET. Have the model number, serial number and proof of purchase, handy when you call.
Hope this helps you get the parts you need.
Apr 26, 2011 | ACE Dimplex (r) Compact Electric Fireplace...
Serial#37461 zo1ff73m stoped working
http://www.rinnai.us/customer-support/manuals-literature/ i typed your numbers in but could not get a hit normaly they have good trouble shooting sections. see it you can find a model # that will work
Feb 15, 2011 | Rinnai Toyostove Direct Vent Heater:...
I would like to obtain the user manual is it
Sure. Just click on the below link to access your user manual. Be sure to print it out for safe keeping, and storage.
CLICK HERE
Jan 06, 2010 | Whirlpool Dryers
How do I open up my kenmore 70 series dryer, it stoped running and I want to check and see if it is dirty, as that has caused this before
LE7680XSN1 Model Serial M80824319 Whirlpool Heavy Duty Dryer. Runs fine but will not heat. What should I check to get the heat to work
Dec 15, 2009 | Kenmore Dryers
I have a Whirlpool gas dryer model #LGR7648KQ1. When I first start it it heats but after a short time it stops heating. It sounds like it is trying to start again but it will not.
The easiest way to check the ignitor is to observe it. Remove the small access panel in front, select a high temperature setting and start the dryer. Watch the burner assembly, shortly after starting the dryer the ignitor should begin to glow or spark. If you see it glow or spark, then the ignitor is working.
You need a flame sensor
Aug 03, 2009 | Dryers
LGR7648KQ1 model, dosen't seemd to have in lint in
The thumping noise is a stress crack from poor construction when thr drum was made. I have the exact same problem and found the crack when I removed the top cover by removing the rear upper brace support screws and bracket, then sliding the top dryer panel towards the rear about 3.5" and then lifting it off for complete drum inspection. Rotate the drum by hand and you will see the crack...Mine is at the front, next to the drum seam.... We should all get together and file a class action suit...I'm sure this is a manufacturer fault related problem with this model..
The crack is probably allowing air to bypass the normal air flow through the filter too... Richard
Jun 27, 2009 | Whirlpool Dryers
Whirlpool dryer model number lgr7648kq1 won't get
Sounds like one of the cavity switches is bad. Open back of dryer, you will see wires that attach to little clip next to each other. Try jumping wire from one side to the other, do one switch at a time and try dryer to see if heats, if you get heat replace that switch. These switches burn out if dryer gets to hot, usually from to much lint in duct work. Also vacuum out duct work in wall and on back of dryer.
Jun 14, 2009 | Whirlpool Dryers
Dryers Logo
14 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
