Question about Dometic Rooftop RV Air Conditioner
1999 springer camper Air conditioner stopped
1999 springer camper Air conditioner stopped working seems blower comes on but no air
  • 36 Answers
I just repaired mine today...Is your ac ceiling controled or thermostat controled?
Posted on May 27, 2010
Carrier unit in camper wont come on ..dead..fuses ok..?????
Have you checked breakers in panel, to make sure one isn't tripped?
What type, year camper is this on?
Feb 23, 2013 | Dometic Rooftop RV Air Conditioner
Air conditioner
You are saying the blower motor stops when the truck stops moving ?
Or the blower motor doesn't work and the only air you get thru the vents is outside air when the truck is moving ?
Jul 19, 2012 | 2002 Chevrolet Suburban 2500
I have a FEMA camper and my rooftop A/C makes a humming sound with no air flow. what do you think ?
Hi!!
It seems like the blower motorr is not kicking in. Turn breaker OFF, remove the grill, check that electrical connections are nice and tight, and turn breaker back ON, start unit and see if evaporator coil is gatting cold, if so, Turn Breaker off, remove blower motor capacitor and test it, if capacitor OK, blower motor needs to be replaced.
Good Luck!! Rate this Post!!
Aug 11, 2010 | Dometic Rooftop RV Air Conditioner
Ac cools camper fan blower turns off compressor
hi there,
ac not cycling off,the thermostat is not working
have to replace a new one.havve anice day fix my rate thanks
May 14, 2010 | Dometic Rooftop RV Air Conditioner
Have a 93 airstream camper with a Dometic AC unit . When I tuun the unit on either to heat or air,it brings the house voltage down to the red zone but does come on but seems to be draining the power.
Does the fan seem to labor when starting up. (basically starts up but seems slow to get up to speed?) Then when fan is turning at normal speed, the power inside seems to go back to normal?
May 09, 2010 | Dometic Rooftop RV Air Conditioner
Unit just stopped working during the evening after having run for 4-5 hours fine. circuit breaker not the problem.
Check your voltage to the unit. Be sure to use a big cord when hooking up your camper. Does the unit have a wall mounted thermostat? Does the blower run? When was it cleaned last?
Aug 21, 2009 | Dometic Rooftop RV Air Conditioner
Honeywell T8112 Air Conditioner Will Not Cool, But Blower Works
make sure the system switch is in the cool position, then press run program button and allow a couple of minutes for system to cycle on, if it doesn't come on press the button for lowering the set point, set it to 72 degrees and then press the hold temperature key.
May 27, 2009 | Honeywell ER150B Air Conditioner
Air conditioner works but not blowing out the vents
Check the air directing servo motors under the glove box. they are 2 black boxes about 3"x3". you have to clean the contacts of grease with contact cleaner spray or alcohol.
Aug 19, 2008 | 1999 Lexus RX 300
Air conditioner fan will not come on and unit will run for 1 minute and stop
You hear the compressor kick in (Hum) but no fan comes on? Will the fan come on when just in fan mode, not cool, or do you have that set-up?
Aug 13, 2008 | Dometic Rooftop RV Air Conditioner
Air conditioner
Turn off unit supply and check the blower wheel inside the indoor unit by rotating it manually by your finger if the blower wheel rotates freely then there is something wrong with your fan motor or fan motor capacitor. But if the blower wheel is not rotating freely try to check the fan motor for lubrication or some bushing dried of and no oil
Dec 10, 2007 | Heating & Cooling
Dometic Rooftop RV Air Conditioner Logo
184 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
Tim Whalen
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
