Question about GE DBXR463GB Gas Dryer
Glow plug glows flame lights up after 30 sec flame goes out
  • 5,911 Answers
If the burner assembly lights, then the problem is usually not with the igniter or regulator. More than likely the gas valve safety coils need to be replaced. There are two of them on the burner assembly. You need to replace BOTH of them at the same time.
If the model number is correct, you can view and illustration of your burner assembly here:
http://pcappliancerepair.com/model-display.php
The coils are listed as items 729 and 731. Part numbers WE4X692 and WE4X693, respectively.
If you have any questions, or if your model number differs from the one you listed this question under, please post back and let me know. I hope you find this information helpful.
Posted on May 27, 2010
Have a comfort glow heater blue flame after it is on for 30 sec or more the flame and ignition goes out i can restart it and it will stay lite another 30 sec or so what can i do
Easy remedy. You pilot safety is dusty. You need to flush it out or blow it out. I use rust buster. It has a long spout on it. I squirt a little bit into the pilot to flush out dust and cobwebs then I blow it out and allow the rust buster to dry. I then relight it.
Feb 15, 2011 | Heating & Cooling
Inductor blower comes on and runs then the ignitor glows flame comes up and burns for approx. 10-15 sec then goes out then fan comes on. Model number is PBKMLB12N0B0F I believe this is a goodman furnace.
I cleaned the sensor that was at the the right further most burner on my Goodman and it worked. got the answer to my problem here at fixya. My burner flame only lasted 5 secs before it shut off. Thanks to all who took the time to send me a response.
Nov 13, 2010 | Goodman Heating & Cooling
The flame goes out after about 30 seconds. I have
one of the thermal sensors may be bad.
you may also have a faulty ignitor even though it glows it maynot be drawing enough current to keep the regulator open
May 28, 2010 | Maytag Neptune MDG7500AW Gas Dryer
I have a roper gas dryer model rdg4440sq0, the igniter glows then the flame lights. Then the flame goes out and doesn't light up again. When it cools down and i restart the dryer the igniter glows and...
If when the flame goes out ...Check to see that the igniter glows...If it glows and the gas does not light then replace the valve coils...Very common problem.....The coils are to weak to hold the valve open..
Apr 20, 2010 | Dryers
Fan comes on glow plug lights up but no flame.3 sec. fan shuts down.Have clean all lines, tips everything. Model 60 Reddy used very little in ten years.
this have a flame controler, if the flame didn't goes on in few seconds the unit automatically stops. back plug and start again, if not star after tree times check the flame control thermocuple, or get the unit in service to fix it.
Feb 14, 2010 | Reddy R60A Utility Heater
I hope that I can get this problem resolved. Can there be a thread started to help me through this? I will try to keep this as short as possible, I have a Ducane Mod. CMPB050C3A Nat. gas furnace. The...
say that you have the glow bar (Hot surface igniter) working
if the flame starts make sure you don't trash on the orifice of the burner, you can try to use a piece of wire or someting small to pick on the orifice of the burner, also make sure is not rust bewteen the burners gap where the flame spread to all the burners because if the flame sensor don't feel flame don't stay light up
hopes this help
Oct 09, 2009 | Heating & Cooling
The glow plug just lights up but no flame on my maytag mdg 5500aww
If the ignitor is glowing but the gas does not light check the flame sensor. If it is OK then the gas valve coils may have to be replaced.
Aug 12, 2009 | Dryers
Re: golf yellow glow light
the idea or concept of the glow plug is to heat the fuel long enough to start the motor.... it should stay on long enough for the glow plugs to heat up enough to start the motor then they go off because they have done their job. so the light going out is normal after a few seconds
Robert
Please take a moment to rate this solution thanks
Hopefully a fixya... perhaps rate the other the same
Jan 27, 2009 | 2003 Volkswagen Golf
Frididaire gas oven won't light
Does the cooktop burners work? if they do then the problem is either the safety valve or the glow plug (even though it glows). Try tapping the safety valve. If the oven lights up change the glow plug.Otherwise change the safety valve
Regards
Nov 20, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Gas dryer runs for 3 mins and then no more hot air
mjm_III1,I have the same problem and did what you did (replacing the gas valve solenoid coil). My problem is history.
Cheers!
Jun 28, 2008 | Whirlpool GGQ8831L Gas Dryer
GE DBXR463GB Gas Dryer Logo
Top GE Dryers Experts
John Tripp
John Tripp
Sal DeAngelo
Are you a GE Dryer Expert? Answer questions, earn points and help others
