Question about McCulloch 16 In 4.5 Hp Electric Chainsaw With Carrying Case MCC4516FK
Mcculloch EM250-14 RPM Slowed suddenly
I have a Mcculloch Electramac EM250-14 that I have used intermittently over the years around my yard without a problem. On May 8th I had a large tree fall down in my yard after a storm. I have slowly been limbing it since. I am not physically able to use it for hours at a time. Today while doing some of the limbs that were about 2-3 inches in diameter it suddenly slowed to about half speed. I stopped it and in a couple of minutes tried to use it again. It still cut but then smelled hot so I set it aside and took a couple of hours break. It still had plenty of oil. When I went out to try it again the same thing happened. I also took the blade off and ran it for a few seconds with no change. The tree is about 120-140 feet from the house if that helps. Any ideas what the problem might be? I still have a pile of the small branches to cut up.
    Brigadier General:
  • 4,088 Answers
The chain must be properly sharpened to cut efficiently and the oil pump must be feeding oil to the chain/bar. Check the oiling by running the saw with the bar tip near some cardboard for a few moments--it should throw off a thin line of oil on to the cardboard. If not, remove the bar and chain and run the motor for a few moments--it should ooze oil out of a side port that exits near the drive end of the bar. If still nothing, check the oil tank filter for plugging, then the oil pump itself--it may have a plastic gear that has stripped it's teeth. Once you get oil from the side port, clean the oil passages in the drive end of the bar, and reinstall the bar and chain. Hope this helps!
Posted on May 27, 2010
  • drallim May 28, 2010
    If you are running the saw with a power extension cord the full distance from the house and the cord wire size is smaller than 12 gauge, you are likely having severe power loss at the saw. It would be best to have someone with a larger gas powered saw cut the tree into manageable pieces so that the work you are doing can be closer to the house. 100 ft 12 ga extension cord is about all that you want between you and the house. Good luck!
Why does my electramac leaks oil
The chain oil feed is a gravity feed and will continue to feed when you put the saw down. Empty the chain oil resoivour when the machine is being stored. or store it in a driptray.
Jul 19, 2014 | McCulloch Electric Chainsaw Final Gear...
My em10 electramac is not oiling what could be the problem?
I recommend contacting your local authorized service center for assistance.
You may contact the manufacturer, download manuals, check fuel/oil ratios, order parts, find your local service center, and view other resources using these links:
Contact us
What is the correct fuel mixture for McCulloch products Chainsaw Trimmer...
User manuals McCulloch Service
I trust this information proves beneficial.
Jan 25, 2014 | McCulloch 215098 KIT OILER VALVE EM 10 12A...
McCulloch Electramac 3.0 hp EM300s-16
Please restate your answer in the form of a question.
Contact us
User manuals
McCulloch Service
McCULLOCH PARTS ACCESSORIES
I trust this information has proven beneficial.
May 20, 2012 | McCulloch Garden
I need a part for a McCulloch EM14E Electramac a bar for the chain
Contact us
User manuals
McCulloch Service
Jan 18, 2012 | McCulloch Garden
I need the owners manual for Electramac EM16 ES electric chainsaw
Without test: http://es.gigabytedownloads.com/signup/mcculloch_electramac_em_16_es.rar
Need register.
Hope this helps; also keep in mind that your feedback is important and I'll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using Fixya, and have a nice day.
Nov 11, 2011 | Garden
Chain comes off mcculloch electramac em250 chain saw
Adjust the chain until you can pull on it and it will come away from the bar but will not hang from the bar. If that does not solve your problem then the chain or drive gear is worn out. If the oiler is not working it is for sure worn out.
Apr 25, 2010 | McCulloch 16 In 4.5 Hp Electric Chainsaw...
Your chain is too loose or it is worn out. Adjust the tension on the chain. The chain should not hang away from the bar but should be loose enough that you can pull it away from the bar with not much effort. Adjust the tension until it is set correctly.
Apr 25, 2010 | Plumbing
Need owners/service manual for Mcculloch 4.5 Medallon Electramac EM450s.
This is a link to McCulloch International. I couldn't find an exact match to what you requested. I'll bet if you look the saw over carefully you can find a matching number here:
http://www.mcculloch.info/node1092.aspx
Leave the block empty and click [► Search]. A list appears and your saw is probably on it. HTH
Lou
Sep 07, 2009 | McCulloch 16 In 4.5 Hp Electric Chainsaw...
McCulloch 14" electric-will NOT run
check the carbon brushes in it. open the cover of motor you can see two pc. of carbon touching the armature. If that become short it need replacement
Jun 29, 2009 | Garden
McCulloch 16 In 4.5 Hp Electric Chainsaw With Carrying Case MCC4516FK Logo
907 people viewed this question
Top McCulloch Garden Experts
Jim Parker
Jim Parker
roeb
Are you a McCulloch Garden Expert? Answer questions, earn points and help others
